Question about HP LaserJet 3050 All-In-One Printer
I have hp laserjet all in one ,,, when I want to
I have hp laserjet all in one 3055 ,,, when I want to make a copy from the feeder paper this message apper " document feeder mispick,reload " how can I fix this problem
  • 52 Answers
Check roller and seperation pad
Posted on Jul 29, 2010
Documnet feeder jam
Check input paper feeder at top too - easy to miss. Top flips open with a firm (but not excessive) pull, so you can look there.
If you are sure you've opened and looked under every available panel on the printer (there are many!), turn it off and unplug for half a minute. Make sure all panels are back properly in place, but leave out the paper tray (and no paper either in the rear input paper feeder).
Plug in and turn on. Wait for it to finish its start-up sequence - it should complain about no paper.
Check the paper is flat and straight in the paper tray, and no excess room between paper and guides, and put it in again.
Print test page.
How is it now?
Sep 15, 2009 | HP LaserJet 3055 All-In-One Printer
I have a HP laserjet 3055 all in one printer and its giving me the error message that says Doc. feeder Jam. There isnt anything in the printer. How do I fix it.
The jam it's talking about is in the feeder on top. Check for stuck paper, or a sensor stuck down, in the feeder area on top
Aug 06, 2009 | LaserJet 3052 All-In-One Printer
When trying to copy papers do not feed but if you scan they will
HP LaserJet 3050z, 3050 All-in-one, 3052, 3055, 3390 and 3392 versatile printer - Error reported: Document Feeder Jam ISSUE: How to correct the HP LaserJet 3050z, 3050 All-In-One, 3052, 3055, 3390 and 3392 versatile printer if this error is reported: Document Feeder Jam SOLUTION:
  • Clear the jammed media from ADF (HP LaserJet 3050, 3050z).
  2. Remove any jammed media with care.Take out the page gently. NOTE: Take care not to tear the paper. c01075162.gif
  3. Close the ADF cover plate.
  • Clear the jammed media from ADF (HP LaserJet 3390, 3392, 3052 and 3055).
  1. Open the ADF cover plate. NOTE: Check whether all packaging straps inside the ADF are removed. c01075163.gif
  2. Unload the jam clearance component.Lift the two handles with both hands until the component clutch is released.Rotate and lift the jam clearance component, and then put it aside. c01075164.gif
  3. Lift the green handle, and rotate the paper picker until it is opened. c01075165.gif
  4. Gently remove the page without tearing it.If you feel resistance, go to the next step. c01075166.gif
  5. Open the ADF cover plate, and loosen the media gently with both hands. c01075167.gif
  6. When the media are stopped, pull the media out gently along the shown direction. c01075168.gif
  7. Close the cover plate of the flat scanner (HP LaserJet 3390, 3392, 3052, 3055). c01075169.gif
  9. Insert the jam clearance component to reinstall it.Press the two reeds until the component is properly engaged.Install the clearance component correctly. Otherwise, paper jams will continue to occur. c01075171.gif
Have a good day
Jun 22, 2009 | HP LaserJet 3055 All-In-One Printer
Not scanning or copying when using the ADF on HP laserjet 3055
Based on the assumption it's mechanically ok, check the cable connection between the document feeder and the base, if damaged or worked look it can cause errors. If it is a sensor error, check for a small bit of paper or even a staple from a prior jam.
Jun 18, 2009 | HP LaserJet 3055 All-In-One Printer
Paper jammed in the feeder, what do i do?
Hello, You can try to pull it out of the feeder. If it's too hard, open every doors and see where you can pull it out from Hope this helps
Jun 10, 2009 | HP LaserJet 3055 All-In-One Printer
Black line down side of copy
Pull open the document feeder and clean off the scanner glass.
Jun 08, 2009 | HP LaserJet 3055 All-In-One Printer
Doc.feder jam
Try cleaning the rollers in the ADF (Automatic Document Feeder).
It might temporarily solve the problem, but rollers do have a limited life time, so you will eventually need new ones.
Part info:
5851-3580 - Automatic document feeder (ADF) paper pick-up roller assembly
Price: $15.57
Dec 10, 2008 | HP LaserJet 3055 All-In-One Printer
HP 3055 model scaner problem
i want repair HP laserjet 3055
Scanner error 6
Sep 15, 2008 | HP LaserJet 3055 All-In-One Printer
Paper in document feeder
there is no paper in document feeder
May 24, 2008 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3050 All-In-One Printer Logo
386 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
