Question about HP Compaq 6735s Notebook
My hp 6735s shuts down all of its own after 10-15minutes.
Hi my laptop was working all perfectly last night.next day while working it shuts down all of its own.& from this own ward this problem persist.
i would like to add some history here that my laptop battery got problem at start of jan 2010 that laptop shuts down even battery was full without warning. i removed it and start using at home without battery since January but now it starts shutting down all of its own even plugged on.
  • 358 Answers
This is likely to be as a result of your processor over-heating, maybe because of your environment, or because the fan is not cooling the processor properly again.
Therefore my suggestion would be for you to unscrew your laptop (If you can do it by yourself), and try to clean, or better still replace your processor fan.
Also clean the air-vent where air is supposed to enter the laptop
If you cant do it by yourself, you can easily get a technician to do it for you.
Also, remove all your RAM(Memory Sticks), and clean the tip of the connector with an eraser, and re-insert it one after the other.
That is, if you have two of them, after you insert the first one, put on your system and see if it works, then do the same thing with the other one.
If the two of them works, them insert the them all. but if it is just one that worked, just remove the other one that is not working and replace it.
I have actually had the same case before, and after doing what I've just told you, it stopped behaving like that.
Then always make sure that your laptop is in a well ventilated, cool environment and that the environment is free from dusts.
Kindly let me known how it goes after you've tried this.
Hope this helps you out.
Posted on Jul 29, 2010
  • mike92_99 Jun 10, 2011
    Dear Damilare,
    I have tried to screw my entire laptop open and advanced cleaned the fan and air supply.
    After this the temperature dropped from 60-70 degrees celcius to 30-40 degrees celcius.
    Despite this good result the laptop keept shutting down, without showing a blue screen. What can this be?
    Thank you for the support message, I have also checked the RAM.
    With kind regards, Mike
HP 6735s will not boot.
Remove the battery, place the laptop in a warm, dry and sunny spot for several days so it dries out completely. Replace the battery and see if the laptop boots up.
If not then the laptop maybe beyond repair, especially when water was spilt on the laptop when it was running. This could have caused some electronic components to short out.
Feb 26, 2012 | HP Compaq 6735s Notebook PC
6735s laptop keeps shutting down
You can Clean you heat sink and change the heat pad of processor. i am sure this will help
Dec 27, 2010 | HP Compaq 6735s Notebook
Hi i have hp 6735s laptop & i it's battery was very good but in last couple days it began to shut down after i plug off the power by 2 or 3 minutes without showing any message to notify me &...
NO OS stated ?Operating system" we cant never ever guess that.
remove the battery , test the PC with no battery?
does it run perfectly now ? yes/no.
if yes and not with battery then the battery is bad or not charged.
this is step 1. of a long process.... PCs are complex
I can not understand your post at all. (cept its power issue)
the full PCs model was not stated,
Is this LT mobile? or always on a desk.
I cant just know how you use a laptop ever.
on desk or in an airplane or at STARBUCK's is 3 different usages.
on a desk? Ill answer, the others are vastly more complex !
DESK bound 110 LT:
  1. turn off sleep and hibernate modes (CP + power settings)
  2. turn on , the same page, "laptop power button turns off PC":
  3. make sure the your software is from HP at your HP support page, we are NOT HP. here.
  4. keep the battery out, of the pc, charge it and park it so when need it not bad or dead. leave it out. run on AC power only.
  5. my wild guess is PC goes to sleep and sucks the battery dry as all do eventually or all do on weak /bad batteries. keep the AC power pack plugged in to wall power all the time. hint hint.
this PC is a very old COMPAQ
HP does not support this now, it's too old (why not upgrade)?
so to fix it , takes tedious steps.
my post above begins this process....
the one thing I cant unstand is this.
plug off? (what? is this)
Jul 27, 2017 | HP 6735s Notebook Laptops
Hp 6735s was used last night and shut down properly but this morning turning it on the system continue booting without displaying anything on the screen which makes it blank / black........ Please I need...
If there is a display switch in the functions on the keyboard (most likely will look like a laptop monitor or a computer monitor on the keyboard). Press the function key and the button associated with that and wait 3 to 4 seconds (you may have to press it multiple times) If you have anything in the vga slot, then it may think a monitor is plugged in and won't display the laptop screen.
If none of the above work, then maybe your computer is having a systematic failure, or the screen connector is loose.
Jun 14, 2010 | HP Compaq 6735s Notebook
HP 6735s screen black out on startup.
The problem is a damage to the MB by excessive heat produced by Nvidia GPU. The only way to fix this permanently is to take out the MB and reflow the GPU with heat. You can find a video on youtube how to do it. You must take out the piece of gel between GPU and cooling unit and replace it with copper bar or penny made prior 1983 - still made out of copper. Also clean the fan. Use heat transfer paste like arctic cool - not a glue, on both sides of the penny. Install win7. Win7 does not use the coprocessor and will help to ran the notebook cooler. Install speedFan 4.40 - free utility to see what the temp is of your GPU and CPU. If you did good job it will stay around 55C. If your HP notebook is still running check the temp. If the GPU is running 80C or more it will melt the connections on the MB and quit working sooner or later.
Feb 28, 2010 | HP 6735s Notebook Laptops
HP Compaq 6735s battery light orange blinking
Have you tried another power cord? If you try another power cord, and it still does the same thing, then I think your laptop is having a power problem. You need to take is to a technician to fix the problem for you.
Best wishes.
Nov 28, 2009 | HP Compaq 6735s Notebook
Hp 6735s wont shut down
using the button to shut it down is not recomended, but if you do not have programs running that is loading/saving data, it should be ok, in some cases it could damage the computer, you should see if it is under worrenty and get it looked at or call tech support and see if they can help
Sep 28, 2009 | HP Compaq 6735s Notebook
How to replace HP 6735s
It's right under/next to the processor fan, locating it should help you determine your best course. I would completely disassemble the laptop to remove the motherboard for the processor upgrade.
Feb 12, 2009 | HP Compaq 6735s Notebook
HP Compaq 6735s Notebook Logo
398 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
