Question about Jandy Aqualink Rs4 One Touch Control System Control System
Just started getting the 170 error code on my jandy aqua pure 1400 system. The pool level was high and forgot to turn to bottom suction. was set to top suction. would this have anything to do with the error
    Top Expert:
  • Jandy Master
  • 8,889 Answers
No sensor needs cleaning if still 170 replace sensor make sure cell is clean also
Posted on Jan 30, 2016
  • 22 Answers
SOURCE: jandy aqua link main control box
Do you have a 4 button switch in the spa and is the light on the button that is slightly under water? If so , the button is bad as the water is completing the circuit and turning the light on and off.
Repalce the button or disconnect it at the outdoor panel.
Posted on Dec 21, 2008
  • 22 Answers
SOURCE: Jandy, Lite 2 Pool heater wont kick in
3/4 pipe line will work and will keep heater from sooting up.
Posted on Feb 18, 2009
  • 10 Answers
SOURCE: Too much salt in pool (4,100)
the leslies employe is right the only way to get rid of the high salt level is to drain the water i would say drain a 3rd and fill pool and check salt level some salt genarators can not make chlorine at high salt levels or when the water is cold
Posted on May 19, 2009
  • 990 Answers
SOURCE: My aqua pure system control says "Aqua Pure General Fault"
Yes the build up between the plates of the sell let the electrions pass straight through the cell. They need to go through the water to get the chemical reaction.
Posted on May 28, 2010
SOURCE: Jandy Aqualink RS4 randomly turns on blower, pump, heater
I have has to deal with the same problem and have found that the spa switch is causing the problem. When I went into the lockout controls menu and locked out the spa switch I no longer had the problem. Once I figured this out and determined the spa switch was faulty I replaced the spa switch and everything is work correctly now.
Posted on Jul 08, 2010
Why does my Jandy Aqualink alarm keep beeping?
if it has a aqua pure and it isnt working turn chlorine production to 0 and then get it fixed
May 24, 2014 | Jandy Aqualink - Rs32 One Touch Pool / Spa...
I have a jandy pda and have no idea what the message that its displaying means. This is our first pool and the owners manual has not helped! It says aqua pure 100% salt 4500 ppm, check aqua pure high salt...
it is showing your status aqua pure is set at 100% salt is at 4500 parts per million which is too high to operate should be between 2700 and 3400 to work properly you need to drain some water out and add fresh to dilute the salt general fault is because salt level is too high it is showing your filter pump and extra aux is on go to the equipment on on main screen it will give you a list of all your equipment any questions send me more info
Sep 20, 2013 | Jandy Aqualink Pda Ps6 Wireless Handheld...
Fault comms eror what does this mean
if aqua pure salt system check sensor and salt level then cell
Jul 28, 2013 | Jandy Stealth 1.5 HP UR Pool Pump SHPM1.5...
Aqua rite rs4 error messages
if using aqua pure check sensor and cell
Nov 04, 2012 | Jandy Aqualink Rs4 One Touch Control...
Error code 172/186 on Jandy Aqua Pure 1400
bad or dirty salinity flow sensor
Aug 19, 2012 | Jandy Pool & Spa
Jandy PDA-PS4 lost link to salt system?? There is no more
go to system setup find aqua pure up setting from 0 to something and it will apear
May 27, 2012 | Jandy Aqualink Pda Ps4 Wireless Handheld...
Jandy Aqualink Rs4 One Touch Control System Control System Logo
1,496 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
jhalston
Level 1 Expert
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
