Question about Dryers
My whirlpool dryer start when you press the start button - but as soon as you stop pussing the start button the machine stop and does not continue on it self.
    President:
  • 949 Answers
This problem is most commonly due to the motor. The motor has an internal switch called a centrifugal switch that senses when the motor is up to speed.
The second cause could be the start relay (this is present on some but not all models), this is part of the start button you push and is less expensive than the motor, it can be checked with an ohm meter to determine which component is faulty.
If you can send me your model number I can pull up the wiring diagram to determine which type of start component is on your Whirlpool. The model number can be found on the tag just inside the door
Posted on Jul 28, 2010
I have a whirlpool duet gas dryer model ggw9200lw1. when i press the start button it clicks once but wont run.
First, check the door switch. Push and release it by hand and you should hear a click. If no sound, replace the door switch with this part.
If the switch is ok, press the cancel button on the machine. Then do this. press and hold the start button for 2 seconds then release wait 2 seconds and press and hold again for 2 seconds continue this pattern until the dryer goes into test mode. You will see all the lights on the control light up. press each button on the control one at a time 3 times each. (Do not press the cancel button) until the dryer begins to run. When the dryer starts to run then press the cancel button. Then your machine should function properly.
Oct 19, 2012 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool LER5636PQ1 DRYER starts when I hold the button then shuts off
Your motor has gone bad. Think of the motor as a starter in a car. When you turn the key (press the start button) power is applied to the starter, to be specific, the stator also called the start winding, same as the dryer. Then the rotor takes over and the stator drops off. With your machine the rotor isn't engaging and the stator is taking the load and shutting down.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 27, 2012 | Whirlpool Dryers
GE CABRIO WASHER, START BUTTON FLASHES PUT WHEN PUSSED IT DOES NOTHING
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 30, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Whirlpool ultimate care ii dryer will not stay on when start is pressed
if you push the start button an as soon as you let go of the start button your dry stop you need a new motor
Apr 24, 2010 | Whirlpool LER4634J Electric Dryer
Power working but won't stay on
sounds like u have a faulty start button. the switch isn't staying closed...
Feb 22, 2009 | Whirlpool LER4634J Electric Dryer
Dryer will not turn on and stay on.
Hello , bad news here , when you press the start button it sends power to the motor and then a clutch sets in and closes a set of points that then sends power to your element -if the clutch does not engage the motor will not continue to run or send power to the element and that is what is happening to your dryer.
not an easy fix at all , the clutch is bad and its located inside the motor and the entire motor would need replaced to repair this problem. they range from 80-100 dollars and would take about 1-2 hours to change.
let me know if you have any other questions.
Phil
Jan 12, 2009 | Dryers
Whirlpool duet dryer will not start. Panel lights come on as usual and when press start machine clicks and will not start. Light on wet sensor lights and no drying action begins.
press the cancel button on the machine. Then do this. press and hold the start button for 2 seconds then release wait 2 seconds and press and hold again for 2 seconds continue this pattern until the dryer goes into test mode. You will see all the lights on the control light up. press each button on the control one at a time 3 times each. (Do not press the cancel button) until the dryer begins to run. When the dryer starts to run then press the cancel button. Then your machine should function properly. This is a secret test and reset for your dryers control, so please keep this between us. The whirlpool people would be heart broke if they see this posted on the web ;-) . If your dryer will still not start after this test, you may need a new control. If you need a part let me know and I can ship it right to you. Good luck and I hope this will fixYa and saves you the $400.00 it would cost for whirlpool to send a certified tech to come to your home.
Mike Anderson
Anderson Appliance Repair
9865)945-3808
Dec 01, 2008 | Whirlpool GEW9200L Electric Dryer
Dryer stopping in middle of cycle but timer continues to run.
oK " It's your timer, it has to be replaced
it's not going threw all it cycles, will start but will not finish
not a big job, unscrew plate on back at the top you will see
timer , take it out and replace it
( can not stress enough that you have to unplug the electrical cord from the wall socket before working on a dryer or any appliance )
Jan 24, 2008 | Whirlpool LER3624JQ Electric Dryer
Dryers Logo
41 people viewed this question
Top Dryers Experts
Marvin
Marvin
