Question about Sharp AR-M355N Copier
How to reset the key operator code on a sharp ar-m355n
mickspaceNET
  • 115 Answers
SOURCE: Lost key operator code for Sharp Copier AR-M207.
The default is 00000
Simulation 22 - 07 will display the Key operator code.
Perform the following procedure to enter the simulation mode.
"#" key -> “*“ (star) key -> "C" key -> “*“ (star) key (do this in quick sequence order, the display should change, then enter below)
Main code {22} ->
(Green Copy Button) Start key ->
Sub code {07} ->
(Green Copy Button)Start key
Press the "CA" button to go back to Copy mode.
Posted on Feb 06, 2009
SOURCE: how to fax?
You access the fax functions (if optional kit is installed) by way of the Image Send button on your panel. Press Image Send, then press the FAX key on the screen. dial as you would any fax when the number is dialed and the document is in the feeder, press the start (copy) button and you are faxing...
Les Olson Company, Sharps #1 ind. Dealer in the USA. Selling Sharp in Utah and Las Vegas with 7 locations to serve you.
Posted on Feb 09, 2009
007tech
  • 95 Answers
SOURCE: need to reset key operator code on Sharp AR-287
Make sure the copier is in "copy" mode.
To get into service mode press the following keys one after the other "P" key - "interupt" key - "clear" key - "interupt" key (do not play around with setting in service mode as this can render your copier useless)
enter 22 and press "start" enter "7" and press start. This should display the admin code.
Restart the copier and you should be good to go.
Posted on Mar 26, 2009
rezazadeh
  • 328 Answers
SOURCE: I have an Sharp AR-235 and the key operatorcode is lost
enter command 22-13 and see operator code
Posted on May 27, 2010
  • 4 Answers
SOURCE: I have a sharp AR-M355N
This code is Toner Control Sensor open/trouble.
Check connection of the toner control sensor.
Check connection of connector and harness to the main PWB.
Check for disconnection of harness.
If all is fine, replace the sensor.
Posted on Nov 11, 2010
Sharp copier USB connection not recognized
WHAT OS U USE?
TRY THIS LINKS......
http://www.solvusoft.com/en/update/drivers/copier/sharp/ar-m355n/sub-models/
http://iprinterdrivers.info/download-driver-for-sharp-ar-m355n-printer.html
http://www.sharp-world.com/products/copier/downloads/index.html
AND ALWAYS U CAN GO FROM -CONTROL PANEL- TO -DEVISE MANAGER- AND FROM THERE U SEE THE PRINTER DOUBLE CLIK ON IT AND U SEE INFO OF DEVISE(PRINTER) LIKE DEV ID (DEVISE ID) COPY THE ID AND GO THERE
https://devid.info/ AND JUST PASTE AND FOUND THE DRIVERS
Oct 13, 2017 | Sharp Ar-m355n Copier Printer Scanner Fax...
Sharp m355n error L3-00
Sharp m355n error code L3 00
Strange that you have placed the same question that was apparently placed in 2014. Solution provided at that time was:
"L3-00 means that the scanner (the light under the glass) isnt moving correctly. You can reset it by pressing clear, interupt,0, interupt, 14,1, start button. Good luck"
Feb 16, 2018 | Sharp AR-M355N Grayscale Copier
Sharp m355n error code L3-00
Jan 23, 2014 | Sharp AR-M355N Grayscale Copier
I have a sharp AR-M355N machine and I keep getting error code F2-00, what does this mean, is there a specific fix for it
Nov 09, 2010 | Sharp AR-M355N Copier
I have a AR M355N and it gives me "finisher out of service." Do I need all the trays installed to clear this?
Maybe? Most likely the problem could be with the stapler unit not finding HP. Did you have a error code before the finsher could not be used?
May 27, 2010 | Sharp AR-M355N Copier
H5-01 error
Make sure that there isn't any paper jammed behind the left door in the (hot) fuser rollers. press keys P, *, C, * enter simulation number 14 press key as if making copy. on LCD execute and clear all to exit. if code returns call a sharp technician.
Nov 12, 2009 | Sharp AR-M355N Copier
How to fax?
Feb 03, 2009 | Sharp AR-M355N Copier
Main code {22} ->
Sub code {07} ->
Jan 24, 2009 | Sharp AR-M237 Copier
Sharp AR-M355N Copier Logo
693 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
