Question about Kenmore 44102 Front Load Washer
Kenmore 44102 front load washer will not spin. the belt is good, I remove the belt and the motor sill does not run in spin cycle.
  • 15,935 Answers
It appears your motor/motor controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Oct 01, 2010
The drum does not turn.
there are two potential problems. firstis te belt to the drum drive pully from th moter. this is the easiest. take off the back panel an seeif the belt is intact. if so run through a cycle and see if the motor spins or triesto spin. if not this is most likely thesuspect. one plug three screws and about100 dollarsfixes te motor. hope this helps.
Dec 18, 2009 | Kenmore 44102 Front Load Washer
Maytag Washer model LA182 loud while washing.
there should be a belt tensioner on thebelt path check to be sure the belt is not slipping
Aug 14, 2009 | Kenmore 44102 Front Load Washer
Washer will not do a spin cycle for rinse or end of cycle
you can check two things,. One is, is the belt broken or stretched, the other is the motor, is the motor turning if the motor is turning then replace the belt. If the motor is not turning replace the motor.
Feb 08, 2009 | Kenmore 44102 Front Load Washer
Kenmore Front Loading Washer Slow Final Spin Cycle
out balance are water still in tub will do that try cleaning out the pump filter under the panel at the bottom of the washer some have a big white looking screw you turnit remove filter if there water in it it will flow to the floor so have something to catch it with
Jan 26, 2008 | Kenmore 44102 Front Load Washer
Kenmore 417.29042992 front loader washer
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 23, 2008 | Kenmore 44102 Front Load Washer
Kenmore front Loader 41729042990
remove motor, check carbon brushs,replace if short,the manual may help.motors that have brushs are the principle,sole motor is Italian,yours is German,anyway thats beside the point ,its the brushs.buy ,eire
Dec 11, 2007 | Kenmore 44102 Front Load Washer
Spinning problem
In those cases it doesn't spin - Do you hear if motor is running (an humming noise) ? It sound like a badly worn belt that slid on the tub (the washer succeed to spin- depending on clothes weight in tub) . Open the rear panel, check for belt status and if it really worn,replace it with a genuine belt from the manufacturer. Be awre you should disconnected power cable from the machin before starting work on it. Good luck!!!
Jun 04, 2006 | Kenmore 44102 Front Load Washer
Kenmore 44102 Front Load Washer Logo
46 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
