Question about Singer 7442 Mechanical Sewing Machine
My top thread keeps wrapping around bobbin case and jamming does anyone know how to fix this tyvm
  • Singer Master
  • 7,365 Answers
Try these suggestions
1.check needle to see if it bent-roll needle on flat surface & see if it roll true
2.check to see if thread is coming off thread take-up lever
3.check the thread tenison
4.check for lint in the bobbin case area
5.check for loose thread in the bobbin case area
6.check to see if the bobbin is bent or warped
Posted on Aug 01, 2010
How to fix a bobbin case that is jammed in place by a piece of thread--case will not come out.
Very gentle persuasion with small (embroidery) scissors to cut the thread then tease i out per strand so you dont do damage to the timing mechanism. Often happens if you wind a bobbin and leave the needle threaded without locking the needle which should be done when yo wind a bobbin. If you send me the make and model Of the achine as long as it is not a computerised one, I may be able to suggest an alternative.
Oct 26, 2015 | Sewing Machines
My elna 2800 is jamming the bobbin the thread keeps wrapping around the bobbin case. What can I do
try changing the needle, make sure the machine is threaded correctly,using every thread guide. make sure the top thread hasn't come off the thread take up lever, try a different bobbin, could also be a timing problem
Dec 03, 2014 | Elna Sewing Machines
Bobbin wraps around itself and jams up
You may have the wrong bobbin in the machine. If it sticks up out of the bobbin case the upper thread will wrap around it.
This would be for a top loading machine.
What model is it?
Oct 18, 2014 | Sewing Machines
Top thread keeps getting wrapped around bobbin case on LX-3125
You should hold the end of the thread coming through the needle until the thread has grasped the bobbin thread.
Jun 30, 2009 | Sewing Machines
Singer CG 550 Top thread keeps wraping around the bobbin and jam
Have you checked the top thread is correctly placed in the spring of the bobbin case?
Feb 20, 2009 | Singer 5050 Mechanical Sewing Machine
Thread jams & wheel axel cannot turn
there are a couple of things that come to mind.
Bobbin:   wound with uneven tension.  Try taking the bobbin, rewind that thread onto another bobbin and wind slowly.  make sure the thread feeds onto the new bobbin evenly.
upper thread:  catching on something or not flowing off the spool easily.
you're doing well, sounds like you consulted the manual and used your noggin, hang in there and let me know if this doesn't help.  we can troubleshoot some more!
Jan 12, 2009 | Sewing Machines
Bobbin thread getting jammed
kyoungblood4
Are you making sure that your pressure foot is up when you thread the upper thread? If it isn't then your thread is not seating correctly in the tension disks. It will then be loose and make a birds nest(mess) under what you are trying to sew. The other thing to check is which way you are putting the bobbin into the bobbin case, different machines do it different ways. Some want the thread to come out of the case in the same direction as the slot on the case and some want it to come off in the opposite direction.
Guest,
Probably when your son broke the needle he knocked it out of time. You will need to have a sewing machine technician to repair that.
Hope this has been helpful for you bothl Liz M
Aug 07, 2008 | Sewing Machines
Bobbin tangles up thread and jams machine
Hi, Is it your bobbin thread or the top thread wrapping around the bobbin. I just got a used PE150. The top thread keeps wrapping around the bobbin. It is not picking up the bobbin thread. Did you find a solution for your problem?
katfou
Jan 30, 2008 | Brother XR-65t Mechanical Sewing Machine
Top thread wraps around bobbin
Is it birdnesting under the bottom or it is actually getting tangled inside the bobbin case? I've had my machine for almost a year and don't think I've had your exact issue. Sometimes, when you do a stich over a already stitched portion, you may have a problem with the bobbin and I just generally stop and start it again. It is important that you use the correct needle and also use a good embroidery thread and stablizer. Another thing suggested is changing the needle after about every 5 designs. Also, check the bobbin case to make sure there's no fuzzies caught in it. I use "canned air" like you use on computer keyboards. I also only use 40 weight emboidery thread for the top and actual bobbin thread for the bottom. Other threads can really jam everything up. So it's been trial and error to find the right combinations. Good Luck!
Oct 30, 2007 | Brother SE-270D Computerized Sewing...
Singer 7442 Mechanical Sewing Machine Logo
416 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
