Question about Kenwood KAC-848 Car Audio Amplifier
What is the rms outpur of my kenwood KAC 848 amp
  • 70 Answers
Rms at 4 ohms is 50x4 in 4 channel mode if your in 2 channel mode then its 150x2 if at 2 ohms then it would be 4 channel 75x4.
Posted on Jul 29, 2010
Best subs for the kenwood x812d
Try and match the rms output of the amp to the speaker , if the amp puts out 150 watts RMS make sure your speaker is at least 150 watts RMS.
Feb 03, 2014 | Kenwood eXcelon KAC-X812D Car Audio...
I need to know the wattege of a kenwood kac -624
The KAC-624 is a 40 watt x2 @ 4 ohm RMS amp. 55 watt x2 @ 2ohm. 110 watt x 1 Bridged I assume at 4 ohm. Manual does not specify. It can run 2 ohm in stereo mode but is unclear on mono impedance requirement. It can run 4 ohm mono at 110 watt but at 2 ohm?
Dec 12, 2011 | Kenwood Car Audio & Video
Just woundering if i could bridge one sub to front and one to rear the subs are kenwood w3514 dvc subs the amp is kenwood kac-x501f
Hello bigmac208,
Yes, that would be the best connection for both the subs and the amp.
I'd wire the sub voice coils in series since the amp will not be stable at 2 ohms when the channels are bridged. The power will be somewhere between 100-200 watts RMS to each sub. While it's not pavement pounding, it should provide pretty good bass, especially if you tweak the crossover and boost settings for best bass response.
Hope this helps.
Aug 28, 2009 | Kenwood KAC-X501F Car Audio Amplifier
Kenwood kac-7204 1000w amp with 12 in sub what size wires nedded to use
bigger the better my friend. Look at your Peak RMS output, and how long of wire you need. Then you could make the judgment call on how thick or what gauge you need. (2 involved factors power + distance). id say 10 gauge and you would be fine.
Jun 03, 2009 | Kenwood KAC-7204 Car Audio Amplifier
My sons kac 848 amp just stopped working
There is an Internal Fuse on Most of these Models that will blow from time to time. You might also check the Ground Connection. A loose Ground can cause the Same Problem. Please Rate My Response! Thanks!
Feb 02, 2009 | Kenwood KAC-848 Car Audio Amplifier
Adjusting wattage on kenwood kac 9103 class D mono amp
That amplifier is 900W x 1 @ 2ohms.
If your subs are 4ohm SVC wired Parallel, resulting in a 2 ohm load, each sub will only see 1/2 of the rated power. (450W ea.)
Your gain (sensitivity) setting should be between 75% and 85% to max. You will be fine.
Jan 02, 2009 | Kenwood KAC-9103D Car Audio Amplifier
Kendwood kac-848 audio problem
Are you sure you have the speakers wired to present a safe load to the amp?
Aug 11, 2008 | Kenwood KAC-848 Car Audio Amplifier
Kenwood kac-848
You have blown outputs , faulty channels. What kind of amp do u have and what were u running to it? Most likely a bad amp, u might need a new one.
Jan 24, 2008 | Kenwood KAC-848 Car Audio Amplifier
Schematic
Try manualsparadise.com or go to the Kenwood web site and look in the support section.
Dec 18, 2007 | Kenwood KAC-848 Car Audio Amplifier
Car Audio & Video Logo
148 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
