Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
Floor brush won't spin
    President:
  • 1,673 Answers
Check the filter screen to make sure it isn't clogged, if yours has that foam filter under the dirty water tank lid, there needs to be a 1/4 or so space beween the filter and the top of the lid. Other then that your turbine may be bad, that is what drives the brush block. Take the brush block out, is the shaft on it or did it get broken off, if it did, that shaft is what goes into the turbine and it can't turn if it is broken.
Posted on Apr 24, 2008
Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
I can think of three things that could be wrong.
The easiest one is that the brush has hair and fluff wrapped around its bearing. This happened to me and was causing a burning rubber smell. Turn it over and remove the base plate. Lift the belt by putting a piece of cord under it and slide the brush out. Remove one end of the brush and slide the spindle out. Clean all the hair out and reassemble.
The internal drive belt is worn, or the nylon bush that it runs on.
The clutch is worn out.
The last two are not as easy to fix as the main drive belt is enclosed in the centre of the clutch. There are videos though that show you the process. Have a read and a watch, but try my first tip first.
  • Dyson DC25, DC29 - Resetting the brush bar (Official Dyson ... www.youtube.com/watch?v=q--faamcC7g
    • BY ASKDYSON
    • 1 MIN
    • 127K VIEWS
    2011-09-29 · Want to watch this again later? Sign in to add this video to a playlist. How to clear and reset the brush bar of your Dyson DC25 or DC29 upright ...
  • Dyson DC25 Upright Vacuum Cleaner - Support ' Dyson.com www.dyson.com/Support/dc25/DC25-ANIMAL Dyson DC25 Upright Vacuum Cleaner Support. Skip to main content X. Shop. Shop vacuums; Shop air treatment ... The Dyson Helpline is available during the following ...
  • My dyson vacuum cleaner brush will not spin. It is not the ... howtomendit.com > ... > Household Appliances, Vacuum Cleaners My dyson vacuum cleaner brush will not spin. It is not the belt. ... How can I fix my dyson dc25? The turbo button is not working... Click here for the answer:
  • Brush bar not rotating - Dyson www.dyson.co.uk/.../brush-bar-not-rotating Brush bar not rotating. ... to ensure vacuums containing Dyson Cinetic™ science maintain constant suction. ... tested at the cleaner head.
  • The Brush Won't Spin on My Dyson Vacuum Cleaner ' eHow www.ehow.com > Home > Home Appliances > Other Home Appliances 2015-06-29 · eHow; Home; Home Appliances; Other Home Appliances; ... My Dyson Vacuum Cleaner's Beater Brush Won't Spin; Dyson Vacuum Brush Roll Not... My Dyson ...
  • Dyson DC25 brush won't spin when touching the floor. If I ... www.fixya.com > Forum > Vacuums > Dyson 2016-03-18 · Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
  • Dc25 animal. front brush not working - Fixya www.fixya.com > ... > Dyson > DC25 Animal Bagless Upright Vacuum 2012-03-29 · ... Dyson DC25 Animal Bagless ... dc25 animal. front brush not ... I have a Dyson DC-25 animal. My brush bar did not spin and has been replaced with a ...
  • Dyson DC24 Brush Bar Motor - Dyson Medic - Dyson Medic dysonmedic.co.uk/dyson-dc24-brush-bar-motor It will not spin when the ... Dyson DC24 Brush Bar ... Unit Motor Dyson DC25 Dyson DC25 beater bar Dyson DC25 brush bar Dyson DC41 Dyson DC50 Dyson Motor Dyson ...
  • DC25 brush bar not working - Dyson Spare Parts with Free ... manchestervacs.co.uk/DysonForum/index.php?topic=738.0 DC25 brush bar not working ... My brush bar stopped working on my DC25 ball the other day. ... Manchester Vacs Dyson Engineer
  • Dyson DC24 - Resetting the brush bar (Official Dyson video ... www.youtube.com/watch?v=akGLQ7UbctY
    • BY ASKDYSON
    • 2 MIN
    • 275K VIEWS
    2011-09-29 · How to clear and reset the brush bar of your Dyson DC24 upright vacuum cleaner. DC24's brush bar is engineered to shut off for protection if ...
  • Mar 18, 2016 | Dyson Vacuums
    Tip
    Brush won't turn after cleaning out debris, belt is fine.
    I have the Dyson Animal, the purple one. I frequently have to take the bottom apart where the brush is at to cut all the threads and hair off the brush. This last time it would not spin afterward. As far as I know there is no reset button, however, I did find out that it was switched to bare floors and THAT is WHY the brush was not spinning. Once I switched it back to carpet all was well. I have had this for years and never knew that the brush did not spin when it was on bare floor setting. Hope this helps!
    on Jun 26, 2011 | Vacuums
    Our DC41 is impossible to push on carpet. Is there an adjustment to do? Almost like there is too much suction.
    See if the following information can help.
    CARPETS OR HARD FLOORS
    • The brush bar will always default to 'ON' (spinning) each time you switch the
    appliance 'ON' and recline it for cleaning.
    • The brush bar will not rotate when the appliance is upright.
    • To switch the brush bar 'OFF' (e.g. for delicate rugs and hard floors):
    - switch the appliance 'ON'
    - recline the appliance
    - press the brush bar 'ON/OFF' button - the brush bar will stop spinning.
    • The brush bar will automatically stop if it becomes obstructed. See 'Brush bar -
    clearing obstructions'.
    • Before vacuuming your flooring, rugs and carpets, check the manufacturer's
    recommended cleaning instructions.
    • Some carpets may fuzz if a rotating brush bar is used when vacuuming. If this
    happens, we recommend vacuuming in 'hard floor' mode and consulting with
    the flooring manufacturer.
    • The brush bar on the appliance may damage some carpet types. If you are
    unsure, turn 'OFF' the brush bar.
    Dec 31, 2014 | Dyson Bagless Upright Vacuum DC41 Animal
    Is the beater brush on the Bissell Helix NOT to spin on bare floor setting?
    Hey Tony! The brush does continue to rotate when using the vacuum on the bare floor setting.
    Feb 02, 2013 | Bissell Cleanview Helix Deluxe Bagless...
    Dyson dc25 off button won't turn off, brush button won't engage brushes
    Hi ... did u get this fixed cos mine is the same hve to switch off on the wall?
    Sep 22, 2012 | Dyson DC25 All Floors Bagless Upright...
    Dyson dc14 brush won't spin
    Liz thank you so much for the quick fix. Moving the carpet/floor knob a few times reset the belt. My method of slamming it against the dresser did not produce the desired results.
    Feb 10, 2012 | Vacuums
    The brushes won't spin. I put new brushes on and it still doesn't spin.
    Usually when the brushes won't turn it is due to a bad turbine. Insert a screwdriver into the square hole that the pin on the brush fits into, and see if it turns. If it is seized up, the turbine assembly will need to be replaced.
    Jun 28, 2011 | Hoover SteamVac F5914-900 SpinScrub...
    Brush roller not spinning. belt, spindle okay. roller taken out and cleaned, no thread. replaced but no dice. ???
    Use only BISSELL Style 10 Replacement Belts (#32074) in your BISSELL PowerForce Bagless.
    1. Unplug cleaner from electrical outlet.
    2. With Rotating Floor Brush removed from vacuum cleaner, grasp old Drive Belt and remove from Motor Pulley. Discard old Drive Belt.
    3. Place new Drive Belt over Motor Pulley and stretch other end over Rotating Floor Brush in the space between the bristles.
    4. Place ends of Rotating Floor Brush down into slots on sides as shown.
    5. Turn Rotating Floor Brush by hand several times in the direction of Motor Pulley. If properly installed, Drive Belt will center itself on Rotating Brush.
    6. Reposition Brush Cover and snap back into place. Check to be sure all three latches are secured.
    7. When you turn on the vacuum, do you see the motor that spins the belt spinning at the bottom? If not, it sounds like you may have a burned out motor.
    If suggested solutions do not correct the problem, call:
    BISSELL Consumer Services 1-800-237-7691
    Monday - Friday 8 a.m. - 10 p.m. ET
    Saturday 9 a.m. - 8 p.m. ET
    Jun 01, 2011 | Bissell 6594 PowerForce Bagless Upright...
    Roller not spinning on hard floors
    after 2 weeks it should be still under warranty. but my guess is you have hair etc wrapped around the brush tip vac so you can see brush(es) remove all string,hair etc... from around the brush area (may have to remove bottom to get all the hair etc... stuck around it. it also may have been jammed up pretty tight and continued use could snap the belt or burn out motor
    Aug 14, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
    Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
    Top Hoover Vacuums Experts
    Gerry Harvey
    Gerry Harvey
    Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
