Question about StarTech.com StarView SV211K 2-port KVM Switch
I am in Wolves area and lost all indian channels. all others ch. are working.Can anyone help ??
Same here bro i dont no lol whats going on
Posted on Jul 30, 2010
Same here, same problem, anybody got the new TW 5A 01 code? or is this nag3
Posted on Jul 28, 2010
My mother has a Panasonic DMR-ES20D DVD recorder it plays back DVD's ok but has lost all tuned channels. When performing a auto tune it gets to ch 53 and appears to hang with error code U80 in the dis
could be its not digital, so it will not pick up any channels as they are now all digital not terestrial through the aerial like the y used to be. you need a digi box now to plug the recorder into
Dec 11, 2011 | Panasonic DMRES20D DVD Recorder
Hi ,i hv lost all the indian channels and sky movies channel.i hv a starview 5 box .is this a common problem or is it something to do only with my box .any kind of help wil be greatly appreciated thks
You can try a factory reset and rescan.
If you are in the UK, Virgin is changing to nagravision 3 (encryption) if your area changes, you will loose most if not all of your channels.
Google "virgin nagravision 3" for more info
Afterdawn.com also has some great info
Aug 27, 2010 | StarTech.com StarView SV231USB 2-port KVM...
Lost most channels any new codes please
Hi if you do a factory reset then turn off the box leave it off for about 30 seconds. turn it back on and do an automatic scan make sure your emu key is on and it should be working, thats what i did with mine.
Hope this helps.
Apr 29, 2010 | StarTech.com StarView SV211K 2-port KVM...
No output from one ch on old JVC VN-300 audio amp in stereo mode, power stage seems ok as both ch work ok in mono mode.circuit diagram, anyone?
The stereo/mono switch in most amps mearly feeds one channel to both channals when in mono. However it does mean that the Power Transistors (or whatever does the main output) is working on both channels. Therefore the dead stage is in the pre-amp part. Remember that the two channels will have the same parts as each other. The advantage is that one will have working parts and the other wont. So you can compare the two channels with voltage tests, using a multimeter.
Mar 31, 2010 | Audio Players & Recorders
I have 4/3/2 ch. alpine f-240 amp- i want to hook up four 6x8 3-way and one 12''sub. the amp has bass EQ on ch. 3. how would i hook it up and get the most power. can i put the 4 6x8 bridged all together...
run two 6x8s on each of the front channels of the amp. then depending on the sub you can bridge it on the rear channels.only if its a single four ohm. if its a dual 2 ohm sub run each coil on each channel. 1 coil-1channel. the other coil-the other channel. amp should run fine may run a little hot since it will be doing all it can do at a safe ohm load. just make sure it is mounted in a well vented area. should be safe.
Dec 25, 2009 | Alpine MRP-F240 Car Audio Amplifier
Need help on boxes cant get 7
Take 2 wolves over to the other side, take 1 Wolf back.
Take 2 wolves over to the other side, take 1 wolf back,
Take 2 chicks over to the other side, take 1 wolf & 1 chick back,
Take 2 chicks over to the other side, take 1 wolf back
Take 2 Wolves over to the other side, take 1 wolf back,
Take 2 wolves over to the other side.
Everything is on the other side of the river.
Apr 14, 2009 | Nintendo Professor Layton & the Curious...
7 squares cannot figure it out?
Is this the one with the wolf squares?
Puzzle No. 007 : Wolves and Chicks
Picarats : 50
Hint : Get the three wolves and three chicks seen below to the other side
of the river while obeying the following conditions.
-No more than two animals can ride the raft at the same time.
-There must be at least one animal on the raft in order for it to
move.
-If more wolves than chicks stay on either side of the river, the
wolves will eat the chicks, and you'll have to start over.
You can move the raft as many times as you like, but this feat can
be accomplished in as few as 11 moves.
Solution : Another classic puzzle:
1) Move 2 wolves to the other side.
2) Take 1 wolf back.
3) Move 2 wolves to the other side.
4) Take 1 wolf back.
5) Move 2 chicks to the other side.
6) Take 1 wolf and 1 chick back.
7) Move 2 chicks to the other side.
8) Take 1 wolf back.
9) Move 2 wolves to the other side.
10) Take 1 wolf back.
11) Move 2 wolves to the other side.
----------------------------------------------------If this isn't the right one, visit http://www.gamefaqs.com/portable/ds/file/936050/51933
GAMEFAQ's has a ton of guides to help you with the games puzzles.
Please don't forget to rate. :)
Apr 08, 2009 | Nintendo Professor Layton & the Curious...
Crossing of wolves and chicks
Hi, try this bro!
First step: Move 1 wolf and 1 chick
Second step: Bring 1 chick back
Third step: Move 2 wolves
Fourth step: Bring 1 wolf back
Fifth Step: Move 2 chicks
Sixth Step: Bring 1 chick and 1 wolf back
Seventh Step: Move 2 chicks
Eighth Step: Bring 1 wolf back
Ninth Step: Move 2 wolves
Tenth Step: Bring 1 wolf back
Eleventh Step: Bring 2 wolves over Take the 3 wolves first kick them until they run away go back and take the chicks across (That is if the wolves havent killed you)
Nov 23, 2008 | Nintendo Professor Layton & the Curious...
Lost remote
Go up to ch 80 and the next one is the AV ch
Apr 17, 2008 | Pacific Digital PRIMEVIEW801 Video...
"ch set" appearing on screen
Need to get into the menu pages to setup the tuner. Just buy a under $10 universal remote but make sure it has a menu button.
Or - many other products that use remotes often have an option for programing it to work with other equipment.
Dec 30, 2007 | Emerson TS1997 19" TV
StarTech.com StarView SV211K 2-port KVM Switch Logo
221 people viewed this question
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
