Question about Maytag Neptune MDG5500AW Gas Dryer
No heat I have no heat. The dryer tumbles and blows air - I just get no heat. I have replaced the igniter, hi-limit thermostat and the thermal fuse - but still no heat. Can anyone give me any hints ? (please)
  • 3 more comments
  • grind15 Apr 24, 2008
    the igniter lites and there is heat then it shuts down after maybe 30 seconds
  • koralewski Apr 25, 2008
    How can I tell if the flame sensor is open ?
    Please advise.
    thank you,
    How do I tell if the secondary coil is opening ? Is this something that can be fixed - or do I have to get a new secondary coil.
    Thanks ---
    Does the bottom front panel need to be on to make the ignitor work ? I replaced the door - but I still have the panel off so I can work on it. Is this "OK" ?
    Please advise.
    Thanks ---
  • Anonymous Apr 30, 2008
  • 145 Answers
Is the ignitor glowing? There is a flame sesor on the burner assembly if it is open you will not get any power to the ignitor to lite the gas.
Posted on Apr 24, 2008
  • James Davis Apr 25, 2008
    If the ignitor glows the flame sensor is mot open. There are two little blck coils on the gas valve right behind the ignitor. The primary coil lets in gas to start the flame then the secondary coil opens to keep the flame on. Sounds like the secondary coil is not opening.
    Sorry I didn't see that other comment wasn't from you. To check the flame sensor you need a volt/ohm meter. You can get them fairly cheap at radio shack or some hardware stores. To check it set the meter to ohms unplug the dryer and pull the two wires off the little box looking thing on the side of the burner. You shoud have continuity across the terminals where the wires plugged in.
Maytag Bravos XL Dryer not heating- blowing thermal fuse
The thermostat is controlling the temperature, however the Heating Coil may be defective. Check the COIL.
Feb 27, 2014 | Maytag MEDB950YW Electric Dryers
Non Glowing Igniter
What solenoids are you referring to?
When you set the timer and heat selector switches on your dryer and press the button [switch] to turn it on, the direction of 120VAC passes through the heat selector switch through the timer switch through the cycling thermostat through the hi-limit switch, through the thermal cut-off fuse to the burner assembly's gas valve.
Simultaneously, as the current is traveling through a path to the 1st gas valve coil, current is also traveling through a path to the flame sensor- and then to the igniter.
The igniter will begin to glow and when it gets hot enough, the flame sensor will detect the heat and switch off. which then diverts current to the second gas valve coils.
The second gas valve coils activate plungers in the gas valve which allows gas to flow out into the burner housing. The igniter still being hot, ignites the gas to a long blue flame.
To maintain the proper air temperature, the heat in the blower housing is monitored by the cycling thermostat. During normal operation, air temperature should be between 120 degrees Fahrenheit and 160 degrees Fahrenheit.
When the air reaches the proper temperature specific to your dryer model, the cycling thermostat will switch off the voltage to the burner assembly.
The hi-limit thermostat and thermal cut-off fuse monitor the drum air temperature. If there is an air flow problem [restriction or total blockage], the hi-limit thermostat may switch off the voltage to prevent damage to the dryer.
Eventually, if the air flow problem [restriction or total blockage] is not corrected, the thermal cut-off fuse will fail (blow) and the dryer won't heat at all.
Check continuity to the following components, thermal cut-off fuse, hi-limit thermostat, igniter, flame sensor, and cycling thermostat. Of course you will take your readings with the power cord of the dryer unplugged from the wall outlet.
You will either disconnect [isolate] any of the wire leads going to their respective components during the test [using a multimeter (analog or digital)]; OR remove each of the components entirely from the dryer to test them.
1.) A good thermal cut-off fuse will have 0 Ohms of resistance. On the other hand, if the needle [on a an analog tester] does not move OR the digital display [on a digital meter] has not changed significantly, there is NO continuity - which means the fuse has burned out and needs to be replaced
2.) A dryer's Hi-Limit Thermostat is activated by hi-temperature changes (between 250 degrees Fahrenheit and 300 degrees Fahrenheit.
A good hi-limit thermostat will have 0 Ohms of resistance at room temperature.
To test the thermostat's response to temperature change, place the component on an electric griddle or skillet. Set the heat on the skillet or griddle to the appropriate temperature according to the temperature rating stamped on the hi-limit thermostat you are testing. If the hi-limit thermostat switches off within 5% of that temperature, the part is functioning properly. However, if the hi-limit thermostat does not switch off OR switches off prematurely, the hi-limit thermostat is faulty and will have to be replaced. [Remember, when the switch turns off at the appropriate temperature level- you should get a high resistance reading to show that the circuit is "open")
3.) Perform the same procedure as step 2 to test the Cycling Thermostat: First at room temperature and then its response to temperature change. The only difference is, the test temperature range will be somewhere between 120-160 degrees Fahrenheit Once again, refer to the temperature rating stamped on the component you are testing- and the 5% tolerance remains the same, too.
4.) The resistance reading for the igniter is between 50 and 400 Ohms of resistance; anything else, it's faulty- toss it and replace it.
5.) You should get a resistance reading of 0 Ohms at the flame sensor-
Flame sensors are tricky though. Flame sensors could still short out and
allow the igniter to glow- but would prevent voltage from reaching the gas coil. For example, the igniter will glow and not turn off and a flame will not be established because there was no voltage at the gas coil to open up and release gas for ignition.
Hope this info helps...I would appreciate a follow-up from you when you resolve this problem- to gain more knowledge and skill.
Thank-you and best wishes on your project
Jul 15, 2013 | Whirlpool LGR3624JQ Gas Dryer
No heat from tumble dryer
If dryer is electric check for lint obstructions, check ventilation, test thermal fuse, thermistor, cycling thermostat and high limit, element and fan.
If dryer is gas check for lint obstructions, check ventilation, test thermal fuse, thermistor, cycling thermostat and high limit, igniter, coils, burner, flame sensor and fan.
Dec 14, 2011 | Washing Machines
Does the Kenmore Series 700 dryer use circuit breakers or a thermal fuse to shutoff the heating element?
All Kenmore Electric Dryers use a thermal cut-off or thermal cut-out, hi-limit thermostat, and a cycling thermostat apart from the motor centrifugal switch as parts of the heating circuit. The thermal cut-off/thermal cut-out and the hi-limit thermostat are located on the heater duct/element duct while the cycling thermostat is located on the blower housing.
The thermal cut-off/cut-out serves as a safety measure and blows open should the dryer overheats or should the hi-limit thermostat fails to cut off power to the heating element. Check the continuity of the thermal cut-off/cut-out and if open, replace it including the hi-limit thermostat.
Aug 22, 2011 | Dryers
I have a Kenmore Series 70 Dryer and I changed the thermal fuse got hot for a few minutes the model #110.74722400
The cycling thermostat must also be replaced when replacing the thermal fuse. The cycling thermostat's failure to cycle off the heating element results in overheating of the dryer which consequently blows the thermal fuse open.
Replacing only the thermal fuse should the dryer stops running and fails to start will result in its premature blowing or even the thermal cut-out (cut-off) located on the heater duct. Like the cycling thermostat, the high-limit thermostat must also be replaced once the thermal cut-out blows open. Refer to the parts diagram in the link below and look for item numbers 31(thermal cut-off), 34(hi-limit thermostat), 39(thermal fuse), and 41(cycling thermostat.
Kenmore Series 70 Electric Dryer (110.74722400) Bulkhead Parts
Aug 21, 2011 | Dryers
Dryer had built up lint,blew fuse,now will blow fuse after cleaning and replacing vent hose
if its heated electrically, not by gas,then it sounds like the heating element has shorted to the case and this would blow the breaker
Jul 28, 2010 | Amana NDE2335AY Electric Dryer
No heat from my tumble dryer
There should be 2 limits mounted above the heating element on back along with a limit mounted on the heating element. I have some repair video: HERE
Feb 16, 2010 | Zanussi TC7102W Electric Dryer
No heat,tumbles,but no heat. good cont. thru thermal fuse,no cont. thru thermostat internal bias? think that is my problem? Any thing else I should check? I get good cont. thru heat coil also. thanks mike
If the dryer runs, but does not heat, you need to check the Thermal Cut-out and Hi-limit thermostat. The following link explains:
The TCO and Hi-Limit Thermostat are mounted on the heater box near the heating element. Read through the info I provided and double check the continuity of these components. If either the TCO, or Hi-Limit thermostat are bad, replace them BOTH at the same time. Failure to do so may result in premature failure of any replaced components. They are commonly sold as a set.
NOTE: The Thermal Fuse and Internal Bias Thermostat are located on the air blower housing. If the Thermal Fuse were bad, the dryer would not run at all. The Internal Bias thermostat may still cause heating problems, but is less likely. Replace it if you like, but I think you may have a TCO that has failed.
If there has been a failure of the heating circuits, I would recommend you do a thorough cleaning of the dryer exhaust ventilation ducting to ensure you have no clogs. Poor air flow is the number one cause of dryer failures.
If you have questions, please let me know. I hope this helps you.
May 05, 2009 | Kenmore Dryers
Maytag MDG5500 - heat goes off after several minutes
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Thermal fuse location
the thermal is on the heater box on the right side it has two white wires going to it
you need to remove the high limit stat and bracket and the heating element to get to the safety stat
Jun 13, 2008 | Crosley CDE6000 Electric Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
216 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
