Question about Electrolux Microwave Ovens
Microoven stops after 3 to 4 minutes and then it can be started only after 15 to 20 minutes cooling again it trips after 3 minutes
    President:
  • 2,468 Answers
The thermocouple located on the magnetron is either weak and sensitive to heat and goes out too soon,otherwise it can be the magnetron tube itself starting to draw too much current and overheating which would lead to this component shutting off power to the magnetron tube,if it doesnt seem too hot when it shuts off,then its this thermocouple on the magnetron tube
Posted on Jul 28, 2010
How do I turn off the cooling option on my Novamatic microwave?
The word COOL is displayed when the microwave goes into a cooling cycle. The cool cycle is a feature that ensures the operating components of the microwave (Inverter and Magnetron) are cooled after operation by running the fan inside the microwave.
The cooling function is activated whenever the microwave runs for over 3 minutes or is operated twice within a 10 minute period. The word COOL is displayed to tell you why the fan is still running. You do not have to wait for the cool cycle to complete before using the microwave again, simply enter the cooking operation you wish to perform and the cool cycle will stop and the microwave will perform the cooking operation you have just entered.
May 10, 2018 | Microwave Ovens
When I turn on my microwave. It sometimes shuts power off. The lights will go off and it will not run. I can unplug and plug it back in after a minute or two and it will work fine.
Sounds like the internal cooling fan may be stuck or defective. This will cause the micro to overheat which intern trips an internal heat safety. Once it cools down it will try to start again and repeat the same problem. Cooling fan is usually near the back behind the control panel.
Apr 04, 2015 | In Microwave Ovens
Microoven model 860A is not getting heated
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101p][p[]p
Feb 25, 2010 | Daewoo KOR-860A Microwave Oven
During cooking, the microwave will work for about 3 minutes then completely shut down.There appears to be a complete power failure.After the units sits for about 5 minutes,it resets itself and you can cook...
sounds like the cooling fan has came adrift or stopped working , this will cause the magnatron ( the microwave generator ) to overheat tripping the over temperature stat ,so fix the cooling , but be sooooooooooooo carefull in there , microwaves + really high voltages , not really a job for a non electrician/microwave tech
Oct 20, 2009 | Samsung SMH7178STD Microwave Oven
Mico only heats 4 to 6 minutes
many microwaves require x amount of clearance for exhaust heat, is it installed with the proper clearances?
it is one, not venting and tripping the overtemp,
two, the overtemp module is bad, or the board receiving the signal is bad
Nov 12, 2008 | Microwave Ovens
Setting the time on Sharp microovens.
Normally it's
Clock > time numbers > Clock
or
Clock > time numbers > Start
Sometimes it's
Clock > (1 or 2) > time numbers > Clock
or
Clock > (1 or 2) > time numbers > Start
If this doesn't work, please reply back with your model number.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 08, 2008 | Microwave Ovens
Microwave Steams Up, Heats Up, and Shuts off!
first of all your mwave needs to be properly ventilated .the problem is your magnetron when heated the thermal cutof switch cutts out power to magnetron.works again when cool.change magnetron
Mar 20, 2007 | GE XL1800 1100 Watts Microwave Oven
Microwave's Power goes off after 3 minutes running..
If the time from START to shut off were EXACTLY 3 minutes, then I would suspect a sensor problem or corrupted code in the microprocesor. But since that time sounds more random, it sounds heat-related, and I would suspect a failing magnetron or a failure in the cooling system. If the cooling fan is not running while the oven is cooking, this failure can occur, and can destroy the magnetron in short order. A cracked magnet (has the oven been dropped?) or other problem can cause a magnetron to go bad and overheat. If it's under warranty, I would definitely contact the manufacturer (see your manual) to find an authorized local servicer. If it's out of warranty, I would balance the cost of a new microwave versus a bench diagnosis fee of $25 or more or an in-shop repair cost of maybe $80 or more.
Oct 15, 2006 | Westinghouse WST3504 Microwave Oven
Microwave Ovens Logo
225 people viewed this question
Top Electrolux Microwave Ovens Experts
William Miller
William Miller
Paul Bade
Are you an Electrolux Microwave Oven Expert? Answer questions, earn points and help others
