Question about RCA OPAL M4001 MP3 Player
RCA OPAL M4002A headphone jack problems
When I plug my headphones in I can hear the music but its just the music and not the words!!If I push the headphone plug in piece to the front or bac it plays fine, so I know its a problem with the jack.How can I get it fixed?
  • Anonymous Jun 15, 2008
    my earphone jack got shreeded
  • Anonymous Jul 17, 2008
    in order to hear out of both headphones
    i have to pull it out a little
    if i put it in all the way only one works
SOURCE: Headphone jack
I had to take mine apart and re-solder the headphone jack. It was amazingly easy, but if you don't do electronics repairs, I would suggest getting help. Everything is very tiny! This type of head phone jack is modular and soldered directly to the tiny internal circuit board. It is poorly anchored by the outside of the case where you plug into it, so most of the stress of pluggin and unplugging the headphones is put directly on the three tiny little solder joints. This causes one (or more) of them to break eventually. Mine lasted only about two months. And, I was carefull very gentle with it! This will cause one side or the other, or both speakers to lose their signal so that only one side works or worse, niether side works anymore. Consequently, I don't unplug mine anymore. If it breaks again, I may try to fix it. It only takes a few minutes. But, I'm hoping I don't ever get to that point.
Posted on Oct 05, 2007
  • 9 Answers
SOURCE: RCA OPAL M4002A Video Problem
You need the specific video converter software from RCA that comes on the CD included with the Opal.  If you don't have that, post here and I'll try to upload the image somewhere as an .iso file.  This is necessary to get the video into the final format the Opal can use.  As far as I know, other video convertors won't format the file properly.
Posted on Dec 31, 2007
SOURCE: How to open up a Sansa C140?
I too had a problem with the headphone jack. It took me a while, and a few scratches on my Sansa C140 case, but I FINALLY figured out how to seperate the case.
1) POP the black top (with the buttons and display cover) off. Get under the edge and pry, working your way around. It's just snapped on.
2) With that cover off, you will see four (4) screws, one on each corner. Remove these. The BOTTOM will now come off (may require a little wiggling to slip the battery terminals out of their grooves).
3) You should now be left with the main board contained within the middle of the plastic case. Removing the board is a CHALLENGE as it is held (not tightly) by a couple of tabs, as well as the headphone jack and the connection port.
Be careful when working to get the board free. I ended up popping two of the solder-tabs off the board for the headphone jack when "prying" the board out of the case. Luckily I was able to fix it when re-soldering the jack to the board. And one of these may have already bad (requiring the repair in the first place).
Reverse the steps to put it back together, again being careful when re-inserting the board back into the casing.
Good luck. Hope this answer still find you in time...
Posted on Jan 25, 2008
SOURCE: keys locked on a M4002A RCA opal
it worked for me! thanks big time!
Posted on May 29, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: what song service supports rca opal m4002a mp3 player. napster doesn't work?
Not iTunes. Not Napster.
You could try Rhapsody's MP3 ONLY service - new!
Limewire works, but make sure you anti-virus program is up-to-date.
The key is to use Mp3 format only, and most music services have switched to WMA format.
Posted on Jul 06, 2008
Sennheiser RS 120 headphones won't work, only hear static
Adjust the tuning wheel on the side of the headphones so it picks it up.
Mar 20, 2014 | Sennheiser RS 120 Consumer Headphones
I can't hear any sound on my verizon wireless razzle phone. It just stopped working after i plugged in headphones what is wrong with my phone?
I had this very same thing happen to me yesterday after listening to music with my headphones. After unplugging them, the speaker would no longer work nor the speakerphone.
After trying many things without success, I was finally able to resolve this by plugging back in the headphone cable and pushing the jack around a little bit to the side until I could hear sound.
I did this while trying to place an MP3 just to make it easier. So far this has worked fine. But now I am reluctant to use the headphones any more.
I know your post was several months ago so this may or may not be helpful.
Oct 27, 2009 | Cell Phones
I cant hear my music
it's usually the first contact (ground) of the headphone jack module that loses it's elasticity and does no longer touch the headphone plug properly. you can try to pull it back inward from the outside using a dentist tool or a sewing needle. if that fails you have to open the ipod touch and push the contact inward or replace the jack module.
Jun 15, 2009 | Apple iPod touch
My lg dare has no audio i cant hear or be heard, I cant even hear the dial tone, how can i fix it? I am having the same problem with my dare. I tried plugging in headphones but it didnt help. I can hear...
You probably plugged a headset that does not have a mic. after you unplug it your phone will think that the head set is still plugged in. these phones are stupid and after you unplug the headset it will still be looking for the mic. Plug in and out the headset rapidly and then your phone will give you a notice saying that there is no mic to the headset. this will fix your problem. P.S. keep insisting, this fixed my problem
May 28, 2009 | LG Dare VX9700 Cell Phone
No voices come out, sound is good, with headphones and speakers
This sounds like a problem with your connection for your headphones. Your headphone jack on your notebook is stereo, which means that you need stereo headphones to make it work. If you look at the tip of your plug on your headphone cord, it will have 1 black ring, or 2 black rings. 1 black ring is mono, 2 black rings is stereo.
If you are using stereo headphones, and you're still having this problem, your headphone plug is not going all the way into the jack on your notebook. Press the plug all the way into the jack and the problem should be fixed.
If you physically cannot push the plug all the way into the jack, there may be a problem with the jack on your notebook that will need to be looked at.
Hope this helps. Please take a moment to rate this solution. Thanks.
Mar 15, 2009 | Compaq Computers & Internet
Audio from tv is not restored by turning off power on headphones
It sounds as if you are plugging the base into a standard headphone jack located on the Television set.
RCA Headphone jacks (incl mini) automatically stop the sound output to the main speakers on almost every set I have seen.. or home stereo.. etc etc
In other words you can take a standard RCA jack.. with nothing connected to it.. plug it in while the music or sound is coming out the main speaker.. and it will cut off the output to those speakers..
If you set has audio outputs on the back.. preferably Fixed Audio Out .. you will need to connect your base unit to those.. turn your set volume to 0 and adjust the headset volume using the control on the right ear-cup.
If you have variable audio out.. you will need to go into your TV sets setup menu.. turn off the speaker.. and turn up the set until you achieve a signal and decent volume through the headset.
If you are missing these connections.. your current “work around” is your only solution.
Best of luck
Dec 31, 2008 | Sennheiser RS 120 Consumer Headphones
Repairing RCA Opal M4002 player?
I had the same problem. my m4002a wouldn't charge or anything. So I decided to take it apart to see what I could see. There are four solder points on the headphone/charge jack that are soldered to the ic main board. Two of my solder points were cracked, so I just melted the solder and bingo it works fine now. I added a bit of highstrength hot glue to the port so it wouldn't move anymore. That seems to have done the trick. I am guessing by maneuvering your headphone jack you are actually causing the solder points to make contact with the ic board. Of course you may not have the exact problem I had but it could be worth a shot.
Nov 03, 2008 | RCA M4002 Digital Media Player
What song service supports rca opal m4002a mp3 player. napster doesn't work?
Jul 05, 2008 | RCA OPAL M4001 MP3 Player
RCA OpAL MP3 player
My son had a similar issue with his. It turned out that he had damaged the headphone/charger/download/upload jack. There was no way to easily fix it, but we were able to return it to Wal-mart for another one. Why they decided to use this jack for so many different functions, I have yet to figure out. It's really a poor design for an otherwise nice mp3 player. If you can't take it back where you bought it, you are pretty much out of luck, unless you're handy enough to take the player apart and replace the jack. Sorry.
Apr 24, 2008 | RCA OPAL M4001 MP3 Player
Headphone prob
hmm...alright then.
1. Check the volume (but I expect you've probably done this)
2. Instead of putting mp4 or m4a on the computer try to put mp3 or wma on the player
3. Does the USB work too? The usb is also out of the headphone jack. If there's problems with that, then there's problems with the jack
4. Have you been pulling hard on the USB to take it out of the jack? If so the headphone jack part of the jack may have gotten a bit loose.
5. Call RCA. Chances are the person you get is from India. Talk slowly and tell them your problem.
Dec 13, 2007 | RCA OPAL M4001 MP3 Player
RCA OPAL M4001 MP3 Player Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
