Question about Amana ABB1927DE Bottom Freezer Refrigerator
The fridge does not cool but the bottom freezer does, It is an Amana BX2ITW. I have not tried anything. The freezer froze a tray of ice but the fridge is not cooling at all.
  • Amana Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
ytty
Posted on Sep 30, 2010
Amana refrigerator A4TXNWFWWO1 >top freezer, bottom fridge it's only 10 months old refrigerator won't get colder than 55 degrees freezer is working
There is something plugging the drain line in the freezer which carries water from the defrost cycle to your evap drain tray in the bottom of your fridge. The water has built up and froze plugging the flow of air from freezer to fridge.... find the line and unplug it and let fridge sit and thaw overnight and then some more.
Jul 19, 2011 | Amana A4TXNWFWW Top Freezer Refrigerator
Our Amana has a reocurring defrost problem where the back of the freezer clogs with ice every three weeks. Is there anything we can do?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 10, 2010 | Amana ARB2557CSR / ARB2557CSL Bottom...
Used armana bottom freezer fridge, not cooling?
yes leave it on for another 24 hours its probably the settings on the refridgerator
Jul 13, 2010 | Amana ARB2517CC / ARB2517CB / ARB2517CW...
Not cooling, water in ice tray, just cool air coming from fan in freezer, 8-10 yrs old
heatman101
gf
Apr 15, 2010 | Amana ABB1927DE Bottom Freezer...
Fridge wasn't cooling but freezer was working, now both aren't
Hi,Your husband did good job, after cleaning and vacuuming, did freezer (bottom) have excessive ice?, if there's excessive ice in bottom, after cleaning, you have a defrost problem, but if there're no ice in freezer after cleaning, you got freon (gas leak) , there's a condensate loop, that passes through ref. body, from compressor that naturally develop, freon leak after few years, by rusting, normally it can be by- pass. vacuum and refill with freon, if there's no freezing, but compressor running, you'll need a mechanic, you got a freon leak. good luck.
Aug 10, 2009 | Amana ABB1927DE Bottom Freezer...
Amana side-by-side fridge freezer only cold at the bottom
yes the evap fan in the frezer should be running when the compressor is running[it may not for a minute or so as it starts up.Amana's are good for the connectors at the evap fan motor comming apart.the connectors are white and will look like its together but when you pull it will come apart.i would always cut the connector out and use a wire nut so wont happen again.if any other questions please email thru FixYa and i will be glad to help. God bless ,tom
Jan 30, 2009 | Amana 22.6 cu. ft. Side-By-Side...
My amana bottom freezer won't cool both the fridge and freezer are warm
Ice build-up inside refrigerator and cycling switch not functioning. Requires technician to take apart inside of refrigerator, clear ice and replace switch. Took my repair man about half hour to fix.
Nov 04, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
11 year old amana bottom freezer icemaker drips water when filling tray
Hello dunc444444
Welcome,
You said, Bottom freezer works fine, but upper refrigerator has no cold air
Is your freezer so full that it is packed to the top especially in the rear?
Refrigerators and freezers share the air from the compressor and travel through vents in the rear of the freezer and fridge.
Sometimes it can effect the cooling in the fridge if the freezer articles block the vents!
The water overfilling in the ice maker is an ice maker problem only.
When we install an ice maker there is a short white plastic tube that we push through the rear
hole of the fridge which supply's the water to the maker, the outside water line attaches to this.
That tube we push through the fridge must go in till it stops. And empties in to a little sistran at the rear of the ice maker. Make sure it did not sip out or backwards a little when you may have moved
rolled the fridge out to clean under it!
Also you need periodically to remove the front grill down in front of the fridge and gently run a refrigerator brush under the coils to clean out the dust that may block air flow over the coils.(the coils are metal black tubes that run back and forth along the bottom of your fridge.
The vacuum will not reach in to that tight space. That's why they make a special brush for this chore.
Let me know how you do?
Huuum {
Let me know.
Huuum
Please remember to leave a rating.
Oct 05, 2008 | Amana ARB9059CS Bottom Freezer...
Amana refrigerator 20 condensation water in fridge
moisture in the freezer is condensed at the back in a tray that has a drain with a tube that drains to a tray at the bottom of the unit. In our case the drain was clogged and water froze in it. We removed the back panel and pulled out the tube from the drain spout. We then used a hair dryer to defrost the ice clog and a wire to route out the drain and the tube. This worked and we replaced the tube and sealed it with tape. It now drains properly into the tray.
Sep 13, 2008 | Amana ARB1905C Bottom Freezer Refrigerator
Amana ABB1927DE Bottom Freezer Refrigerator Logo
647 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
