Question about Refrigerators
I have a Whirlpool Refrigerator, model # ET186KXGW01 it started out by water leaking inside frig. I let it slide cuz I was hoping it would stop. Now I have freezer frosting up and frig. isn't cooling much. I am trying to do this myself to save money. Please help and Thank You
  • marshav Jul 29, 2010
    Thank u
    Genius:
  • 1,478 Answers
The answer to these questions lies in the way the freezer/fridge combo works. The freezer is where the cooling coils are located. Then air is moved over the coils and circulated through the fridge side by a small blower or fan. The problem arises when the air is not circulated for some reason.
The reasons the air is not moving is usually two reasons
  1. The fan or blower has failed.
  2. The coil is covered over with ice and blocks the air flow.
The first reason is pretty simple to fix, you simply replace the air circulator and things are good again.
The second reason can be more difficult.
1. The timing device that runs the defrost cycle of the refrigerator is defective.
2. The heater coil that melts the water is shorted or not working
Usually the first thing to check is the heater coil. If there is resistance through the coil then most likely it is still good.
The timing device can be an advanced defrost control board or a mechanical timing device.
If the heater coil checks out to be good then the problem should be the timer.
For most situations, unplugging the refrigerator and allowing it to defrost on it’s own will get you going temporarily, till parts can be shipped to you. That will melt the ice and give you a few days or a couple of weeks till it ices up to the point where it will not work again.
So you can see here, the problem can usually be traced to one of three things.
  2. The timer device
  3. The electric heater coil
By checking these parts you can isolate your problem and fix it.
Take care.
Posted on Jul 29, 2010
Whirpool Gold refrigerator model GR2SHTXKQ01 (water leaks from dispenser. This model has freezer on top, dispenser is inside refrigerator.
Water valves leak like a leaking faucet sometimes. They just will not close all the way allowing water to bypass the valve and either drip at dispenser or drip and make a mess in freezer. Your model takes a=> 2219592 Water Valve - Dual Outlet
Change the dual water control valve and I believe this will solve this problem, Thanks Sea Breeze
Jul 11, 2012 | Whirlpool Refrigerators
Water leaking from the freezer into the frig through the vent in top of frig Model#ETIPHKXPQ00
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 21, 2011 | Whirlpool Refrigerators
Water is leaking out the bottom of the unit. It has a water dispenser inside the frig
Hi
There are various reasons as to why your refrigerator is leaking.Please check this bellow link to troubleshoot your issue:-
http://www.repairclinic.com/Refrigerator-Troubleshooting?red=Refrigerator-Repair-Help#itleaks
http://www.ehow.com/info_7972651_refrigerator-leak-out-bottom.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
May 03, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerator leaks water on the inside underneath the freezer
The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component. Mine recently caught on fire at this device that is located near the compressor. If you would like to be a part of the petition for a recall on this appliance contact me at jboooor@hotmail.com
Jun 09, 2010 | Whirlpool ET1FTKXK Top Freezer...
There is water leaking into the inside of our refrigerator, any idea how to fix it? model ET14JKXGW02 MFG 12/99
This is usually from the defrost drain being clogged. I put some instructions together, follow the link below to see them and let me know if it is helpful.
Water in Frig
May 22, 2010 | Whirlpool Refrigerators
My whirlpool refrigerator is leaking.....I have a freezer on top frig and it is leaking on the inside.....any help would be great
you have drain plugged, remove freezer back panel you will see ice under coils use hair dryer too melt ice and find drain hole keep heating hole until the water drains
Apr 24, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool Refrigerator water leak through Ice dispenser
You need to remove the ice maker and open the front carefully. It has small micro switches inside it and it sounds like one that opens the water control valve is stuck in the on position. Be careful not to loose the arm spring and how that goes back together as you take it apart. Sea Breeze
Sep 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water leaking from bottom of unit
check to see if if drip pan leaking may be water line
Apr 07, 2009 | Magic Chef CTF1826AR Top Freezer...
Whirlpool frig model -et9fttxlq11 serial-9m5110756 inside at very back water comes out of this opening
Your issue is;
"whirlpool frig. model -et9fttxlq11,serial-9m5110756
inside at very back water comes out of this opening"
Thank you for providing a valid model number!
This link shows exploded view of your model.
http://www.repairclinic.com/0100_2.asp
Water can leak from these areas:
The inside ceiling of the refrigerator
The inside back wall of the refrigerator
Self-defrosting refrigerators usually dispose of the water generated during the defrost cycle via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website).
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
In some refrigerators, the defrost water is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain--usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction.
    The inside ceiling of the refrigerator Water accumulating on the ceiling of the refrigerator is usually caused by a clogged drain in the freezer section beneath the evaporator. The clogged drain will cause water from the self defrost cycle to leak into the divider between the freezer and refrigerator. This water may then freeze and cause condensation build-up on the refrigerator ceiling. The solution to this problem begins with unclogging the drain. It may also be necessary to remove the entire freezer/refrigerator divider to thoroughly dry the insulation in the divider. Occasionally the insulation needs to be replaced to prevent a recurrence of the problem. This can be a big job – you may want to hire a qualified appliance repair technician.
    The inside back wall of the refrigerator In some refrigerators, the water from the defrost cycle is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain - usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction.
    Please show your appreciation by rating my solution.
    Thank you,
    Dave E. (Illeagle)
    "Your satisfaction is my personal reward"
    Jul 24, 2008 | Refrigerators
    Whirlpool refrigerator leaks water inside the frig. It gathers in the pan under the lowest sliding drawer. Possibly something to do with the icemaker? I don't use the icemaker -- I flipped up the bar...
    Its a done deal...:) On MY whirlpool MODEL # ETICHMXKBO3 I found the drain hole frozen.. There was some debris and clogged it up and water froze up behind it causing the deck of my freezer to fill and freeze up and cause the water to drain into the fridge. Solution: remove the ice maker(if equipped) remove the rear aluminum cover. I used a heat gun and melted the 1 1/2 of ice build up and softly with a screw driver clean the drain. When drain is visible use scolding hot water until it starts flowing to the bottom tray. I used my air compressor to finish it off....
    Jun 18, 2008 | Refrigerators
    Refrigerators Logo
    118 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Marvin
    Marvin
