Question about Husqvarna Huskystar 215 Sewing Machine
I have lost the manual to my Huskystar 215. I need to know how to do the bobbin & also thread the machine. Thanks
  • Husqvarna Master
  • 7,365 Answers
Contact huskqvarna website & you can find a dealer that should have one or try these sites
sew usa
sewing manuals.com
ebay
Posted on Jul 30, 2010
How does the thread holder work
It sounds like you are asking how to use the spool cap. These are put on after the spool of thread to hold the spool in place.
Oct 05, 2014 | Husqvarna Huskystar 215 Sewing Machine
Manual free download
Hello
It is available as follows
Model Lang Title Date Huskystar 207,Huskystar 215 Svenska Instruktionsbok 04/28/2010 0MB Huskystar 207,Huskystar 215 Espa?ol Gu?a del usuario 02/01/2010 1MB Huskystar 207,Huskystar 215 English User's Guide 11/24/2009 1MB
from this link
http://manuals.husqvarnaviking.com/
Hopefully this will be of some help.
Sewingirl/
Jan 28, 2014 | Husqvarna Huskystar 215 Sewing Machine
Bobbin loading
it wont unless there is thread and it has to catch with the top thread. or else you put it where the thread is fed backwards. or, you have to push the lever back over that you filled your bobbin with.
Aug 22, 2012 | Husqvarna Huskystar 215 Sewing Machine
Bobbin thread jams
try changing the needle--flat side goes to the back of the machine
check the thread take up lever & see if the thread is still on it
it's also possible that the machine is out of time & needs to serviced
Feb 19, 2012 | Husqvarna Huskystar 207 Sewing Machine
As I sew there is too much bobbin thread on the underside of the material and then it gets all dangled
Common problem. The thread is actually not from your bobbin, it if from your main thread. The thread is either not properly going through the tensioner, or the tension needs to be tightened. This "birdnesting" is an aggravating, yet usually rather simple, fix. Did that take care of it?
Jun 20, 2011 | Husqvarna Huskystar 215 Sewing Machine
Husqvarna Model 215: My t-shirt material got jammed. I cut it out and then lifted out the needle, cover plate, bobbin and metal plate over the teeth. Then I took out the casing or whatever it's...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
May 24, 2011 | Husqvarna Huskystar 215 Sewing Machine
Out of nowhere, after working fine for weeks, the bobbin thread started breaking, and then stopped "wrapping" properly around the outside of the bobbin while I sewed. It keeps jamming to where I...
Change needle
Clean under needle plate where feed dogs are for lint
Clean bobbin area for lint or loose threads
Rethread machine top thread make sure to get every thread guide
& bobbin is threaded correctly & inserted in the bobbin case or shuttle correctly
Check tension 3 or 4 is usually good
after you try all this & it keeps jamming then it may need to be serviced
Nov 24, 2010 | Husqvarna Huskystar 215 Sewing Machine
Which way does the flat side of the needle go towards in a 215 model?
the flat side should face the back of the sewing machine
here's a tip I learned about needle & thread compatibility from a needle & thread expert
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
happy sewing
Oct 12, 2010 | Husqvarna Huskystar 215 Sewing Machine
Husqvarna Huskystar 215 Sewing Machine Logo
310 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
