FixYa.com
Tags:
NEC ND-2500A DVD±RW Burner
NEC DVD_RW ND-2500A will only read and burn DVD's,...
posted by cdela68 on Apr 24, 2008
my NEC DVD_RW ND-2500A will only read dvd's or burn dvd's. it wont reconize that there is a blank cd or audio cd in the writer or any cd if that matters. so in short i cannot play or burn cd's.
I have tried reinstalling the firmware and cleaning the plate with rubbing alcohol. does anyone know what else I can try please.
Comment by cdela68, posted on Apr 26, 2008
thanks, I downloaded the new firmware and restarted the computer, still same problem. I have also contacted the nec people as well. if you have any other suggestions I would appreciate them. regards
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Apr 25, 2008
Thanks for Trying (70)
mangoeater2
Rank:Guru Guru
Rating: 86%, 92 votes
You could try updating the Driver.
The driver and instructions can be found here:
http://www.opendrivers.com/driver/214402/nec-nd-2500a-dvd+rw-firmware-1.06-free-download.html
Have you contacted the manufacturers site and a)checked out their FAQ's and in the last resort Contacted their Support for help?
Rating Locked! (?) cdela68 has rated this solution as Thanks for Trying
Can you Help with these CD and DVD Burners problems?
CD and DVD Burners
audio cd branden
steeds insert a disc in ook al... Answer This...
CD and DVD Burners
JVC DR-MV7SU Timer...
I am trying to set up timer... Answer This...
CD and DVD Burners
registering
I had made a purchase back in... Answer This...
CD and DVD Burners
dvd burner question
I only have one slot for a... Answer This...
NEC DVD_RW ND-2500A will only...
my NEC DVD±RW ND-2500A... Answer This...
Repair Service
Find CD and DVD Burner Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
