Question about Kyocera Copystar CS-1820 Black and White Copier
How do I scan a document and get it to show up on the copmuter?
If you have the cd of kyocera, insert it and find addons then intall it first. when its done use some programs for example scanner plus.
Posted on Aug 02, 2010
What happen when you send a document to print and just showing blank
For your printing problem, try uninstall and reinstall print drivers in your computer. For your scanning something is wrong with the scanning unit.
Jul 26, 2016 | Toshiba Office Equipment & Supplies
Vertical Black Line
Probably there is nothing wrong with that scanner, just open and clean document feder with alcohol or glass cleaner.
Mar 29, 2013 | Canon PIXMA MX870 Wireless Office...
How to fix canon mp258 error code 2,140,2 when i scan douument
please help me....
I m trying to scan my document but it is showing error code 2,140,2 on PC and error code E5 at printer....my catridiges is empty is it because of that reason............
Aug 11, 2012 | Canon PIXMA Office Equipment & Supplies
When document is scanned to email--email copy shows a large yellow band down the left side of the document--shows everytime--replaced toner--cleaned everything--willl not go away
You need to isolate the problem first. Try scanning from the ADF and then scanning by placing the document on the glass. If the error shows on both then it is likley you have an issue with the scanner. If it only shows on the ADF copy then most likley the glass is dirty and needs to be cleaned. Curious as to why you replaced the toners to resolve a scanning issue? The scanner does not use any of the toner system, it is purely electronic.
Mar 22, 2011 | HP LaserJet 2840 All-In-One Printer
How do you setup your scanned documents to show up on my desktop as a pdf file?
  1. You can use A-PDF Image to PDF (free download here) to scan a document into PDF format and email it with only 2 steps:
    Click the "Scan paper" icon to scan documents from scanner
    Click the "Build to One PDF And Mail" icon to create a PDF document contains all of the scanne
    d documents and email them.
Jun 20, 2010 | Office Equipment & Supplies
How do i scan to my computer
As long as the printer/scanner is hooked up to the computer, you should be able to put the document on the glass face down, close the lid and press the scan button. The HP screen will pop up on the computer screen, don't mess with that, just let the document scan (it should show you the progress) and once it's done, it will ask you if you want to scan something else or be done. If your done, click done and then it will open up the HP window and show you what you scanned. To retrieve the scan, I always go to start, my documents, my scans and look for the current month and year, open that folder and then you have access to the document you just scanned. Hope this helps.
Mar 02, 2010 | HP Deskjet F340 All-In-One Printer
How do I transfer songs from I Tunes to Emerson MP3
all song that are download on a copmuter will transfer to my documents you and leave that open plug in the mp3 select open files and brag them accross
Jan 13, 2010 | Audio Players & Recorders
Brother MFC 665CW can no longer scan since networked
That's rather normal, if your printer doesn't have scan-to-email functionality, you won't be able to scan unless you connect it via USB to a selected machine.
Nov 20, 2009 | Brother Multi-Function Center MFC-665CW...
Lines showing up on document after scanned
Do you have lines, too when scanning a document?
In this case the scanner glas needs cleaning. Use a soft cloth and some glass cleaning solution and wipe the scanner glass. The lines should disappear.
Nov 12, 2007 | Brother MFC-3240C All-In-One InkJet...
Can't scan
This sort of thing can be down to the fact the settings for communication to the printer is separate for printing/faxing/scanning. So you will need to find the scanning device (will usually be called HP3050 regardless, or something along the lines of that) and make sure it's set to communicate through USB and no other means.
Sep 07, 2007 | HP LaserJet 3050 All-In-One Printer
Kyocera Copystar CS-1820 Black and White Copier Logo
60 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Chris Schutte
Marvin
Marvin
Adorjani Laszlo
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
