Question about Dishwashers
Fluidmaster S2DBL the stopper sticks up position who do I fix this.
If you're talking about the fill tube sticking in the latched position (not dropping), it's probably due to a sticking flush cable. Call Fluidmaster and they'll sen a replacement part.
Posted on Feb 05, 2011
  • Dowutyalyk Sep 10, 2011
    I noticed this same problem on mine. I took it out and inspected the assembly. I noticed the bottom rubber seal had swollen to where it jams up on the side of the housing whenever the stopper is in the up position. Rubber seal absorbing water over time, then eventually getting stuck every once in a while? Now, to find out if fluidmaster knows about this issue and if they have a fix for this.
Fluidmaster
First shut water off at stop than flush all the water out of the tank next take a sponge and get all the water out of tank next unsrew the supply line from the valve under tank than move out of the way next unsrew the nut on the valve of fluidmaster than pull the fluidmaster out of tank stick the new fluidmaster in tighten nut srew the supply line back on turn on stop and let the tank fill up thats it if the fluidmaster dont shut off press the handle let some water out and adjust the fluidmaster screw Tip the water should stop a 1/4 inch below the flush valve tube in center of toilet
Jul 11, 2016 | Fluidmaster Plumbing
Grohe drain stopper installation
They adjust by twisting them.
Jan 20, 2014 | Plumbing
Fluidmaster fil valve float sticks
Give it a slight turn to stop it from rubbing on the side
Nov 26, 2013 | Fluidmaster 400A Toilet Tank Repair Fill...
How to fix a dripping toilet
if the fluidmaster,itself is leaking, there is a rubber disk in the base of fluidmaster, replace disk. however, i can almost promise you the dripping you hear is from a bad flapper. replace with KORKY brand flapper. buy the basic black one, with no water saving gadgets on it.you will see cheaper black ones, but get the KORKY
Dec 20, 2012 | Fluidmaster S2DBL Dual Flush Toil System
Fluidmaster 2sdbl keeps running after flush
turning the water shutoffs off and one can cause debris/sand/grit to move around in the lines. Check the seal for grit, rub your finger along the inside where the seal is. Lift up the overflow tube and run finger along the bottom , better, get an old toothbrush , cut off most of the handle and "brush" the bottom of the seal, then turn the brush around and brush up on the part that closes down on the seal when you let the overflow tube go
Sep 22, 2012 | Fluidmaster S2DBL Dual Flush Toil System
Brand new fluidmaster 400 installed but toilet still leaking
Is The water leaking in or out check the stopper is good and that it is seating right
May 13, 2012 | Fluidmaster Plumbing
Fluidmaster Dual Flush Valve S2DBL won't flush.
Fluidmaster S2DBL Dual flush valve - would not flush
The dual flush wouldn't work at all. So I slid the lid off part B (lever mounting base) and found the ball end of flush cable was not in the mating hole on lever arm. With needle nose pliers I pulled and pushed the ball into the hole and slide lid back on till it snapped. Snapped B to C (handle) - problem solved!
RAP
Jan 29, 2012 | Home
I have cleaned the toilet seat in hot water and the plastic glued stoppers for the seat have fallen off and the glue has become hard. Where do I get new stoppers from.
Hi seacenter30
Why buy new seat stoppers when all they need is just re-glueing.
Get yourself a cheap hot glue gun (HomeDepot,Lowes,WalMart,etc) and a couple of hot glue sticks and apply the hot glue to the rubber/plastic stoppers and hold them into position on the toilet seat lid till the glue sets, just takes about 20 seconds...
Then the toilet seat will be good to go again...pardon my pun...:-)
Please take time to rate me thumbs up
Sep 14, 2011 | Prestige Home
Removing arm on#88592 to stick thru side of tank
If you are referring to the flush knob, the nut is reverse threaded. Remove the nut, then swing the arm to the left, and pull straight out of the tank.
Dec 23, 2009 | Fluidmaster Plumbing
Dishwashers Logo
986 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
