Question about Maytag MSD2756G Side by Side Refrigerator
My Maytag MSD2756GES freezer coil is completely iced over and fridge is not cooling. I think the defrost element is not working. Need a part #.
    President:
  • 1,099 Answers
Defrost problems can cause the fresh food section not to work. You need to find out why it’s not defrosting. There are three things that cause a defrost problem: defrost heater, defrost thermostat and defrost control.
If you have an older refrigerator, it probably has a mechanical defrost control. Find it and turn it clockwise until the refrigerator cuts off. (Note that the defrost control is normally located either in the refrigerator near the cold control or at bottom behind the kick plate). If your refrigerator is newer it will have an electronic defrost control and you won’t be able to turn to defrost so just continue without doing so. Now that it’s in defrost, wait a few minutes. If the defrost heater gets hot, replace defrost control. If it doesn’t get hot, then the problem is either the heater or the thermostat.
At this point, you need to melt the ice. The best way to melt the ice is to use either a hair dryer or by using hot water (this will be faster but will make a mess).
Once the ice is gone, you can check the heater by unplugging wires and using an ohmmeter to check for continuity. If you have continuity, the heater is good and you should replace thermostat. If you don’t replace the heater, at this point you won't be able to check the thermostat but if the heater is good replace it. Defrost parts can be found at AppliancePartsPros.com
If you have a GE refrigerator made after the year 2000, do not replace the defrost thermostat. Trust me the thermostat is not your problem. 99.9% of the time it will be the heater. Sometimes it is the main board or the thermistor.
Also note that
It's possible that the defrost terminator is bad.
If it doesn't have an electronic adaptive defrost control, then the mechanical defrost control is bad.
In the future, avoid ALL appliances that use electronics. They fail very very regularly and are expensive to replace.
Just think if you had a fridge with a TV in it, and the tv went out. Who would you call? A TV repairman or an appliance repairman?
Buy a Whirlpool refrigerator with the least amount of electronics you can get.
Also, there is a door switch that goes to the freezer section. It controls the light and the adaptive defrost. If the switch is bad, that too can cause the problem.
Lastly, do not buy anything made by electrolux corporation (frigidaire is one of them for example).
They have cheap evaporators that leak and can't be fixed, thus causing you to buy a new fridge every year or so.
Hope this helps your problem......
Posted on Jul 28, 2010
Hi, I have a Fisher and Paykel E402B Fridge/Freezer. It has not been working properly for a couple of months.. It does not cool/freeze properly. Through investigation I discovered that the coils and fan...
the defrost heater or thermostat located on the evaporator coil thats icing up isnt defrosting due to a bad heater or thermostat,or it can be the defrost timer that powers these other 2 parts
Jun 21, 2011 | Fisher and Paykel Refrigerators
Water is accumulating & freezing @ bottom of freezer ice maker has been removed water to fridge has been turned off still, water coming from somewhere & freezing
This is what it sounds like to me. There is a drain hole for the defrost water to drain down to the "drip pan" If that hole in the drain pan is clogged. Then when the defrost system melts away the frost in the cooling coils. Every 6 or 8 hours. The water will accumulate in the bottom of the freezer compartment and turn into ice. This is a very common problem.
The solution.
Put the food in the freezer and fridge into coolers and pack with Ice. Get the 99 cent coolers at the supermarket and buy some Ice there too.
Shut the fridge down and open the freezer door. chop out the Ice in the bottom of the freezer compartment, but not in the drain area directly below the coils. that will be hard to get to and you may damage the fridge if you just chop away.
To speed up the process, get some hot water in a glass and pour it into the area below the coils
(that should be a solid block of Ice as well). If you cant get to this easily, just wait for the fridge to thaw out naturally.
After it has thawed out, you should be able to locate the drain tube in the bottom of the small tray
below the coils. Stick a flexible piece of wire, or pipe cleaner or something of the sort into it to completely unclog it. So when you pour water into that tray, it immediately drains out completely.
into the "drain pan" located below the freezer compartment in the base of the fridge.
I hope this helps,
Best Regards,
Mark
Dec 30, 2010 | Maytag MSD2756GES Side by Side...
Changed filter and now it is not making ice water out of refergerator is not very cold
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 10, 2010 | Maytag MSD2756GES Side by Side...
I have a maytag side by side with water/icemaker. model msd2456dew. it has frozen up in the freezer, under the white interior paneling. we think this is what is causing the cool air to not filter into...
Checking defrost components on Maytag SideXSide refrigerators
To check the defrost circuit , unplug the refrig and inside the refrig section at the top about 2" in from each side in the back , there are "D" slots to put a finger in , and pull downward and foreward , to remove the control panel cover . Once removed , there is a 1/4" screw on each side holding the adjustment indicator panel on , 1 phillips screw behind both light bulbs , and 1 screw holding the complete panel to the rear wall . After removing these 5 screws , at the top right corner , with about 6-8 wires going to it , is the adaptive defrost board . Sometimes you can see the electronic board and on newer refrig's , a white box will be seen. Inside this box , is the adaptive defrost control . Disconnect the plug going to the board and on the right side of the PLUG , the far right wire is yellow , then another color , then white . Useing a small insulated wire with both ends stripped , insert one end into the yellow wire hole and the other into the white wire hole . This will bypass the adaptive board and send power directly thru the defrost bimetal ( thermostat ) AND heater to check if they are good .Plug the refrig back in . Now , wait about 3-5 min and look for a red glow at the bottom of the inside freezer panel , which will be the defrost heater or listen for sizzling which will be the frost melting and dripping onto the heater .If NO red glow , watch for a spark while removing the jumper wire you installed , from the plug . If a spark IS seen , then the heater was on and the heater AND bimetal are good . If you see the red glow , hear the sizzling , or see the spark , then the adaptive defrost board should be replaced . If no glow , sizzling or spark , then unplug the refrig and reinstall the refrig control section .
Remove the food in the freezer section enough so that the 2 screws holding the lower freezer panel on and the freezer panel , can be removed . Remove the panel . If the heater (black element at the bottom of the coils ) wires are visible , trace then to the top of the coils and disconnect . Use an ohm meter to determine if the element is good . If the element IS good , at the top of the coils , is a 1" cylinder with 2 wires , clipped onto the coils . This is the defrost thermostat ( bimetal ) . Replace this part if the element shows good . If the element shows bad , replace the element . NOTE 1 : sometimes the element and the bimetal come wired togather and the replacement part comes with a new heater and bimetal already wired togather . This would be the adviseable replacement part . However , each part can still be replaced individually . NOTE 2 : If looking at the bimetal and the top plastic " cap " looks cockeyed , replace the bimetal as moisture has gotten inside and disturbed its designed function .
Jul 28, 2010 | Refrigerators
Fridge stopped working/ freezer still works great?
the freezer works ok..this is where the cooling unit is..so, if the freezer works ..its not blowing or allowing air to flow into fresh food area..if its missed its defrost..it will not allow air to go into fresh food area and you need to remove panel and defrost coils ..or see if blower is working...check for bad heater or defrost thermostat or what controls defrost ie timer or board
May 20, 2010 | Maytag MSD2756G Side by Side Refrigerator
Refrigerator not cooling-Freezer Coils Freeze Up & Don't Defrost
check the fan assembly theres not enough air flow going over the coils
Feb 11, 2010 | Maytag MBB2254G Bottom Freezer...
GE Profile - fridge not cooling
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 17, 2009 | Refrigerators
Back wall of larder freezer icing up - fridgeidare RL 6003 B
located behind the freezer back panel.
The defrost system (AKA evap. system) is composed by an heating coil, a fan , and a defrost thermostat, and its function is avoiding ice formation on coil.
When defrost system is defective the fridge wont cool down properly
In your fridge , either evaporator fan, thermostat or heating element is faulty, and the ice on coils is preventing the appliance from cooling down properly.
Try first a complete defrost, leaving the unit unplugged overnight, if this does not fix the problem, then there is a fault.
Jan 20, 2009 | Frigidaire FRS23F4C Side by Side...
Maytag
Heres you problem your drain plug in freezer is likely frozen as well and water is running under fridge. You have to replace the thermostat defroster assembly Its behind the panel at rear of freezer and runs down and under condenser coils. Part cost $42 and plugs in its easy to replace It creates heat which keeps the coils free of ice and also keeps drain from freezing.
Jun 19, 2008 | Maytag MSD2756GES Side by Side...
Maytag MSD2756G Side by Side Refrigerator Logo
517 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
