Good picture but lost the audio when I rolled the big screen a few inches to sweep behind it
  • 1 more comment
  • Anonymous Jun 06, 2008
    no audio after moving tv to another room -
    tv spker is on.
  • Anonymous Jun 10, 2008
    same problem moved tv and lost audio
  • Anonymous Sep 25, 2008
    Moved the TV from one house to another and lost all audio!!
  • 3,037 Answers
By rating your chat as such I will not get paid, any higher rating will enable myself to get paid, please change it if you feel a need to, thanks
Posted on Apr 24, 2008
Big black square in middle of screen picture top to bottom about 36 " wide good audio and picture 6" on right and left side displaying.
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 26, 2012 | Hitachi 55HDS69 55 in. Plasma Television
The color on my Phillips 60 rear projection big
that means that the phone needs to be unlock by the network provider
Mar 13, 2010 | Philips 60PP9202 60" Rear Projection...
Toshiba 26 inch lcd tv/dvd combo lost picture
I have same problem with a 7 month old Toshiba 26LV610U LCD TV/DVD combo.
Feb 10, 2010 | Toshiba 26HLV66 26 in. LCD TV/DVD Combo
Old magnavox 52 inch big screen tv - screen rolls, jumps, loses c
the screen on my hdtv has alot of marks on it how do i get another
Feb 26, 2009 | Philips Magnavox 51MP392H Rear Projection...
My mitsubishi 1080 WS-55807 has lost the picture
Unplug the set, remove all other audio/video components, go open front door, and roll it out to the curb.
Nov 24, 2008 | Mitsubishi WS-55807 TV
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Sep 28, 2008 | Philips 50PFP5332D 50 in. Plasma...
Sony Kp-51hw40
Sounds like a bad solder connection in the sweep power supply. Not a repair for the novice I'm afraid. If you get it fixed before the set goes out completely, it should not be that expensive of a repair. Good Luck
Jun 03, 2007 | Sony KP-51HW40 51" Rear Projection...
No picture
If the screen is completely black, do you feel static from the screen? If not then you probably lost your High voltage to light up the screen. If you do feel static, and in a darkened room can see a gray screen, then you have lost your video signal internally, and it could be anything from a video IC to the microcontroller chip which would be an expensive repair. Since you see some pixels in the middle of the screen when the TV is off, I'll assume the High voltage is good, and besides the video circuits, it's possible that if you had a defect in the vertical sweep circuits, it might kill the video as well. May want to get an estimate or if it's over 8 years old, replace it.
Dec 19, 2006 | Panasonic PV-DF2704 27 in. TV/VCR/DVD...
No picture
You have an intermittant vertical sweep circuit! It could be the vertical out put IC solder connections on the printed circuit board, or maybe the IC itself has poor connections between the IC and the contact legs that mount the IC, or another componet in the vertical sweep circuit. If you know how to solder and unsolder, work on printed circuit boards, then you shoul have no problem replacing the vertical sweep circuit. Good Luck
Oct 09, 2006 | Panasonic CT-25G6 25" TV
Picture has horiz. lines
There is no vertical hold in the tv circuits now adays. You may find a vertical center or a vertical height. Your problem sounds like (if it has PIP Thats Picture in Picture) its in the PIP module and its a small module that stands up and most models of Mistubishi this module is no longer availabvle. The problem with the module is the small pana caps are leaking and ruins the PC traces. I have heard that theres a kit available on E-Bay to jump out this module. Now if its not the PIP model then it could be a few capacitors in the vertical sweep circuit. Also the B+ feed off the Flyback that supplies voltage to the vertical output IC could have a bad or leaky capacitor in the circuit. If your not a tech or solid state troubleshooter theres not much you can do and SHOULD take this set in to a repair center. Good Luck
May 21, 2006 | Mitsubishi VS-45605 50" Rear Projection...
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
