Question about ASUS A7N8X-VM Motherboard
I want to up gread my ram and memory what size can I go to??
    Problem Solver:
  • 14 Answers
What type of Computer do you have?
Well heres a great Website that you can use, it will scan your machine and recommend sizes and types of Ram. very easy to navigate.
http://www.crucial.com/
Just go to scan my System and the information will be provided.
Happy Upgrading =)
Posted on Jul 28, 2010
Hp Laserjet 2300 showing error 53.10.03
  • 53.xy.zz
  • CHECK RAM/ROM MEMORY
  • Description
  • There is a problem with the printer random-access memory (RAM) or read-only memory (ROM). The DIMM that caused the error is not used. Values of x, y, and zz, are as follows:
  • x = DIMM type
  • 0 = ROM
  • 1 = RAM
  • y = Device location
  • 0 = Internal memory (ROM or RAM)
  • 1 to 3 = DIMM slot 1, 2, or 3
  • zz = Error number
  • 0 = Unsupported memory (for example, presence detect bad)
  • 2 = Unsupported memory size
  • 3 = Failed RAM test
  • 4 = Exceeded maximum RAM size
  • 5 = Exceeded maximum ROM size
  • 6 = Invalid DIMM speed
Jan 04, 2015 | Office Equipment & Supplies
Tip
Virtual Memory too low Warning Trouble in win xp and vista
When there is less physical memory than needed, then some virtual memory (virtual RAM) is created on the disk. When there is a limit set to the size of virtual memory usage and there is not enough of it present there is a warning that frequently comes "Virtual Memory too low". Solution 1 : This problem occurs when physical RAM + Virtual RAM (usually created on hard disk) together are not sufficient to take care of the currently needed RAM size, or this situation is about to arise. This usually happens when some fixed upper limit for Virtual Memory has been set. To solve this problem, you can either upgrade you physical RAM on your computer (recommended), or you can set the Virtual Memory to system managed size or you can do both. Setting Virtual Memory to system managed size means windows will set it to higher size whenever needed automatically,for this, <br /> Right click on My computer --&gt; goto properties, goto advanced tab, click on performance settings, now click on advanced, now click on advanced, now click on change button for Virtual memory. <br /> On this screen select the System managed size, press OK. After this re-start your computer. This will solve the virtual memory too low problem. Solution 2: Recommended solution is to upgrade your physical memory (RAM) according to requirements of the kind of applications that you run on your computer. If you upgrade RAM or not, the following procedure will help prevent this warning by increasing the virtual memory limit. <br /> Right click on My computer icon and click properties. <br /> This will show system properties window. Click on a advanced tab and click on the settings button under heading performance. This will open performance options window. Click on advanced tab and click on change button under heading virtual memory. Check if the space available is set to some custom value or double the RAM size ? If it is not double the RAM memory size , then select the size option set the virtual memory size double the RAM Size and press set button and press OK button. Restart the computer
on Apr 04, 2011 | Computers & Internet
Maximum Supportable RAM size per slot in Dell N4010
go to crucial memory and download their memory scanner. it will tell you how much memory is installed and what the max is per slot on any computer. hope this helps
Jun 24, 2013 | Dell Inspiron N4010 Notebook
Remove meomry & up gread
First you have to find out how big your RAM is, not in terms of capacity, but in terms of how many pin. Once you know how many pins your RAM is you can purchase new RAM from many places online or locally. Before I go any further, I have to know if your PC is a Computer or Notebook.
If its a computer, you will have to take off the casing to expose the internals of the tower. That is where you will see your RAM ports. Usually there will be 2-4 places for RAM to be placed. There will normally be a fulcrum that will need to be pushed or pulled on both sides of the RAM (long ways), once you pull/push those down you can safely remove the RAM. You can tell because it will pop out a little bit to let you know its coming out. Pull them out, and then simply push the new RAM in its place, you should get a POP sound when its in place and the fulcrums/levers should adjust back to the way they were previously with the old RAM by themselves. After thats said and done put your tower back together, and turn the computer on. Please make sure that your motherboard is capable of handling the new capacity RAM you have purchased first though. Also make sure computer is off when you do this.
Aug 17, 2012 | Compaq MS Windows XP Home Edition for PC
Error memory when loading calculus made easy on ti-89 titanium
You may get Memory Error when you try to access an archived variables. From the other hand Memory Error message is displayed if there is not enough free RAM to access the archived variables. For correcting Memory Error message use the 2ND then MEM to check RAM free size and 2ND then VAR-LINK to determine the size of the archived variables that you want to access. As the third step for correcting this problem deleting unnecessary variable from RAM and archiving large variables or programs. By the definition, the RAM free size must be larger than the archived variables
Feb 23, 2012 | Texas Instruments TI-89 Calculator
Opening programs is so slow virtual memory running low
which operating system you are using and what is the ram capacity? and onemore thing to check what is your virtual memory capacity. for that
Right click "mycomputer" > properties > advanced >click settings on performance > in advanced tab > increase virtual memory file size.
generally its size is ram capacity * 2 (ex: for 512mb its virtual memory size is 1GB) check that and we can increase the file size also.
Jun 23, 2010 | Compaq Presario 5000 PC Desktop
Scoreboard schematic diagram
Windows Xp
Step 1. Right Click on My Computer
Step 2. Click on Properties
Step 3. Click on Advance Tab
Step 4. Under Performance Click on Settings
Step 5. Click on Advance Tab
Step 6. Under Virtual Memory Click on Change
Step 7. On the top Check the Box and in Custime Size Put the value..
Value Should be :
Intial Size = ram * 2
Maximum Size = ram * 3
For exampale
1 gb ram = 1024Kb .. 1024 * 2 =2048 intial Size
3072 Maximum Size
Regards
Oct 11, 2009 | Toshiba Refurbished Satellite 1800 PIII...
I need to add extra memory now my lap top works with 128 MB i need to be 256 MB
thats no problem sir,u can upgrade the memory cards of the computer to the level which it supports may be 1gb,2gb or 4gb.....
u can purchase another memory stick of same specifications because its availiable is different size like 128Mb,256Mb,512Mb or 1Gb.....you can use any one according to your wish...
Apr 26, 2009 | Toshiba Tecra 8200 PIII-850MHz/ 256MB/...
Ram upgrade
Its support "DDR SDRAM"
Max Supported Ram is "1GB"/"1024 MB".
Ram Speed: 266 Mhz..
Good luck...
regards,
Dec 04, 2008 | Toshiba Satellite A65-S1068 Notebook
Problem with Mercury PI845GVM motherboard
fine ur problem if very simple as u installed 512 mb RAM on ur pc if at possible try to connect on to the other slot and restart the computer and check ur RAM capacity in ur os if it shows as same 256mb then ur have to change ur virtual memory settings i.e memory allocated to the video so configure ur virtual memory as per requirement then free up RAM memory ..
Steps for virtual memory configuration.
  1. Open System in Control Panel.
  2. On the Advanced tab, under Performance, click Settings.
  3. On the Advanced tab, under Virtual memory, click Change.
  4. Under Drive [Volume Label], click the drive that contains the paging file you want to change.
  5. Under Paging file size for selected drive, click Custom size, and type a new paging file size in megabytes in the Initial size (MB) or Maximum size (MB) box, and then click Set. If you decrease the size of either the initial or maximum page file settings, you must restart your computer to see the effects of those changes. Increases typically do not require a restart.
Apr 12, 2008 | Intel Motherboard
ASUS A7N8X-VM Motherboard Logo
35 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
