Question about Kitchen Ranges
ERD range oven won't heat
I self cleaned the oven and now the oven won't work we have the ERD model of gas range. I have tried everything in the book but it doesn't heat. The lights work,the time has been adjusted. The main fan starts but there is no heat
Dacor service said it was a control panel issue with the high limit.The cooling fan should also be set from 300 to 200
Posted on Apr 25, 2008
Oven won't heat.
Good Afternoon Gwen - Try reprogramming the range by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. If issue persists, then the unit could possibly be experiencing an issue with a wiring failure, EOC (electronic oven control), sensor probe and/or faulty bake or broil element. I would strongly recommend consulting a professional to narrow down the precise issue before investing in parts that may or may not be the root cause.
May 15, 2013 | Frigidaire Gallery 30" Self-Cleaning...
My GE xl44 gas range broiler won't work,
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jun 02, 2011 | GE Profile JGB900 Gas Kitchen Range
The oven does not work. The self clean does not too
kenmore self cleaning range c970-595084 everything works except the oven will not heat up,on self clean door locks but thats all, top elements work, lights work, digital display works, but no power going to oven elements when i used a tester to check voltage. Can anyone tell me what to do? Is there a fuse for the oven only?
ANY HELP IS APPRECIATED.
TY Fr; Clyde
Mar 15, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
If i push the clean button, what happens?
The oven goes on full balst and heats up to like 800 degrees to try to incinerate averthing that spilled or run over into the oven....the problem is that it also incinerates everything around your oven including the controls and wiring...do it at your own risk... it is on there because it sells ovens...
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Sep 07, 2010 | Frigidaire 30" Self-Cleaning Slide-In Gas...
Gas oven wont turn on
my brother stopped by last night and undid the lower fire cover , fiddled with something (we don't know the name) , now the oven will heat up and life is calm.
thanx for having this site to help calm us silly homemakers who aren't DIY.
aloha, teri
Aug 21, 2009 | Maytag Gemini 30" Self-Cleaning...
How do you clean the self cleaning oven i never got a book
just push the clean button, it will superheat the oven for an extended period, burning off old residue.
Apr 12, 2009 | Maytag Gemini 30" Self-Cleaning...
Kenmore gas range--oven won't come on
My oven will not work. After pressing the desired temp on the oven, the preheat light and oven light comes on. After about 15 minutes, the oven is slightly warm and maybe an hour later the oven may or may not heat to desired temp. Kenmore gas range model #790.72851301.
Nov 15, 2007 | Kitchen Ranges
Oven won't start
Open the bottom storage area drawer, Look to the right for a badge with model / serial number.
If the over has the following options..
Self cleaning work ?
Broiler work ?
Oct 10, 2007 | Tappan TGF320 Gas Kitchen Range
Kitchen Ranges Logo
101 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
