Question about Linksys Wireless-G WRT54G Router
2.4GHz Wireless Lan And 5 GHz Wireless LAN
I have a Linksys WRT54G
i have no signal but sometimes i can connect to the internet
when i check my status it says :
The Frequency band of 2.4GHz Wireless Lan And 5 GHz Wireless LAN are not compatible, please switch system to the same frequency in order to connect successfully
please help me ...
  • 700 Answers
This is usually caused by your router and your wireless network card are not compatible... you need to purchase as well cisco wireless network card adn tehn when you press your wireless security on the router, it will automatically apply all security protocol to the connection.
if you do not want to purchase new card, you always can setup these devices manually,
connect to the router via rj45 cable, establish what protocol, security and transmission method/frequency you will be using, write that down, disconnect the cable, enter your wireless network card settings and apply same settings to your network card, this should solve the problem.
as you did not stated what operating system you are using and what card is in your computer, this is unfortunately best advice which can be given.
how to set up your router, you have downloadable pdf file on linksys site.
Posted on Jul 28, 2010
My router stopped communicating with modem
LinkSys Wireless-G WRT54G 2.4 GHz Broadband Router with 4-Port Switch:
Go to LinkSys Login. wrt54g_back-panel_mini.gif Resetting the Router will erase all of your settings (WEP Encryption, Wireless and LAN settings, etc.) and replace them with the factory defaults.
There are two ways to reset the Router's factory defaults:
The Internet port is where you will connect your broadband Internet connection.
Please Rate Me
Nov 17, 2010 | Linksys WirelessG Broadband Router with...
I have a WRT54G router and want to daisy chain a Linksys BEFSR41 switch off it, but I seem to be doing it wrong...
Not sure if you just want to expand the amont of computer you can connect to it or the wireless range but I would setup the BEFSR41:
  • Disable DHCP
  • Set an address out of the DHCP scope of the WRT54G
  • Connect them LAN to LAN if not use xover to connect them
Aug 27, 2010 | Linksys Wireless-G WRT54G Router
Receiving wireless signal but unable to connect to the Internet
you have to set your router into mixed.....and set your gateway into LAN & WIRELESS...
Jul 08, 2010 | Linksys Cable Modem
HOW TO USE INTERNET IN MORE THAN ONE PC FROM LINKSYS WIRELESS G B
You have two ways on how you can get other computer online through this router. First, you can wired them (using an Ethernet cable) to one of the Ethernet ports on the back of the router. They are the ones labeled 1, 2, 3, and 4.
Second is through wireless, but those computers that will connect through wireless must also have a wireless adapter to be able to pick up the signal that this router is broadcasting.
Feb 12, 2010 | Linksys Wireless-G WRT54G Router
Linksys wrt54g SRX200. I can connect to my router
It appears the connection between the Linksys and the modem is not working.
Try a different LAN cable.
Check the LAN cable from the modem to the Linksys, it should be connected to the WAN/Internet port on the Linksys.
Dec 19, 2009 | Linksys Wireless-G WRT54G Router
Linksys WRT54G connects but is homicidally slow, and won't renew DHCP if signal falters!
Linksys wireless firmware is know for it slow connection issue. I have one and my lan speed was double then my wireless speed. I put the third pary firmware from www.dd-wrt.com website and now my wireless and lan speeds are the same.
Nov 12, 2009 | Linksys Wireless-G WRT54G Router
Linksys wrt54g with sony vaio webcam won't work
check the LAN cable from the internet connection going to router.make a sure that wire is OK.if the wire connection is a ok go to your PC/unit then make sure the Lancard/wire less lancard driver is complete or remove the Old lan/wieless lan drivers and install a new or update the drivers.good luck and have a nice day
Jun 15, 2009 | Linksys Wireless-G WRT54G Router
Configure Modem Echolife HG520s With WRT54G OR WRE54G
Not sure if I understand properly but your router should have a WAN port or an "Internet" port
your modem should be connected to it and your PC should be on any of the LAN port
Apr 04, 2009 | Linksys Wireless-G WRT54G Router
Zyxel modem and wrt54g modem
You need to put the zyxel p600 into bridged mode
Mar 26, 2009 | Linksys Wireless-G WRT54G Router
Will a computer with 10/10 LAN connect to my wireless LAN?
The 10/100 LAN is a wired connection. If it is connected to the wrt54g through an ethernet cable yes it will see anything on the wireless connection but if you want the computer to use a wireless connection then you will need to get an 802.11B or 802.11G wireless adapter. The wireless adapter does not have to be Linksys but it does generally make thing easier if you use all the same brand.
Nov 29, 2008 | HP AdvanceStack 10:10 LAN Bridge MB...
Linksys Wireless-G WRT54G Router Logo
427 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
