Question about RCA HD52W56 52" Rear Projection HDTV
Tv was working fine, then all the sudden the picture warped towards the middle from top to bottom, and everything was like doubled up.
  • RCA Master
  • 8,617 Answers
Install the RCA repair kit called the ITC222 and ITC222a convergence option missing repair kit available from www.tvrepairworld.com the kit contains the parts and the CD with instructions for the repair.
Posted on Jul 29, 2010
Testimonial: "very helpful"
I have a sony kp-41t65 tv acting like computer screen out of whac
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can get more information and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 10, 2009 | Sony KP-41T65 41" Rear Projection...
Weird warped lines
Try the Magic Focus option on the menu.
Jan 19, 2009 | Hitachi 57F500 57" Rear Projection...
Warping picture and color separation
The convergence chips and resistors need to be replaced. You can get a repair kit and photo instruction guide from www.TvRepairKits.com.
Sep 09, 2008 | Philips 46PP9302 46" Rear Projection...
Distorted picture
On the middle circuit board towards rear is a metal wavy plate.On the back side(actually towards screen when looking from rear of unit),the middle screw has a ground wire(light brown) that is loose.
Apr 08, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Warping
If this is a projection tv then replace convergence amps. and resistors in the area also look for open fuses.
Sep 05, 2007 | Philips 55PP9352 55" Projection Television
Red color on screen is warped on my LCD projector TV.
Normally the oily fluid coming from a picture tube, is the coolant from the tube. It's very combustible and have been known to start a fire. You have two problems in this set. A leaking blue picture tube. A convergence circuit that needs repaired. Call a local servicer and see if they will give you an estimate over the phone. It's time to start looking for a new digital set. Good Luck.
Jun 23, 2007 | Hitachi 50UX58B 50" Rear Projection...
Bowlike effect convergence all screwwed up
I suspect you originally had an intermittent solder connection on the convergence circuit board. This may have damaged the convergence IC's on that board by now if repairing those connections doesn't fix the set.
Mar 10, 2007 | Mitsubishi WS-65819 TV
Warped Picture, Separated colors
Each color (red,green & blue) has an amplifier IC (STK-).
When there is a convergence issue,the first step is change both
IC's for reliability. Then check for open fuses devices,usually
pico fuses.Then re-check convergence alignment.......T.
Feb 07, 2007 | Philips 60PP9352 60" Rear Projection...
RCA HD52W56 52" Rear Projection HDTV Logo
281 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
