Question about True 72 cu. ft. / 2039 liter Commercial Freezer T-72F
Do freezers have a thermostat
Sieral 6900223, freezer will only cool to 10 degrees f. is there any adj.
  • True Master
  • 43,501 Answers
If the unit is a bit overcharged it will only go so low and then not cool any lower....you could try to remove a bit more charge and then see what happens... also check to see and make sure that the low press. switch is not cutting the compressor off...as the temp. drops so does the press. and if the switch setting is too high it will cutout to soon...
So... if the compressot runs continuously then drop charge...if it is cycling then sheck the switch...
heatman101
Posted on Jul 28, 2010
Ice cream not freezing hard
Ice cream needs to be at 10 degrees or colder to stay hard. Check your thermostat and move it colder if you need but give it 24 hours to stabilize to the new setting. Another thing you might check are the coils on the outside of your freezer. They will be on the back or underneath your freezer. What you need to look for is to see if there is any lint or dirt that might be built up on the coils. If they are real dirty they need to be cleaned off with a vacuum or an air hose if you have one. The dirt build up keeps the freezer from cooling efficiently and causes it to run warmer than normal. If all of that is clean and boosting the thermostat to a colder setting does not take care of it you might need to call a service tech. Hope this helps.
Jul 24, 2014 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer Constantly Runs.
Do you know what design temperature is for that freezer? Some are meant for 0 degrees others for -10 or 15. I would say you are trying to maintain -10 for a food freezer and trying to keep ice cream frozen. Ice cream freezers need to be colder than food freezers. I know it sounds dumb but look it up. Check the door gaskets to see that there is no leakage and the surrounding area should be no higher than 75 degrees, (otherwise it\'ll run all the time). Hope this helps and good luck.
Apr 20, 2014 | True 72 cu. ft. Commercial Freezer TS-72FG...
Freezer has quit freezing only a little over a year old. manufactor date 6/2009 compressor is running will only cool down to 50 degrees thermostat set on coldest.
Is the compressor continually running? If so then there could be a leak in the system or the compressor is damaged. If it's running then stopping, the cold control (thermostat) could be damaged.
Mar 06, 2011 | Kenmore 15 cu. ft. Chest Freezer 16542
Our under the counter freezer will not cool below 28 degrees. What are your thoughts?
Hi.
Try doing a defrost. If the freezer works after defrost, then it was the defrost system. If the freezer has auto defrost (evaporator comprising thermostat, timer, fan and heater), then the problem may restart after few days. In that case the problem is one of the parts comprised in the evaporator.
If the freezer does not cool after defrost, then temperature control (depending on model) may be responsible. Compressor and gas leak usually result in no cooling at all.
Regards.
Ginko.
Feb 11, 2011 | U-Line Freezer Origin Series 75FB 6 Cu....
Freezer thermostat was set at 0 degrees unit went down to -30 degrees. I increased temp on thermostat 3 degrees 3 times each over a 3 day period. The thermostat is not responding. I have the thermostat set...
I would start there. If the thermostat has an off setting, turn it there and see if it goes off. If not, try turning it to it's warmest setting while the box is cold to see if it turns off. To test to see if the relay/ contactor is stuck/bad, kill power to the unit (Unplug or turn off breaker). Disconnect one wire to the thermostat. Restore power. If unit runs, bad relay/contactor. If unit does not run, I'd replace the thermostat. Make sure the sensing bulb of the thermostat is in the conditioned space of the box or in the return air (intake) side of the evap so it can sense the box temp.
Aug 02, 2010 | Nor-Lake KLF7766C Commercial Freezer
I have a Frigidaire model GLFU206FWA upright freezer. The temperature control won't go above 10 degree F. This causes freezer burn on some foods after a period of time. Is there a way to regulate the...
Good day,
Manufacturers of freezers do not give the option of running the machine much above that temperature. Normal operating temperature for a freezer is about -2 to about 8 above F.
Otherwise people could accidentally set the temp too warm and cause a loss of food.
Some appliance parts houses carry universal thermostats that could possibly cover the temperature range your looking for, but 30 degrees is far to warm to preserve frozen food safely.
Jun 21, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
Temperature has dropped from a normal 18 degrees
The only thing that will make it cool to low is a thermostat. They wear out and get out of calibration. Check to be sure the temp sensor from the thermostat is tight on the mount. Its the little tube that connects to the evaporator that makes the thermostat work.
Jul 01, 2009 | AEG Freezers
Having temp problems
for a freezer would suggest a thermostat problem easily replaceable if you follow the removal of the old thermo.use temperature gauge to set to the required degree after instaling new thermo
May 21, 2009 | Freezers
Proper temp. range in freezer
Hi dgh1,
The freezer should stay within 5 degrees of 0 while in operation. While in defrost the freezer may reach as high as 20 to 25 degrees. If any higher temperatures are reached your food will spoil as they are defrosted and refroze everyday. If you find that the temperature is allowing your food to defrost you may want to replace your defrost thermostat. This device is located on top of the evaperator coil inside the back of the freezer. It is made to turn the heater off when a temperature of 55 degrees is reached. One other possible problem could be your defrost timer is taking to long to restart the cooling cycle after defrosting. I hope this will help you and please send any other questions you may have, I am happy to help. and dont forget to rate me.
Mike Anderson
Anderson Appliance
(865)945-3808
Oct 28, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
True 72 cu. ft. / 2039 liter Commercial Freezer T-72F Logo
79 people viewed this question
Top True Freezers Experts
Dennis Boxerman
John Tripp
John Tripp
christian nielsen
Are you a True Freezer Expert? Answer questions, earn points and help others
