Question about Amana ABB1927DE Bottom Freezer Refrigerator
The fan is sticking, wont run unless you give it a slight spin.
    President:
  • 2,468 Answers
Replace it they get old and stick they are not that costly
Posted on Jul 28, 2010
Testimonial: "Thank you, figured it needed it."
Eziset 950 wont spin and gives slight electric shock
Possible that the motor has failed and it has developed a leak to the body which seems to be felt over the machine, Isolate the motor and test the external voltage presence.. if absent it can be related to the motor.
Jan 12, 2013 | Simpson Washing Machines
Rheem air conditioner fan not working outside
with the unit off: use a stick or something safe to try to move the fan blades to be sure the motor is not seized. If it spins freely :turn the unit on and use stick to give the fan motor a "boost". if it takes off and runs you have a bad fan capacitor which is the most common cause of your problem
Sep 30, 2012 | Ruud UBHC Air Conditioner
Carrier model 38txa024300 ,condesor fan wont oporate with compressor unless the fan is spun befor energizing . is it the dual run capacitor that is bad? thanks for any help. jeff
If the fan spin freely then the capacitor could be bad. Otherwise, if it spin with difficulty then it need to be cleaned and lubbed.
May 22, 2011 | Carrier 36KCARMS Air Conditioner
I NOTICED ON MY 2009 DODGE RAM 1500 4.7 THAT IT HAS TWO FANS ONE IN FRONT OF RADITOR AND THE OTHER ONE ON ENGINE WELL THAT ONE IS RUNNING SLOW EVEN IF I GIVE IT GAS SPEED DONT CHANGE IS THIS NORMAL
the one on the engine is probably a viscous type fan.It spins freely until the heat causes it to 'stiffen' up and assist in drawing heat off the radiator.Prior to this it is not needed and would only rob engine power and slightly affect fuel economy.Easy way to check if it is viscous,with engine off,just spin the blades.It should spin with a little resistance onlyThe electric fan on the radiator is switched on by a temp sensor or by using the air cond(unless it has another for this task).Hope this helps you.
Apr 11, 2011 | Dodge Ram Pickup 1500 Cars & Trucks
My Evarorator fan motor wont start unless I give it a manual spin. Then it runs
Order a new one through an appliance parts distributor and save yourself any loss of food! Its going to fail completely soon.
Aug 20, 2010 | GE GTS18HBM Top Freezer Refrigerator
Fuses were replaced first. Fan on airconditioning unit won't keep
It sounds like the run capacitor of your condensor fan failed. When it fails, it can prevent your fan from starting unless you manually spin it to get it going, then it could run for awhile before it overheats.
Apr 06, 2010 | Heating & Cooling
The Inside of my oven wont get hot the light comes on but it doesnt get warm
If this is a fan over then check to see if the fan is spinning. If it is not spinning then the fan bearing has got tight. This is easily fixed by using a thin piece of wood, like a chop stick to give it a flick and get it moving.
Works a treat every time it happens to me.
If it's not a fan oven then you probably need to get the elements checked out.
Nov 20, 2009 | Frigidaire Ovens
1998 Pontiac Grand Prix fans only work when air conditioner is on
The fan clutch is probably worn out. With the engine warmed up but NOT RUNNING...see if you can sin the fan. Grab a blade and try to spin it.
If it freewheels, it's shot. Should be a slight resistance.....
Replace if nec.
Aug 14, 2009 | 1998 Pontiac Grand Prix
RV A/C blower not working and keeps kicking out
If blower not working, and yoou hear a slight "Hum" with fan only on, try this. With power off to AC. Go up on roof, and slide a stick through opening on side near rear, and try to get to fan blades at rear of unit. try to spin the blades a few times, even if it only goes a little at a time. Unless you want to take all those screws out & remove cover to get at it better, but watch for wasps under there. Give fan a couple of full rotations, then have someone turn it on to fan only & see what happens. If fan finally works, let it run for a few minutes on fan, then try cool & see if it all comes together again. Let me know.
Jul 17, 2009 | Dometic Rooftop RV Air Conditioner
AC unit wong start unless I spin the blower
you have 2 windings that are in you motor,One winding is the start winding It give the motor its initial boost that gets the fan spinning.The other winding is the run winding and it takes over and keeps the fan running.So it sounds like the motor is bad because the start winding is not giving the boost it needs to start. good luck--Nate
Jul 15, 2009 | Coleman Mach III Air Conditioner
Amana ABB1927DE Bottom Freezer Refrigerator Logo
145 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
