I have a simpson swf 1076 front loader washer that has the door stuck on lock.
Have the same model
Posted on Sep 08, 2010
I have a Simpson esprit 550 and it won't agitate or spin? Fills and drains fine any help would be great thanks
check pressour switch door lock or lid lock not familer with mechine so don't no if its top or front loader good luck
Apr 20, 2015 | Simpson Washing Machines
How do I reset my simpsons eze loader 5.5fkg front load washer 45S558E.. have installed a new LOCK DOOR part
turn off the mains hold power on
turn on the mains plug
have you tried holding in buttons and turning on the mains
wait a min??
perhaps it wont lock the door because of a connection fault
the controller is detecting your closing the door
next in the routine is usually start to detect motor and add water
perhaps the intake valve has failed and the machine isnt detecting water...?
Dec 09, 2014 | Washing Machines
My front loader door wont lock
Believe it or not, you may be able to fix that yourself with some spray lubricant applied to the shaft of the electric lock mechanism, but you will have to remove the lock to lube where it's stuck. Then you will need to work the locking jaw back and forth till it breaks free then reinstall.
Mar 18, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
My front load washer has the door lock stuck and the door is open
When this happened to our front loader washing machine, we had to unplug the appliance, wait, then replug it to reset and unlock the door.
Feb 10, 2010 | Electrolux EW1000i Front Load Washer
Wont work
Your door lock is not fitting correctly!
This is a safety override to make sure that the washer does not fill with water & leak all over the floor because the door is not locked properly!
Suggest you get the door lock mechanism checked out and adjusted. It could be that this has either become blocked with soap powder or cotton material shedded from your clothing over time.
The latch is normally available as a spare part, so you could check this out with your local Simpson dealer, or buy it on the internet once you know the part ref number.
Nov 17, 2009 | Office Equipment & Supplies
Door won't open
the lock switch is probably stuck. make sure machine is off but plugged in still. Push in on the door while gently giving a couple of thumps around the lock area and the lock will probably "click" open.
Aug 16, 2009 | Kenmore Elite 45986 Front Load Washer
Washer is stuck on control locked
Press & hold 'end of cycle' at right of panel for 3 seconds. The light will come off.
And rate me plz....................
Mar 27, 2009 | Whirlpool GHW9100L Front Load Washer
LG Front Loader WD-8074FHB
sometimes you just have to force the door but first try hitting the machine near the door lock sometimes this helps the door interlock may be stuck in the closed position
Mar 02, 2008 | LG WM1812C Front Load Washer
Washer load became imbalanced and forced door open, now cannot close door, lock stuck and washer will not run
Perhaps you have to change your lock, this is a sensitive point & will affect the smooth operation of your machine. Re. the inbalance, you hv to screw up & lock the front 2 legs (with check nut), adjust the front legs (screwed up) only to see if the machine does not move during wash/spin.
Nov 13, 2007 | GE WBVH6240F Front Load Washer
Washing Machines Logo
265 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
