Question about Speed Queen ATSA0AWN Front Load Washer
Speed queen front load washer will not go in to a long spin- starts to spin but stops then starts. model atsaoawn pump is clear and working. It doesn't matter loaded or unloaded.
  • ifix4updq Jul 30, 2010
    Speed Queen front laod washer -model ATSAOAWN-
    little or no spin- drain pump clear and working. high spin is intermittant. loaded or empty makes no defferance
    President:
  • 1,554 Answers
The machine cannot advance to the high speed spin cycle unless the wash water is drained first. This can be an issue with the drain so set the machine to drain only and if the pump works without problem then the issue is with the door latch. It is safety feature of the washer not to advance to the high speed spin cycle unless the door latch is properly activated. The intermittent behavior of the problem indicates a loose connection either in the harness connection between the door latch and the machine control or the door latch itself.
Check to make sure that the harness connection between the door latch and the machine control is intact and fully inserted to both parts. The connections must be snug fit and corrosion-free. Reseating the connections several times will help clean off dirt and corrosion build-up in the terminals and the connectors.
The door latch definitely needs to be replaced if there's no issue found with the harness and the connections. Remove the spring and wire hoop assembly securing the door seal to the outer lip of the door opening then peel off enough part of the door seal near the door latch. Remove the screws securing the door latch to the front panel then take door latch out. Install the new door latch and put the door seal back onto the outer lip of the door opening then secure it with the spring and wire hoop assembly.
Feel free to update us about the development of the troubleshooting and repair. You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. Accepting a solution does not stop you from communicating with an expert. You can continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Please make sure to accept the solution you found the most helpful, appropriate, and informative. Failure to do so will automatically give credit to the first solution no matter how inappropriate and non-informative it is.
Posted on Jul 30, 2010
  • 15,935 Answers
The motor controller (speed controller) may be faulty, or the load balance sensor.
Are there any visible indicators when it slows/stops?
What is the exact model # of the unit please?
Thanks!!
Posted on Jul 28, 2010
  • ifix4updq Jul 28, 2010
    the model is ATSAOAWN S/N 070901620 it will start to spin -- slows to tumble then tries to spin again but doesn't ramp up---.the out balance switch bypassed.
  • Kim Willison Baade
    Kim Willison Baade Nov 26, 2013
    I have the same Model #....did you ever get your machine fixed...mine is doing the same thing.
Coin-operated Speed Queen washer: Model swtt21wn
speed queen double front load washer spinning without stop,please give some idea,thanks alot
Feb 21, 2011 | Speed Queen SWT921 Top Load Washer
My Speed Queen washer shakes and walks during the spin cycle. I have leveled the machine and ajusted the amount of clothes in subsequent loads and it still shakes. How do I solve this? Thank you!
Did you remove the shipping bolts from the back of the washer? They are located on the back, usually very clearly marked "REMOVE" and have a red or yellow plastic washer/bushing. This is a fairly common problem with front load washers, from what I understand.
They're big suckers, and they keep the drum suspension from absorbing any vibration (so the drum doesn't slam around during shipping). Good luck!
Jan 27, 2011 | Speed Queen CTSA0AWN Front Load Washer
WHY DOES MY SPEED QUEEN MACHINE HAS STOPPED WRING MY CLOTHING DRY, AND WATER REMAINS IN WASHER
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Oct 16, 2010 | Washing Machines
My speed queen washer made a high pitch noise when spinning. i took the front off and saw the belt was almost cut in half. how do i replace it?
Easy,It just slips over the fluid drive after disconnecting the link to the spin solenoid, then on to the pump pulley.
Adjustment is made by the motor mount.adjustment bolt.
Good luck.
Feb 23, 2010 | Speed Queen AWS52NW Top Load Washer
Speed Queen ATSA0AWN Front Load Washer Logo
270 people viewed this question
Top Speed Queen Washing Machines Experts
Charles T Nevin
Charles T Nevin
fta777
Mike
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
