Question about Compaq MP1400 and MP1800 Replacement Projector Lamp - L1551A Projector Lamp
Five projector panel buttons flash amber - Compaq MP1400 and MP1800 Replacement Projector Lamp - L1551A Projector Lamp
In focusi 2114 will not stop blinking amber
pls check the uaer manual
http://www.projector-manual.com/manuals/infocus/InFocus_IN2114.pdf
page 6
http://manualmachine.com/infocus/in2114/771122-user-manual/page:6/
Power, blinking amber
The power button has been pressed to turn the projector off and the fans are running to cool the projector.
Nov 10, 2016 | Computers & Internet
What is the cause of Dell 4210X projector temp and lamp flashing amber?
This is going to be the lamp itself. Once you replace it will have to be reset back to zero hours to work properly
Sep 07, 2015 | Dell Office Equipment & Supplies
Power bottom light flashes amber and the temperature light is steady amber after DMD chip replacement.
Sounds like a board problem or a bad temp sensor. Those things get pretty hot (charred) and you may have open circuit it when you swapped. Did you put the old one back in?
Nov 25, 2014 | Dell 4610X Wireless Dlp Multimedia...
Projector is not on red light is blinking
check the lamp first
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
Dec 16, 2013 | Dell 1210S Projector
My hd20 has a power-icon light of amber, when power button is pushed it goes to flashing green and it doesn't turn on, just flashes green
Have you tried decreasing the resolution of the computer?
When the resolution is too high for the projector, something similar to your description happens.
Oct 23, 2011 | Optoma HD20 DLP Projector
I lost my viper remote starter, i already bought a replacement remote, but how do i progam it? I have the basic five button remote, black buttons and silver borders around the whole remote.
Programming the Viper Remote Starter 5101
Unlock the doors before starting
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in IGN to the on position but don
Dec 12, 2010 | 5101 LE 1 Way Car Remote Starter System
My Ask Proxima won't turn on
if there is no amber led, the power supply is bad. if you have an amber led and the button won't work, there is an obstruction under the button panel. if the led is red and no fans come on, the fans or the power supply is bad. if the fans come on but no light, the colorwheel is bad.
Nov 03, 2009 | ASK Proxima M2+ Multimedia Projector
5 amber flashes
Operator error.
Press printer's RESUME button.
If this doesn't clear the error, cancel printing and turn the printer off and then back on.
When press Resume button, ip3000 not responed(not print)
Aug 07, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Projector
A couple of things...
If the fan is not working, the lamp will not fire. If you have the owner's manual, it should indicate what the flashing lights mean. Check to make sure that the panels are seated properly. When you replaced the lamp, the outer cover was removed. If that is not seated back 100%, the unit will not work. There are a number of safety "checks" built into the unit to prevent damage and possibly fire as the lamps get really hot.
Check the items above and let us know your progress.
Dan
Jun 19, 2008 | Dell 2300MP Multimedia Projector
29 people viewed this question
Top Compaq Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Computer Links
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
