Question about Epson DFX-9000 Matrix Printer
My problem is: Printer DFX-9000 doesn't printing some lines of text from txt file. Exactly, every second line printer replace with blank line. I checked settings and it is correct, just like other dfx-9000 that printing correct. What to do? Thanks advanced!
  • 415 Answers
Try head cleaning and printer alignment should help
Posted on Jul 28, 2010
DFX 9000, just over 1 yr old, Skipping lines withing the print. Then generate error OD
From our FixYa forumn:
The error codes OD means that a check of the print head thermistor circuit during power-on initialization determined that the print head itself is not installed. Some cause of this is again the print head is not installed, the print head built-in thermistor element has failed, carrier cable is disconnected or is already damage, print head temperature detection circuit has failed.
Having said this, it is better to have the printer check by a qualified technician.
http://www.fixya.com/support/t1051554-epson_dfx_9000_error_code_od_ob
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 01, 2011 | Epson DFX-9000 Matrix Printer
DFX-9000 printing 2 Journals on 1 page instead of 1 per page
Have you tried to check the print settings?
Click on Start>Control Panel>Printers(Printers and faxes)> Right Click on the DFX-9000 printer icon>left click on properties>click the printing preferences button located below the properties box. In this window you should see the setting of the printer itself.
Sep 05, 2009 | Epson DFX-9000 Dot Matrix Printer
Print heads for dfx 9000
if you replace the printhead and dont change the alpha an beta value, your printheat was damage shortly
Feb 05, 2009 | Epson DFX-9000 Matrix Printer
Epson DFX-9000 printing from DOS nework
can i ask a free download driver for my printer bjc-80v?
Feb 01, 2009 | Epson DFX-9000 Dot Matrix Printer
DFX 9000 Printing problem
when i switched on epson dfx9000 printer its showing Error 01,Pls give the solution.
Dec 17, 2008 | Epson DFX-9000 Matrix Printer
Re dfx -9000
Please perform the following steps to ensure your printer is physically functioning.
1. Turn the printer off and disconnect the interface cable.
2. Load plain, single part tractor paper into the printer.
3. Press the LOAD/EJECT button while turning on the printer.
NOTE: The self test prints over several pages. After the first or second page has printed, press PAUSE and turn the printer off.
If this self test prints correctly, then the printer hardware is functioning correctly.
>Try printing from other applications.
>Check cables as they can cause communication errors.
>Re-install the driver.
>Go to support.epson.com for more information & documentation.
Sep 08, 2008 | Epson DFX-9000 Matrix Printer
Dfx9000
The SP motor brake signal did not switch on within 3 seconds after turning the printer on.
Check, and if necessary replace, the following in the order below.
1. Check for disconnected SP motor-related connectors (ROM BOARD: CNSPHS, CNSPM)
2. Check the Interlock switch, and if necessary replace the switch assembly
3. Check both the SP motor and driver. (Always check both.) Check fora broken fuse on the SP motor 42 V line.
Replace the motor assembly and/or ROM BOARD as necessary.
Jul 08, 2008 | Epson DFX-9000 Matrix Printer
Line feeds
Hi-
When you said line feed do you mean the Top of form?
hope this helps
1. Make sure the printer is turned on and the desired tractor is selected (the corresponding tractor arrow should be lit).
2. Open the upper cover.
3. Press the Top of Form button to enter top-of-form mode. The printer beeps once, and the Top of Form light turns on.
4. Use the Micro Feed buttons to feed the paper to the desired top-of-form position. The “A” on the ribbon protector shows you where the bottom edge of your first line of text will print. This position is based on the first printable line of text. If your software inserts a top margin of five lines, your text will actually print five lines below the top-of-form position.
5. Press the Top of Form button again to exit and save your new top-of-form position. Then close the top cover.
Keep me posted if you have inquiries, thanks!
Jun 18, 2008 | Epson DFX-9000 Matrix Printer
Printer is not aligning paper properly.
Please try the following to resolved that issue:
Jun 10, 2008 | Epson DFX-9000 Matrix Printer
PDF printing with DFX 9000
Actually, the issue that your having is a software issue. You need to check the settings of the reader. Try to contact Adobe and ask help for its settings. They're phone number is 1-800-945-9120.
Feb 06, 2008 | Epson DFX-9000 Matrix Printer
Epson DFX-9000 Matrix Printer Logo
366 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
