Maytag top load washer leaks from bottom - Washing Machines
  • 1 more comment
  • m_seever6111 Oct 20, 2008
    I have the same problem anyone know how to fix it without calling a repairman?
  • Rayne Swezey
    Rayne Swezey Apr 21, 2009
    I had a repairman just here and he just used a putty knife to pry off the top..... also repairman have replaced tub splash ring and bleach/softtner hose and it still does not work right....I beleive this is a fualty model and will be recalled or should.
  • fmarzullo Apr 27, 2009
    I have the same problem with our washer which is 18 mths old. Has anyone found a fix to this problem?
    Genius:
  • 1,028 Answers
Usually tub seal ck pump and hose to pump but my bet would be tub seal
Posted on Apr 24, 2008
Im haveing the same problem, how to i get this top off to check,,,,can not find out how to open ,,,with out messing the washer up
help and thanks
Posted on Jun 28, 2008
Maytag neptune top load fav6800aww washer leaks from bottom during spin
for a start you should check if the rubber of the spinner is still ok. you will probable have to replace that rubber
Mar 21, 2014 | Maytag Neptune FAV6800AW Top Load Washer
Water leaking from the bottom of my maytag bravos washer
Depending upon the age of your washer, the pump may have begun leaking
Apr 21, 2013 | Maytag Bravos MTW6600T Top Load Washer
Maytag top load washing machine leaking water from bottom
The machine is leaking water from the bottom, I think the leak is in the area near where the motor is mounted. Before we noticed the water comes from underneath the washer, we smelled like burning rubber.
Al Bana
Jun 26, 2009 | Maytag PAV2300 Top Load Washer
Maytag washer leaking between cycles or if stopped during fill
lift the top up on the washer and see if the fill hose is crack or broke,hose on right side
Jun 18, 2009 | Whirlpool LSN1000LW Top Load Washer
Maytag washer
Many of the maytag toploaders have a rubber fill hose at the top of the outer drum.
Sometimes if the machine is fully loaded (or overloaded), during the spin cycle if clothes are above the top of the drum they can actually knock the rubber flange of the hose out of the drum. Then when the machine fills with water, it will dump it down the outside of the tub and it will appear that the water is leaking from the top and side of the drum... Fix it by snapping the fill hose flange back into the hole in the top part of the drum... let me know how you do or need more help...
Mar 23, 2009 | Maytag Ensignia 3.3 cu. ft. Top Load...
My daughters maytag has water leaking from the bottom.
Check the easy stuff first, fill hoses tight?- drain hose cracked?
Failing those checks, cut a piece of cardboard slightly smaller than the size of your washer. Slip the cardboard under the washer and run a short load. Look carefully at the water mark on the cardboard. The mark on the cardboard the water leak will leave, will help you tell from which side or front to back the leak is common from. This will help point you in the correct direction to look for the trouble maker.
Nov 25, 2008 | Maytag PAV2300 Top Load Washer
Washer leaking water on floor
Need to check drain pump and its hose connections. If its not from the drum seal then that's usually where the leaks occur.
Mar 30, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Washer 5401A
this is a leak in your triple lip seal that has seeped water into your bearing. this requires special wrench and experience to change
Feb 13, 2008 | Maytag SAV5401A Top Load Washer
Washing Machines Logo
329 people viewed this question
Top Washing Machines Experts
Richard Roth
Richard Roth
