Question about HP PSC 1610 All-In-One InkJet Printer
I have installed new cartridges the colour prints perfect but the black is blurred with lies through it. i also found a small t shaped rubber piece about about 4mm x 6mm in the paper tray could this be the problem. thank you. janet.
  • 700 Answers
This rubber piece can be actually locket from printer rollers, but, returning to your smudgy printing
1. remove cartridges from the printer
2. check if there is bit of paper stuck anywhere in paper path, if so, remove
3. check if rollers on paper path are clean
4. touch bottom of the cartridge with absorbent tissue to check if ink is flowing through, if yes then insert cartridges back and print test page.
5. if cartridge do not allow inkflow, check what solvent is used (water, isopropyl alcohol or methylated spirit - this which do not cause precipitation is correct solvent), soak absorbent paper (tissue) with proper solvent and whipe head of the cartridge with it, 6. put drop of the solvent on golden knobs inside seats of the cartridges of the printer, allow it to soak in, wipe off with lint free tissue and put another drop of solvent in. allow soak in,
7. install cartridges back, print test page, it should start printing very weak and improving as it goes through the page (solvent will be printed first)
8. create "strip page" one line yellow, white space, one line cyan, white, magenta, white, black - print that page, this print will clean printheads and establish good inkflow.
all ink printers must print at least one page per week as to keep heads free of gum and ink in flow.
Posted on Jul 28, 2010
Lexmark 3600-4600 - Documents print out blurred
It would be worth a try to insert a different / new cartridge to determine if it's the root cause of the problem. If you're hesitant about buying, try to contact Lexmark Technical Support Center for assistance.
Mar 29, 2012 | Lexmark X4650 InkJet Printer
Blurred printing new black cartridge installed - we still have blurred printing.
It is problem on cartridge setting may be it select color cartridge.or clean your black cartridge check nozzle print test.
Feb 12, 2010 | Canon PIXMA iP5300 InkJet Photo Printer
The cartridge keeps getting jammed on the left side and when it prints the left side is printing double. I found a small black rubber piece rectangular shaped but with 2 square corners and rounded on the...
I will replace the printer. There are so many on sale now, I'm not going to waste money trying to fix it when I can get a new one for what it would cost to fix it.
Dec 18, 2009 | HP Officejet 5610 All-In-One InkJet...
Canon i9100: colors printing incorrectly
I've had the Canon i9100 since 2003 and have excellent photo printing results. In 2009 it started playing up and I'd gt some banding. More recently, black didn't want to print. It was as though the black ink in the print head got dry some days.
April 2010 - The colours started printing strange and I bought a brand new print head and installed it. Only takes a minute. Still had an issue with photo printing. Black and white was excellent but colours weren't true.
Found advice online to try cleaning the print head to print head carrier electrical contacts by rubbing them with a rubber eraser.
I did that and now I'm getting perfect colour photo prints again.
I had been thinking about buying a new A3+ printer but this is old printer is now working as good as new.
Nov 16, 2009 | Canon i9100 InkJet Photo Printer
Won't print because color cartridge is empty and l don't need color
Try changing printing preferences/properties. Click on option for color, then click on box for "black ink only" or similar. Try now. If you still cannot print after changing preferences/properties, you will need to replace color ink cartridge due to manufacturer's built-in software that prevents printing when ink is low. Great for the ink companies!!!
May 18, 2009 | Cannon i70 Printer
Refilled ink cartridges problem colour
this is not a printer problem, you have a problem with colour cartridge! u can fix this in 2 diferent way: 1. replace the colour cartridge with new one, or gently clean the nozzle cartridge with a wet tissue until the cyan colour mark a line on the tissue just like the others colours: yellow and magenta. maybe must repeat this several times.
Sep 13, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Black cartridge not activating properly
There's a blue protective strip on the bottom of the cartridge when you buy it, and it needs to be removed before you put the cartridge in the printer.
May 16, 2008 | Lexmark X83 All-In-One InkJet Printer
Tri Colour cartridge inserted is not intended for use in this printer msg
Try to clean the print cartridge contact points with a good rubber eraser and clean the printer side cartridge contacts with good lint free cotton cloth. Then first insert Black cartridge and then colour cartridge. Use some more pressure while attaching the cartridges.
Apr 22, 2008 | HP PSC 1315 All-In-One InkJet Printer
Black ink
Leanne83 and jzig - I presume your problems are solved by now. If not, please respond with a new comment.
Guest
Are you confident the new cartridge is full and in-date? Can you confirm that the old cartridge was not removed until immediately before the new cartridge was installed. Did you remove the yellow tape from the new cartridge before you installed it? Was the black cartridge change properly completed such that an ink charging cycle occurred. Have you carried out any head cleaning cycles? If not, do it. Have you done a nozzle check print? If not, do it. Any sign of black ink? Yes, but not perfect? If so do a couple more head cleans and nozzle checks. If still not perfect, let it rest for 24 hours to disperse air bubbles. Then repeat.
If you have already done lots of head cleans with no result, and you're SURE you have a good ink cartridge properly installed, then you can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try up to 3 head clean/nozzle checks again. If still nothing, post a new comment with full details of what you have done and the results.
Nov 17, 2007 | Epson Stylus C40UX InkJet Printer
HP PSC 1610 All-In-One InkJet Printer Logo
96 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
