Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
16hp b&s runs for 30 min or so and stops like it is out of gas. Yes the gas cap is lose and vent is not cloged
    Problem Solver:
  • 5 Answers
Its probably the fuel solenoid on the bottom of the float bowl. Remove it and replace with a float bowl bowl plug. You can leave the connector unpluged.
Posted on Aug 01, 2010
Cutting out
Almost sounds like a vacuum lock ("it feels like it running out of fuel"), like the gas tank isn't venting.
Air has to be allowed into the gas tank to replace the fuel leaving it.
Next time it dies, open/take off gas cap and see if it fires up right away, instead of having to wait 10 minutes.
If that works, start looking at the vent lines and see if it's plugged, or a one-way valve isn't working, or the line is pinched.
Dec 30, 2013 | Suzuki GSX-R 600 Motorcycles
Yardman seris 155 42 inch cut will only run for 30 sec to 1 min then stops why
try and run it with the fuel cap loose the vent in the cap could be plugged
Jun 04, 2012 | Garden
Powerwasher honda 13.0 running fine until gets hot after 30 min. cuts out every 5 mins after that.
If this has the thick silver gas cap, I have had similar problems on a number of these engines because it is a vented fuel cap and it will slow or even stop the fuel flow if they stop venting Try loosening or better yet replacing it. If that doesnt solve it then you may want to drain the fuel and put in fresh fuel Pressure washers will get water in the tank. Also make sure you drain the carb bowl. There is a bolt on the side of the carb bowl for that purpose.
May 08, 2011 | Honda 8 HP Engine
I read the guys problem with his Cub Cadet running and then stalling out. Here is my problem with my lawn tractor; I have an older model 125, runs great but stops running after about 30 min. when it...
My name is Dane and I am going to help you solve your problem.
Run your mower again and when it starts to run rough, loosen your gas cap. If it runs right again, you have a stopped up gas tank vent. clean it or replace the cap. Could be a bad coil too. I hope I've helped! Thank you! Dane
Dec 28, 2010 | Garden
My 2005 cadillac deville service engine soon light comes on i had it checked and no problems except check my gas cap light comes on Please advise. Thank you.
i have got this code before and it just be lose gas cap.....but have also had to replace the cap on a few of them .....the vent hole in it gets cloged....hope it helps
Nov 16, 2010 | Cadillac DeVille Cars & Trucks
16hp B&S ohv runs for 30min under load then stops 5min cool off starts runs 30 min new coil plug gas is venting adj valves
could be fuel vaporising.... re rout the fuel line away from heat sources this may help or the fuel is not getting to the carby fast enough....check fuel filter and lines for cleanness .
Jul 22, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Engine starts and runs,mows for 30 min then chokes
i had the same problem i talked to a repair shop and they said the coil was going bad and when it heats up there is a short in it (follow the spark plug wire back to the motor and the coil is there ) i replaced the coil pack and problem solved, hope this helps.
May 14, 2010 | Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
