Question about Microsoft Windows XP Professional
When i open a window it is very heavy - Microsoft Windows XP Professional
  • 415 Answers
Try using a lighter antivirus if you have one,
check msconfig through the run dialog to see what apps are running,
increase the amount of ram you have,
let me know,
Posted on Jul 28, 2010
Testimonial: "thank you sir"
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 73 Answers
Did you unhook it from it's hinges?
Posted on Jul 31, 2010
I shut the door with key in lock and batteries are dead now it wont open
Pry the upper back edge of the window out and wedge it open with a plastic or rubber door stop. Tape a heavy wire coat hanger (bent to an 'L' shape) to a 1/4'' wooden dowel, insert that assembly into the opening created by prying the window out, and use it to push or pull the manual lock button so the 'red' is showing. Use the outside handle to open the door.
Mar 02, 2015 | Computers & Internet
Batteries are dead. key is in lock still wont open
Rear Door With Window Bottom Will Not Open Window Opens Fine
have to know what u r talking about , car, truck ,heavy equipment or a toy
Jan 09, 2015 | Ford Cars & Trucks
How do i adjust the sensitivity of my touch pad for my Toshiba laptop PSLB8U-05202F
1.Turn on the computer and log into Windows as normal. Open the "Start" menu and click on the option labeled "Control Panel."
2.Double-click on the icon labeled "Mouse.". The "Mouse Properties" window will open. Navigate to the tab labeled "Device Settings." Click on the button labeled "Settings." A window labeled "Properties" will appear.
3.Examine the left panel of the "Properties" window and expand the option labeled "Sensitivity." Click on the option labeled "Touch Sensitivity."
4.Reduce the touch sensitivity setting by moving the slider to the right, towards the "Heavy Touch" label. Experiment with different levels of sensitivity until you find one suited to your needs.
5.Click on the button labeled "OK" to close the "Properties" window; repeat with the "Mouse" control panel. Your new touchpad sensitivity settings are now saved.
Sep 14, 2011 | Toshiba Satellite L305-S5908 Notebook
When I close the door on my e36 325i convertable the window won't go up, it normaly drops on opening of the door and goes up on closing but non of this is happening help really appreciated thanks
You have a problem in the window regulator assembly.
Go to a nearest garage and have check the window regulator, sounds like the gear mechanism have been nicked and releasing the window in heavy vibration.
Hope that helps!
Sep 14, 2011 | 2001 BMW 325
I want to exhaust a portable A/C out of a 2'w X 6'h, crank open window. Obviously, with no sliding window, the slider system won't apply. So, what are common solutions for venting out crank...
I use a 1" metal strap that is heavy enough to support the unit to the window frame, then I cut plexiglass to fill in the opening. I typically drill small holes to attach the metal strap. Remember that it is very important that the unit slope downwards towards outside for the condensation to run OUT.
Jul 22, 2011 | Frigidaire Heating & Cooling
My scenic w600 i865g have worked just fine until I moved the computer to another place in the room, the computer shuts down when windows are loading it's the same when loading unix that is on a...
If the problem disappears when you move the computer back to the previous location, it's most likely something in the new location that is causing the problem. Could be a bad power outlet or some heavy duty electrical interference.
  • Open in Google Docs Viewer
  • Open link in new tab
  • Open link in new window
  • Open link in new incognito window
  • Download file
  • Copy link address
  • Edit PDF File on PDFescape.com
Feb 26, 2011 | Fujitsu Siemens SCENIC W600 PC Desktop
Need hood open!
Use a slim jim to open the door. A heavy this banding material can be used to make a Slim Jim or else call a locksmith
Apr 06, 2010 | 1997 Pontiac Bonneville
Bmw z3 has no electrics, all dead
might be water inside the car leaked in slowly from the soft top in heavy rain, does the car smell slighly inside when all windows are closed? take the seats out and remove the water under the carpets, then leave everything to dry by slightly opening the windows for moisture to escape, try parking the car in the sun..........
Mar 04, 2009 | 1997 BMW Z3 Roadster
Right front electric window keeps opening by itself
it probably corroded the motor and or contacts. You can either take the motor out and try to clean it using elctromode, or replace it
Check ebay, they usually have a good aftermarket laying around for much cheaper than a dealer ship
Feb 06, 2009 | 2001 Audi allroad
Microsoft Windows XP Professional Logo
32 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
