Question about Moultrie GameSpy 4.0 Digital Camera Deluxe
Can not read lcd lines are missing - Moultrie GameSpy 4.0 Digital Camera Deluxe
  • 13 Answers
Now you can fix the lcd . Get the "how to fix your moultrie display" on ebay. is really easy
Posted on Aug 19, 2010
I have same problem. I think it will take a new LCD assembly. How do I get one?
Posted on Aug 02, 2010
Have the same problem on this camera and the last Moultrie camera I bought. Threw the first one away. Was a fool to buy the second. The LCD went out two weeks after end of the warranty period.
  • Ronald Lockhart Jan 04, 2011
    2007 and 2008 Moultrie got bad batch of LCD's from China(go figure)...they have a plastic tape stuck to ribbon connector cable...remove lcd; hold with heavy glove, heat until lcd can be unstuck from pcb...use a pencil eraser to massage contacts...heat back of lcd, restick to pcb...90% fix rate.
Lcd replacement for C510
According to the User Manual on page 82:
"If the messages do not appear, turn the printer off and
contact the Lexmark Customer Support Center at 1-859-
232-3000 or http://support.lexmark.com. "
Attaching User Manual.
http://images.lexmark.com/publications/pdfs/c510/eng/userref.pdf
Feb 18, 2014 | Lexmark C Office Equipment & Supplies
Cant read led bar
I think you mean LCD display? If so, then LCD displays with missing columns or lines can often be improved by gently heating the ribbon cable where it connects to the circuit board (using a hair dryer, for example) and gently rubbing the connection area with a pencil eraser. Haven't tried this on my wingscapes cam (because I can sort of still read it) but when it gets too messed up to use I'll give this old, tried and true method a shot.
Oct 19, 2013 | Wingscapes 8.0 MP BirdCam Digital Camera...
I,m at my home in FL and my Aqualink one touch programmer lcd screen is difficult to read lines missing and unable to read the display properly can anyone help as a new one is $400.00 dollars ouch
I have the same problem. The LED seems to glow only about 10 percent of maximum. Is there a solution to this? I've tried turning off and on through menu, but brightness is almost non existent.
Oct 23, 2012 | Jandy Aqualink Rs4 One Touch Control...
When I take a photo there are lines across the screen, also when I look at them it says read error.. ?
A CCD problem would explain the lines on your pictures and the lines on the LCD (since the CCD is used to feed the live image).
If seen on both your pc monitor as well as the camera's LCD then it's likely a CCD issue and it's no wonder that it will be more expensive than buying a new digicam. This is why you need to be exceptionally careful when taking care of your camera since most are uber sensitive to being damaged by the slightest miss-handling.
In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own.
Other Fuji comments here: news/0510/05100403fuji_advisory.
May 21, 2011 | Fuji Finepix S5800 Digital Camera
When I take a picture, the image comes out with some green lines going across it. What could possibly be the problem?
NOT a good sign --
If the lines are just on the LCD and NOT on the PC when downloaded , then it's the LCD missing a address line for the other colors. (green means you are getting yellow & blue but NO RED).
If the lines are both on the LCD / viewfinder and the PC then you have a sensor problem. The Glass lens just focuses the light onto a square sensor made up of thousands of light sensitive transistors which turn light into information (color codes) - which get sorted into images.
A sensor problem means the electronic collector is not reading one or more lines of sensors.
I hope it's number 1 - because the second fix is a factory fix assuming it's still under 90 days warranty. Ray
Jan 20, 2011 | Olympus Stylus 760 Digital Camera
Inspiron 1525 horizontal lines missing
You can try to uninstall and reinstall the video driver in dev manager. try to check if this happens in bios aswell if it does then it may be the lcd itself.You can contact the manufacturer to have the lcd replaced if your computer is still under warranty.hope this helps...
May 23, 2010 | Dell Inspiron 1525 Laptop Midnight Blue
My Sharp monitor172CB is missing part of the
Sounds like the back lights are burned up. That will make it difficult to see. There are videos to show you how to replace them. But I don't know you expertise.
Jan 13, 2018 | Sharp LL-172CB (Black) 17 in. Flat Panel...
TI-85 Display Has Missing Lines
have u ever modded it? it can (and probably will)damage the screen (graphics driver)
Oct 26, 2007 | Texas Instruments TI-85 Calculator
Moultrie GameSpy 4.0 Digital Camera Deluxe Logo
912 people viewed this question
Top Moultrie Cameras Experts
Steve
AZBen
AZBen
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
