Question about ASUS P4GE-V Motherboard
Videocard wont work
I cannot my videocard to work it's a visiontek-x1300
    Problem Solver:
Agp video card driver
Posted on Dec 02, 2009
    President:
  • 2,351 Answers
Hi jazzcowboy,
Your Asus P4GE-V uses an intergrated graphics card.
Onboard VGA [Auto] Page 4-22. User manual.
If the bios is set to Enabled, the onboard VGA is enabled.
When you add an AGP card your bios will not see it.
You must change the bios setting to [Auto] so the system will see your AGP video card.
To download your manual for the Asus P4GE-V Click the link.
http://support.asus.com/download/download.aspx?modelname=P4GE-V&SLanguage=en-us
Suggest you add to your favorites.
Enjoy!
Have more questions, feel free to ask.
Mike
Posted on Apr 24, 2008
X1300 dvi/vga gives no video
test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) Ide/Sata make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every working device and to have an end for a computer to be able work properly
make sure your graphics card is securely seated with no dust in its socket
hope this helps you:
Sep 10, 2011 | VisionTek ATI RADEON X1300 256MB DDR2 PCI...
I have a Dell dimension 4300 running Windows XP SP3. The system has 1 Gb of RAM. I removed the AGP graphics card that came with the system and installed the VisionTek Radeon 256M X1300DMSPCI card into a...
Yes, it is compatible, just that you must first uninstall the previous video driver, then configure the BIOS to route the video signal to the PCI and not the AGP and only then install the new card. And in the end it will behave worse than the previous AGP card you got because the PCI interface is way slower than the AGP.
Just buy a good AGP card, PCI cards are made for office pc's in which the onboard one is totally obsolete.
Feb 08, 2011 | VisionTek RADEON X1300 , Graphic Card
After installing x1300 pci card and disableing my motherboard graphics card I get only a black screen
so many possible reasons for this so ill have a stab have you connected the monitor cable to the new graphics card or have you left it connected to the internal graphics adapter or failing that you may not need to disable the internal graphics in bios just pick auto if available or select agp/pci-e if possible
Aug 04, 2009 | VisionTek Computers & Internet
When installing on vista it wont go past currently installing microsoft visual c++ redistrutibale.
this is mostly caused by scratches on the installation disk or that part of the package may be curropt, if you are using an origional windows then you can approach microsoft with this issue and they will replace your disk otherwise just get another copy from someone and try installing that. <also try if you can skip C++ installation, but i dont think that will work as its an important component and windows requires it>
Jul 05, 2009 | VisionTek RADEON X1300 512MB AGP Graphic...
I have a vision tek radeon x1300 xge 8x/4x graphic card that was working fine the last time i used my computer. now when i turn on computer i get a message saying no signal on monitor and then screen goes...
Hi there. Try connecting it to a diffrent monitor to see if the same thing happens. If it does, open the case, take out the card, and then put it back in. Now turn it on and try again.
Let me know how it goes.
Tim
Apr 17, 2009 | VisionTek RADEON X1300, (512 MB) AGP...
Problem installing ATI Radeon X1300 256mb in Dell Optiplex GX260
Hi edward,
I'm looking at the specs of your dell and of the video adapter.
It appears the Power Supply in your dell may to under powered for the video card.
According to dell's website the largest psu that ships with that unit is 250 watts while the radeon x1300 needs a minimum of 250 watts to run and assuming you have the 250 watt version you need to take into consideration that the psu is also powering your CPU, memory,fans,hard drive/s and other components on in your system so 250watts just isn't enough.
You may want to contact dell and see if there is a larger psu that you can purchase. I would recommend one at least in the 400 watt range.
I hope you get it straightened out I certainly know how frustrating it can be to not be able to use new hardware.
Let me know how it works out.
Sean
Mar 16, 2009 | Computers & Internet
Need to connect 2 displays to Vision Tek RADEON X1300256 card
You probably should have gotten a card that had Dual DVI because it will be two separate outputs instead of one... I would take it back and get the correct Graphics Card.
Dec 10, 2008 | VisionTek RADEON X1300 , Graphic Card
Tried To Install New Card, monitor not responding.
Tech is suggesting that you pressed too hard while switching back & forth & may have hurt the motherboard by bending it. This a common problem. I can only suggest that remove your old card & clean the PCI slot with canned air. Carefully reseat the old card pressing evenly downwards till the card is seated. Use a flashlight & check where the card connects to the slot. It should be level across the PCI slot. Do this while the power cord is unpluged from the PC. Plug the power back in & start the PC.
Some video cards require extra power. Your newer card may need a four pin power connector to run. Please check the instructions that came with the RADEON X1300.
Dec 31, 2007 | VisionTek RADEON X1300, (512 MB) AGP...
Video card for emachines 5260
The 5260 has differant types of motherboards.
You can read about the differances below: If your sure its a PCI slot that you want than this should make a differance - Visiontek Radeon X1300 Video Card -256MB GDDR3 Lifetime Warranty!
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2467314&body=WARRANTY#tabs
Info about the Emachine 5260
http://www.gennersales.co.uk/recovery/emachineupgrades.htm#eMachines_5260_Computer_Upgrades
Dec 15, 2007 | Sapphire RADEON X800, (256 MB) PCI Express...
My screen is completely black but i can still see my mouse.
Try uninstalling your current drivers. Download and install new ones from the manufacture's site.
If problem persits, this means that the graphics card itself is fried/damaged.
Nov 18, 2007 | VisionTek RADEON X1300, (512 MB) AGP...
ASUS P4GE-V Motherboard Logo
132 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
