I get the error 344 message continuously to this one number i'm trying to fax to. i can fax to any other number, but this one # almost always produces this error 344?
    Problem Solver:
  • 19 Answers
Then the problem is most definately on the fax you're trying to send to, and not on your machine. If it works to all other numbers but not to that specific one, then you can shift the blame to the other guy.
Posted on Jul 28, 2010
My HP 8600 Premium no longer sends or accepts FAXes. It says it's connecting, but never does. And returns error 344. I know the other fax machines are working fine. Please advise.
Here's a document that explains some on the fax error codes: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=buu02549
The code 344 indicates noise or static on the line and usually the best way to get around that is to disable Error Correction Mode and/or lower the fax speed.
To disable the Error Correction Mode (ECM) touch the right arrow, then Setup, then Advanced Fax Setup, then down arrow and then Error Correction Mode and set it to Off.
To lower the fax speed, also go to Advanced Fax Setup and set it to Slow.
Nov 07, 2014 | HP Officejet Pro 8600 Premium e-All-in-One...
Error 386
Hi Error 344,
Is telling you the remote end has hung up the call which means it may not be a fax number (you called a voice line number for example, you can confirm if it as fax by just calling the number on your phone if you hear the whistles of a fax then that's not the cause).
I'm not familiar with the HP model but if it is "Super Group 3" (you can tell this if the transmission speed is capable of above 14.4kbps) and you're trying to call an older fax the remote machine may not be able to recognise the "Calling tone" your machine is sending and so it hangs up. You can try to remedy this by temporarily disabling Error Correction Mode (ECM) in your machines fax set up menu this will disable the Super Group 3 capabilities of the fax and maximum transmission speed will be reduced to the older Group 3 machine. HP website recommends the following:
Error Code: 344, 345, 346, 347, 348, 349 ECM, 350 ECM, 351 ECM, 352 ECM, 353 ECM, 354, 355 Definitions
  • The remote machine failed to respond to a fax command from the local machine because the connection was interrupted. These errors can occur if the phone lines in the area to be faxed are old or there is noise (static on the phone line). Other reasons can include power outages and other power-related problems.
  • The call-waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
  • The remote user pressed the Stop key while the reception was in progress.
  • Under rare conditions, incompatibility between the two machines might cause the remote machine to abandon the call.
Solutions
  • Retryt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
  • Disable ECM. Errors might still occur, and might result in a degraded image quality on the received page. However, the ability to send the entire document will be improved.
  • Try sending at a lower transmission speed.
Error Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395 Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Jan 23, 2014 | HP Officejet 6600 e-All-in-One -...
Fax error 344 - HP officejet 4255 all-in-one
fax error is remote machine not responding to your fax.the other fax has stopped communicating.this is a comms error.
Jun 29, 2009 | HP LaserJet 3050 All-In-One Printer
Fax series 920, can receive but not send faxes, error code 344*
Do you have or are you sending a fax to a party that has a DIGITAL PHONE SERVICE?
Jun 04, 2009 | HP 920 Plain Paper Fax
Fax
344 Error can be caused by a few things. One of the following is occurring:
The sending fax has failed to respond to a fax command from the receiving fax due to poor line quality or fax interruption.
The sender has pressed cancel button while the reception was in progess.
In rare conditions, incompatibility has been encountered by two faxes and causes the sending fax to abandon the fax call.
Solutions:
Fax session was using ECM. Check your fax settings under the fax set-up menu on the printer. Disable the ECM (Error Correction Mode).
Fax at a different time to see if line quality improves.
Try relocating the fax to a differnt phone plug.
Replace the phone cord attached to the fax/printer.
Aug 18, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Error 344- Fax Function
Try to connect the phone line from the phone oulet directly to the line one connection of the machine.
May 09, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
Comm Error 344 is: (Note that this is on the receivers end)
The remote machine has failed to respond to a fax command from the product because the connection is interrupted.
The remote user has pressed the Stop button while the remote machine was receiving.
Under rare conditions, incompatibility between the two machines can cause the remote machine to simply abandon the call.
This website will show you what the error codes are.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00062808#A5
Feb 26, 2008 | HP LaserJet 3050 All-In-One Printer
478 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
