Question about Dishwashers
MDB5600AWB dishwasher after the cycle has completed some water remains in the bottom of the tub.
    President:
  • 2,468 Answers
Either the check valve located in the lower sump is plugged or not closing fully and letting waste water back in,or the sump is plugged with waste food,or the drain line to the sink is partially plugged
Posted on Jul 28, 2010
Why will my dishwasher Electrolux model #EIDW5905JS0A, not drain completely at the end of its cycle.
Good Morning Friend,
I understand your Electrolux dishwasher, model# EIDW5905JS, will not completely drain at the end of the cycle. It is not normal for water to remain in the bottom of the tub at the end of a cycle. If water remains in the bottom of the tub at the end of a cycle, the dishwasher may not be draining properly. Please follow these troubleshooting tips:
    1)If unit is hooked up to a garbage disposal, make sure the disposer is empty.
    2)If unit is hooked up to a new food waste disposer, check to see if the "knockout" plug located inside the disposal inlet has been removed.
    3)Check to see if drain hose is kinked.
    4)Make sure cycle is complete, not in a pause.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
    -Best Regards-
    WP
Jul 03, 2014 | Electrolux EIDW5905JS Dishwasher
Why does my dishwasher not drain completely at the end of its cycle.
    -Best Regards-
    WP
Dirty water standing in the bottom of the tub
There is probably some debris that is blocking the water from getting to the pump.For More information please visit Kenmore Parts.
Oct 04, 2012 | GE Nautilus 24" Built-in Dishwasher
Asko dishwasher did not finish complete washing cycle and now has a very low humming sound. It will not start washing cycle. I have turned it on and off but after I turn it back on humming sound...
Some wash water may have gotten into the bottom pan area below the wash tub. If water has overflowed from the tub into the bottom pan, the drain pump will activate and remain active until water has been removed from the bottom pan. To check for this, the lower front panels will need to be removed. With power turned off at the breaker, a wet-vac can be used to remove water from the bottom pan. If there was water there, check the door seals, door closure and make sure the drain hose has a high-drain loop. If the drain is shared with the kitchen sink, it may simply have backed up into the dishwasher through the drain hose when a full sink was emptied. The best drain system is for the dishwasher to have its own separate drain.
Jun 29, 2011 | Asko Dishwashers
No water going into dishwasher checked supply line its good Frigidaire model fdb635rfr6
Just had a similar problem with my Frigidaire FDB834RFS0 model. Dishes were not getting clean. Noticed some detergent still remaining in the dispenser after completing a wash cycle. Checked the water level during several cycles and noticed it was barely visible in the bottom of the tub. Decided to remove the water supply valve and solenoid to check it, thinking I would probably have to buy another one. Took it apart and found there is a mesh water strainer on the inlet side that was full of bits of junk. Cleaned it out and decided to reinstall to see if it made a difference. Noticed immediately when starting the next cycle that I could hear the water gushing into the tub. The water level rose significantly and the result was clean dishes and no left over detergent in the dispenser.
Jul 31, 2010 | Frigidaire Dishwashers
Water left in bottom of dishwasher after cycle
a little water is supposed to remain in bottom so that pump will not lose prime
Nov 07, 2009 | Dishwashers
Some water stays in dishwasher (beau mark portable dishwasher
The manual says that's normal: "A small amount of clean water around the outlet on the tub bottom at the back of the tub keeps the water seal lubricated."
Dec 14, 2008 | Dishwashers
Not draining
Are you sure your drain system is not clogged or restricting water flow ? When you say youtook off the hose off under the sink and it seemed to be lots of water running on the rise cycle .. that suggests that you may have a restriction after the drain hose in your house drain system. ...
Some other considerations..
To minimize the possibility of electric shock, unplug this appliance from the power supply before attempting any maintenance.
  • Some water, usually one to two cups, remaining in the bottom of the tub is normal. However, if water is covering the bottom of the tub, the dishwasher is not draining properly.
  • Check for paper or large objects covering or blocking the sump area in the rear of the tub.
  • Make sure that the right type and amount of detergent is used: Using the wrong type or too much detergent can cause sudsing that can prevent the dishwasher from draining. Only detergent specifically designed for automatic dishwashers such as Electrasol®, Cascade® or Cascade Complete® should be used
Hope this helps you...
Sep 03, 2008 | Dishwashers
Water will not drain out of the tub all the way and behind the front door bottom in the insulation seems to be wet. and the cycle seems to take a long time to run...thanks
My dishwasher, Bosch Model No. SHU9922UC/U12, Serial No. 10 0202 80447 01 0040 goes through its wash, rinse and dry cycles but sometimes there is some water remaining on the items in the upper tray and one inch or so of water remaining in the bottom of the tub. Once water leaked out onto my kitchen floor. I found some broken glass and some plastic in the circular trap at the bottom and have removed the detritus.
Jul 29, 2008 | Dishwashers
Dishwashers Logo
126 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
