Question about Coleman Powermate Premium Plus 6250W Portable Generator
Have 10 hp Tecumsa engine and can not get ignition spark from plug. Have new spark plug, cleaned flywheel & coil with emery cloth. Have checked on/off switch for continuity. Can ignition coil be tested off of engine?
    Scholar:
  • 142 Answers
Did you check, that the magnet is on the flywheel.
When you cleaned the flywheel, did some metal rasping gather around it.
The magnet should be strong. A small steel instrument will be pulled by it.
The high voltage coil can be tested for resistance with an Ohm meter. The resistance may be some kOhm but not MOhm. If MOhm it should be replaced.
If the coil and magnet are OK, and well attached to the flywheel and aside with a minimal air gap, then the coil may be checked by turning the flywheel. As the voltage on coil ends when magnet passes by the coil should be very high, the only way for checking is with a spark plug, connected to the checked high voltage cable, the thread of the plug well connected to motor case. A spark is the prove that it is OK
Check also the HV cabel and the connection of other coil end to motor case.
I hope that this will be helpful, because I don't have your device in front of me. Some people rank such an answer with 2 thumbs (meaning useless). Better don’t rank.
Posted on Jul 29, 2010
  • parlapanov Aug 04, 2010
    Thank you, better ask some one else again.
How do i fix weak spark
You can try to remove cover and remove coil. Then, take some emery cloth and carefully clean the end of coil that faces flywheel. Then reinstall coil and remember to set gap per manufacturers recommendation. If your not sure you can use a feeler gauge and set to .004 -.005". This is slightly closer than most but will be OK, and should give a little more spark as well. Also, don't forget to clean up magnet on flywheel with emery cloth too. Doing this should give you as much spark as you can get from coil, if it still isn't enough you may have to replace coil. Good luck and I hope this helped.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Nov 18, 2013 | Garden
No spark on a 126T020675B2 Briggs 6.75 hp mower engine
gap needs to be 10 thousands of a inch done with a brass feeler gauge ..mag/flywheel has a spot with a magnetic field if you look you can see it it should make a 1/2 wrench stick to it if not replace mag/flywheel ..check key way also
Jun 05, 2013 | Mtd 22" Yard Machine Push Mower
No spark
Check ignition coil, and the magnet if inside the flywheel, could be loose
Mar 31, 2013 | Craftsman 10.5 Hp 33" Commercial Cutting...
Tecumseh engine has no spark. spark plug has been replaced
iF IT IS EQUIPPED WITH A CDI (CAPACITOR DISCHARGE IGNITION) IT IS PROBABLY BURNT OUT AND MUST BE REPLACED. IF IT HAS A COIL, TRY CLEANING THE MAGNITO AND COIL WITH EMERY CLOTH THEN REGAP IT.
Feb 09, 2011 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Have a 5600 Gen. with 10 HP B/S engine OHV. Did great during Rita, replaced carb- changed gas-replaced plug- doesn't want to fire it seems. Where Can I find the magneto ? Are there points on the flywheel...
The magneto is by the flywheel. Depending on the age, there maybe points under the flywheel. If so you remove the flywheel and there the points are. Sometimes bugs build cacoons between points, make them inoperable. Newer engines have electronic ignition though. Follow the small wire from the magneto coil ( where the spark plug wire goes) it will either go under the flywheel through a plastic bushing, or to an electronic module. The magneto coils do fail you can test with an ohm meter. Before that test for spark. You can remove the spark plug, and let it rest on the engine to get ground, and turn the engine over. You always need 1-spark, 2 fuel . If you have spark, see if it will hit on starting fluid, if it does, then you have a carb or fuel filter issue. Those shut off valves on the bottom of those tanks, can be a problem
Jun 29, 2010 | Briggs Stratton H7159 & Stratton® 5500,...
Have 303447 briggs 16 hp only fires one cylinder
Have you also changed the spark plug too. The ignition circuit is pretty simple, from the battery, the Coil is energized, the "points" or equivalent, through the "Distributor" or equivalent, and onto the Spark Plug. So it is a simple matter to work along the path, proving the "Integrity" at each, point by testing. IF it still doesn't fire after ensuring all Leads are OK, the Spark Plugs are proven OK, the Cables, the Points, & Distributor, . IT is either that or the Ignition Timing is OFF. Please check all those points.
Apr 23, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
I have a briggs and stratton motor off a ride on. 12 Hp I/C Quiet model 281707 type 0148-01 with no spark. I've cleaned the flywheel, the coil and bought a new plug. Any thoughts?
Make sure that there is .010-.012 clearance between the flywheel and the coil . As this is a engine that has electronic ignition you do not have to worry about points and condenser. Also check to make sure that the ground wire from the ignition switch to the coil is not shorted out on the frame anywhere.And make sure
Apr 12, 2010 | Garden
Simplicity Sno Away Snow Thrower Briggs 6hp engine No Spark
Check engine oil.
Remove wire from low oil sensor and the start.
Replace low oil sensor.
Hope this tip help solve your problem.
r/David
Dec 28, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
Engine will not start, no spark
Try taking of the engine shroud and cleaning the magnets on the fly wheel. Also clean the two little prongs that are really close to the fly wheel. Use fine sand paper or emery cloth. Then check the spark plug wire for rust (clean if any). Try replacing the spark plug if it is old.
Let me know if this helps.
roundo4
Aug 22, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
152 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
