Question about Zebra GK420 Thermal Printer
Unable to factory reset network setting on a ZebraGK420d
    Champion:
  • Zebra Expert
  • 285 Answers
Press the button untill flash 7 times, then relese the button, try without network cable unplug
Posted on Nov 13, 2010
  • Anonymous Nov 13, 2010
    press button untill flash 7 times, then release.
  • or guest press button off machine and botton press on machine and flash 7 times
How to reset a Xerox Workcentre Pro 123 to factory settings?
The default userID is 11111, and the default password is x-admin http://www.office.xerox.com/userdoc/CC_WCM_WCP_123_128/CC_WCM_WCP_123_128_Web/pdfs/Quick_Networka_Setup_En.pdf
this guide should let you set dhcp and otherwise control it
I was unable to find a "factory reset" solution
Aug 03, 2015 | Office Equipment & Supplies
Unable to login to WAP4410N using web based administration utility after factory reset. it's reporting as invalid username or password
Please see the Reset the Default Factory Setting please read it the Detail I have a WAP4410n wireless access point, I have reset it to factory default by pressing the reset button for 30 seconds. I am able to ping its default ip 192.168.1.245 through its default ssid "ciscosb" if I configure my static ip was solved by connecting through the lan cable, and setting manually the ip to 192.168.1.0/24 network, and accessing 192.168.1.245 through web, the reason why the connecting through WiFi was working because the management web access through wireless is disabled by default
Thanks
Apr 21, 2015 | Cisco Small Business WAP4410N WirelessN...
Why am I unable to join the network "belkin.a83"
The router has been changed from its default settings, so if you do not have the passed you need to reset it to factory settings.
You can reset the factory default settings by
Press and hold the "Reset" button for at least 10 seconds, and then release it The lights on the Router will momentarily flash The "Router" light will begin to blink When the "Router" light becomes solid again, the restore is complete. Also download the User guide from here.
http://cache-www.belkin.com/support/dl/F9J1002_8820ed00839_man_uk.pdf
Jan 24, 2015 | Computers & Internet
Unable to reset Siemens SE568 router to factory settings. pressing button at base of unit reboots device but does not restore factory settings. need to access gateway to configure wireless network. How...
Reset button on the back of the router. You will probably need a toothpick to press it. Recommend holding it in for 30 seconds. Hope this helps.
Sep 17, 2013 | Computers & Internet
Need to reset handset
IP Reset
IP Reset returns the basic network settings to their factory defaults. You can perform this operation from the
base unit or one of the handsets.
The following settings will be reset to their factory defaults:
DHCP setting (restored to DHCP on
• Settings related to static IP addressing (the values for static IP address, subnet mask, default gateway,
DNS1, and DNS2 are cleared)
• DNS settings for DHCP connection cleared
1.2 Reset and Firmware Update
1.2.1 Reset
1.2.1.1 Resetting the Network Settings IP Reset
Performing IP Reset from the phone user interface see 2.1.4 IP Reset restores the basic network settings
made through phone user interface programming or Web user interface programming to their factory defaults.
If the unit is unable to connect to the network after changing network settings, you can restore the network
settings to their factory defaults by performing IP Reset, and then try configuring the settings again. Settings
such as the phonebook data, are not cleared by this feature.
• DHCP setting restored to DHCP on
• DNS settings for DHCP connection (cleared)
• PHY settings (speed and duplex mode of the either LAN or PC port are restored to "automatic")
• VLAN (Virtual Local Area Network) settings (disabled)
• Terminal number settings (restored to "automatic")
Notice
After performing IP Reset, the unit will restart automatically. To avoid problems, it is recommended that
you save your settings before performing IP Reset.
Note
If these settings (with the exception of PHY settings and terminal number settings) were made through
Web user interface programming, the set values made through Web user interface programming
remain effective, even if you perform IP Reset. To reset these settings to their factory defaults, perform
Reset Web Settings from the Web user interface again.
Document Version
2010-08
Administrator Guide
www.InternetVoipPhone.co.uk ' sales@internetvoipphone.co.uk ' 0800 088 4846
Firmware Update
configuration file programming, the set values made through configuration file programming remain
effective, even if you perform Reset Web Settings.
Resetting the Settings Made through the Web User Interface
(Reset Web Settings)
Performing Reset Web Settings from the Web user interface see Reset to Defaults) resets the
settings made through the Web user interface to their default values.
When you use this feature, the unit will return to the status just after performing the most recent provisioning
or pre-provisioning.
Notice
After performing Reset Web Settings, the base unit will restart automatically. To avoid problems, it is
recommended that you save your settings before performing Reset Web Settings.
Note
The settings configured through the phone user interface only will not be reset. However, settings that
can be configured through both the phone user interface and Web user interface will be reset.
1.2.2 Firmware Update
You can update the unit's firmware to improve the unit's operation. You can configure the unit so that it
automatically downloads the new firmware file from a specified location. The firmware update will be executed
when the unit is restarted.
For details, see Section 6 Firmware Update.
Provisioning server
Firmware server
Configuration
file
A
Firmware
C
B
A Download
B Check for update
C Firmware download and update
34
Administrator Guide
Docume
Jan 16, 2013 | Panasonic KXTPA50 Phone
Windows XP sp2, Router speedstream 6520 Wireless setup problem. The netbook is not asked for the network key. ''Windows is unable to connect to the selected network....... I get this message even if the...
please check router settings [transmission mode ] set it to G and try again, if all fails reset router to factory and reconfigure with is a safest thing to do.
Sep 24, 2009 | Computers & Internet
Not able to restore factory setting using 12345 code or 0000 code
If you were unable to restore factory settings using "12345", use 1234 or 123456. If that will not work, refer to the user manual of your phone or contact the phone service provider.
Apr 08, 2009 | Nokia 5310 Cellular Phone
Need to reset savin 3740 fax to factory defaults
Found documentation of Ricoh's website. They are the manufacturor of Savin products. The default access code is 2222. Entering this allowed me to get into the network settings and change the IP scheme.
Jul 25, 2008 | Office Equipment & Supplies
I am unable to access the 192.168.2.1 to set the security WAP or WEP for my network. The network works fine with 3 other computers and various other games accessing the network. It is just insecure. I have...
hold the small reset button down and hold the "push button down" this will reset to factory settings. the the ip address should now be accessabe. however. it sounds like your setup has changed the ipaddres of your router and you will have to reconfigure it to meet your systems needs.
Mar 01, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Zebra GK420 Thermal Printer Logo
4,144 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Marvin
Marvin
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
