Question about Campbell Hausfeld 5HP 20 Gallon Single Stage Cast Iron Air Compressor VS5006
AIR PRESSURE PROBLEM
I HAVE A 5 H.P. 20 GAL. RUNS FINE BUILDS PRESSURE TO 60 LBS. TOTAL NEVER GETS PAST THAT NEVER SHUTS OFF, I HAVE REPLACED THE CONTACTOR AND REGOLATOR STILL THE SAME ANY SUGGESTIONS, THIS IS A CAMPBELL HAUSFELD UNIT
    President:
  • Campbell Hau... Master
  • 1,388 Answers
The issue suggests that the head gasket is blown between the two cylinders or the reed valves are not seating or broken. The only other condition that would cause this is a leak. Here are a couple of simple tests. For leak spray soapy water on all connections and fittngs including the pressure regulator and the bottom of the pressure switch while unit is running. Repair as needed. If no leak is found, run compressor untill it reaches 60 or stops increasing and feel for suction at the air filter intake. The best way to check for suction is to remove the air filter and feel for suction at intake port-hole. The suction should be very strong. When valves are leaking it almost feels that the air is blowing out thru intake. If little or no suction, remove head and valveplate and replace parts as needed. Parts are available at www.chpower.com or www.toolpartsdirect.com. Good luck and post again if you have other question.
Posted on Jul 28, 2010
  • rush0011 Feb 03, 2013
    This is the most helpful answer I have read online. Thanks!
My four-year old PC pancake compressor starts fine but only builds up 60 psi no matter how I adjust the pressure regulator. The compressor motor runs continuously. I checked for air leaks and can't find...
First take off the head on the air pump and check the reed valves on the valve plate. If they got hot and warped or cracked they'll work to a point then no more pressure can be built up. Next check the pistion ring and cylinder wall. If either is damaged you'll only get so much pressure build-up then it will leak past the piston.
Mar 07, 2011 | Porter Cable C2002 150 Psi 6 Gal...
Compressor builds pressure to 60 lbs keeps running
Most of these are preset to turn off at 125 or 130. Does it go past 60?
Jan 27, 2011 | Craftsman 15 gal Air Compressor 3 hp UMC...
I have a bostitch 6 gal pancake compressor that won't build pressure past about 20 lbs. when I turn it off I don't hear air leaking out anywhere and when it's running it runs at a higher pitch ( similar to...
I'd pull the cover off to expose top of cylinder head and have a look at any intake air filter. In parts diagram, It appears there is a small one that would likely clog during the texturing process.
Jan 26, 2011 | Stanley Bostitch CAP2060P 105 Amp...
I have a sears craftsman air compressor. It runs fine until it builds gets up to the max air pressure. It shuts off then as it should but as I use it and the air drops and it tries to restart, it barley...
Something may be wrong with the 'unloader' function in the air pressure control--it should drain air pressure within the exhaust tube from the compressor. You may also be running the unit on too small wiring (extension cord) and it is starving for power when the heavy load restart occurs. Hope this helps!
Aug 16, 2010 | Garden
WILL NOT BUILD UP AIR PRESSURE PAST 20 LBS.
Check to see if air is leaking past 'pressure relief' valve. It's probably leaking and that's where all the air is going.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 11, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Tank will not build pressure beyond 25 lbs. Just runs
IS YOUR AIR FILTER CLOGGED. SOUNDS LIKE THE VALVES IN YOUR HEAD ARE NOT CLOSING ALL THE WAY. THEY ARE MOST LIKELY REED VALVES, THIN STRIPS OF METAL THAT OPEN AND CLOSE WHEN THE PISTON MOVES. MAKE SURE THEY ARE CLOSING ALL THE WAY (NOT CARBONED UP). DID YOU REMOVE THE HEAD AND DID YOU PUT BACK LIKE YOU FOUND IT - NOT TURNED OR FLIPPED OVER. SEE IF YOUR FINGER WILL GET SUCKED UP TO THE INTAKE HOLE.
Apr 12, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Campbell Hausfeld 5HP 20 Gallon Single Stage Cast Iron Air Compressor  VS5006 Logo
348 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
