Question about Cameras
My Powershot A530 camera was dropped and I am getting a "lens error, restart camera" message. I have turned it on and off, removed batteries,etc and nothing is working.
  • Cameras Master
  • 4,738 Answers
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Apr 25, 2008
"lens error turning off camera.
If the camera was dropped it can somehow seize the lens related parts since they are mostly made from plastic. It is also possible that particles like sand grains can go between the moving parts of the lens and seize the mechanism. Either case the repair could be expensive and may not worth having it done.
Feb 24, 2011 | Canon PowerShot A495 Digital Camera
Lens error, restart camera.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
May 02, 2010 | Canon PowerShot A530 Digital Camera
When Turning on the Canon Power Shot A530 the
Here are some things that you can do to try to correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, or if repair costs close to the value of the camera, they're worth a try.
Dec 21, 2009 | Canon PowerShot A530 Digital Camera
When i press the power button i get an error message
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 08, 2009 | Canon PowerShot A530 Digital Camera
Camera was dropped-- "Lens error-restart camera" message
If it is still under warranty , please repair it.
If it is out of warranty. Try to get a quote, it the quote is more than 50% of original value , forget it.
For digital camera's they die like flies. New ones are better and cheaper anyway.
Mar 22, 2009 | Canon PowerShot SD800 IS / IXUS 850 IS...
Lense error restart camera
A digital camera's lens is a very easy thing to have damaged. If the lens is bent some time you can force it in to the other direction and it will pop back into place. some times the gears get stripped and the lens then has to be replaced. I replace lenses all the time because of this issue. Hope this helps.
Apr 03, 2008 | Canon PowerShot A530 Digital Camera
Lens error
The following blog outlines some simple repair options for a lens error. They won't work for all cases, but they're worth a try:
Dec 09, 2007 | Canon PowerShot A530 Digital Camera
Lens Error, restart camera
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try:
Oct 03, 2007 | Canon PowerShot A530 Digital Camera
Cameras Logo
159 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
