Question about Troy Bilt Tb70ss Gas Trimmer
I have troy built string trimmer model TB70SS.Poured in gas that had a little water in it. I have cleaned tank & carb. Runs sitting level.When I till up to use it cuts off slowly.
How to replace pull cord
Posted on Jul 29, 2010
TB70ss Trimmer runs but does not turn the string
Remove the angle drive gearbox near the string head and spin it to see if everything is moving properly. You may have stripped the gears out of it.
Sep 16, 2012 | Troy Bilt Tb70ss Gas Trimmer
How to get the fuel tank off the troy built Tb70ss gas trimmer
Go here and you will see the parts breakdown and diagram for this model...to give you an idea on the parts you will be working on:
http://www.ereplacementparts.com/troybilt-tb70ss-41adt70c711-gas-trimmer-parts-c-26780_27267_27463.html
Aug 26, 2010 | Troy Bilt Tb70ss Gas Trimmer
Troy-Bilt TB70SS will not start
Hi. Go to any auto parts store and get a can of starter fluid. Have a helper squirt a little into the air cleaner while u start it up. Then continue to squirt the starter fluid to keep it running until the engine sounds good again. J.
Jul 07, 2010 | Troy Bilt Tb70ss Gas Trimmer
I have a TROY-BILT String Trimmer model TB70SS and I cannot get it restrung when the string runs out. Do you have a manual that shows how to load the string for this model?
Click Here For Your Manual.
If it takes you back to your model number & serial number, simply enter your model number and any random number for the serial. You will be able to access the manuals from there.
I hope this helps.
May 06, 2010 | Troy Bilt Tb70ss Gas Trimmer
My weed eater wont start.
One of the problem could be is you have one of the line in this case top line in the carburator clog. For clean the carburator You need to remove first the cover for the filter 2 screws on front of the carburator remove lines mark the lines top and bottom remove slowly the carburator be careful with the gasket. The carburator have 4 little screws removed and remove the black gasket (diaphragm) clean with carburator cleaner and air, blow air thru the top line tube, now on the otherside remove the screw and clean the gasket and the carburator inside do the same step. Make sure you clean the fuel filter inside the tank with carburator cleaner.
Apr 05, 2010 | Troy Bilt Tb70ss Gas Trimmer
Troy built weed eater won't feed line
Check the size of the line,(OD), make sure you are using the correct size, sometimes cheap line will be problematic, also, you said you are re-stringing it, try a new batch of string, the old string inside the hub can get chaffed and will stick to itself...
Aug 22, 2009 | Troy Bilt Tb70ss Gas Trimmer
Troy built 6 75 hp lawnmower will not stay on I start it but it will quickly turnoff''
on the bottom of the carb. is a bolt that holds the float bowl on. remove that bolt and float bowl. use a small needle and stick it in the holes on the bolt to clean them out. look at the gas in the float bowl to make sure there is no water in the fuel tank .
Jul 02, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Weed eater will idle but shutdown upon giving gas
Cleaning the screen on the muffler will help but the muffler itself is what needs burned out. This can be done with a fire or a torch. Let the muffler cool on it's own as use of water can warp it. Parts can usually be purchased at any small engine repair shop that represents Mtd. That's who make the weed eater.
Jun 21, 2009 | Troy Bilt Tb70ss Gas Trimmer
Need to clean carburetor of troy built trimmer. Where can I find directions on how to do it?
Go to any auto parts store and buy an aerosol can of carbeurator cleaner. Remove the air cleaner filter and give the air intake a couple of squirts. Pull the cord and turn the engine over a couple of times to draw the cleaner into the carb. Then let it sit for an hour and dissolve what ever is gumming up your carb.
Jun 11, 2009 | Troy Bilt Tb70ss Gas Trimmer
Troy-Built TB70SS, 1 year old, will not start even after carb cleaning
check to see that the kill button is not stuck in the contacting position, and if it is, try to get it unstuck. WD40 should help. if it's not, then disconnect the kill wires. now try starting it. if it still doesnt start, then the spark generator is bad. if this is the case, you'll need a new trimmer, or have a small engine mechanic replace the generator. i think its called the coil, not sure at the moment it's 4:00 am for me. anyways, whichever is cheaper is best choice.
Jun 01, 2009 | Troy Bilt Tb70ss Gas Trimmer
Troy Bilt Tb70ss Gas Trimmer Logo
237 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
