Question about HP DesignJet 500 InkJet Printer
Hp Designjet 500 not recognising ink cartridges. the ink carts were nowhere near empty but coming but the printer says replace bought new ones and put them in and the machine is not recognising them showing x on each cart. Even though they are new ones. tried restarting printer and computer still no luck
I've had that problem with unfinished cartridges showing up as empty. I imagine that it could be a bad cartridge as well but I hear and feel the ink when I shake the cartridge. Therefore the ink is there. I also have a problem with some inks. I find the HP inks work perfectly whereas other manufacturers' inks work on and off. I need a solution as well. Right now I have full cartridges that are not picked up by the Designjet sensor. Any idea?
Posted on Oct 20, 2010
  • servolan May 12, 2011
    I have the same exactly problem and no solutions?
    Help me please
HP Designjet Z2100 photo printer Cyan ink empty
Sounds like a problem with the chip or HP accidentally sold you an empty ink cart. Either way, they should replace it. We carry ink as well and if you ever need anymore, please let me know. Free shipping and less expensive. Damien @ iPrint Technologies - 818.700.7419
Aug 28, 2014 | Office Equipment & Supplies
1050c DESIGNJET REPLACE MAGENTA ISSUE
one of the first signs of a faulty power supply is a washed out display,
also you may hear a slight buzzing noise,
you may need to replace the ISS Pwb ( part of the tubes ) not order able separately,
it has been known that the connector block ( for ink Cart) does fail, I would try swapping it with another colours and see if the fault follws the connector block,
it may just be a bad chip on the ink cart.
Jun 07, 2013 | HP DesignJet 1050c InkJet Printer
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
My HP DesignJet 500 plotter printer doesn't recognize any of the 4 ink cartridges
>Your have new cartridges,not refilled right?
>Remove cartridges,
>Remove right door,
>Check ISS unit cables,PCB & connectors as shown in snap shot,
Most of the cases ISS arrested with ink leakage from cartridges, result connectors,PCB tracks & cables got damaged.. check perfectly if found shoot the problem....
> Replace ISS unit,, But only professionals can do the replacement..
*** Reading, writing & initializing the backup EEROM located in ISS unit, if any thing goes wrong both ISS & Formatter assm will loose their memory..be careful..
Dec 05, 2011 | HP DesignJet 500 InkJet Printer
Printer does not recognize new ink cartridge
Are you using "refilled" hp cartridges? If so, they may be interpreted as "empty" or a non-hp cartridge if the carrtidge shell was manufactured prior to the recent time that hp began coding the electrics on the same type cartridges. This can also happen if you are using "compatibles". If this is the case, try buying original new hp carts. If that is what you already have, return the cart to the store as defective and as for a replacement.
Apr 28, 2010 | HP Photosmart 3210 Printer
HP Business Inkjet 2800 Problem
there is a sensor which recognises the amount of ink u have in ur cart. if that sensor doesnt work, then printer will not recognise the ink in the cart. Try cleaning the copper contacts on the printer cart slot. if no go. look for service..
Sep 25, 2008 | HP Business InkJet 2800 Printer
HP officejet 6210 all-in one
ok i found a way to help you find those 94's 97's printer cartridges
http://computers.pricegrabber.com/ink-toner/m/3768822/
this link is for the hp 94 cartridge
http://computers.pricegrabber.com/ink-toner/m/3768824/search=hp%2097/st=product/sv=image/
this link is for hp 97 cartridge
from the uk i hope this helped you find the right cartridges
338-334 is there new numbers if there not put in right the cartridges will have error to them kinda snap in with little force
May 07, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Magenta Near Empty??
This is only a reminder! The cart will show "empty" when it is really empty. You can print on until the printer stopps because of empty cart (and prints on when it is replaced).
Take the new on out and put it in again. answer display question with "1" (Yes, cart changed). "Near empty" Message will disappear.
Feb 12, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 210C All-in-One Ink Cartridges
near empty message is a reminder: plz buy a new cart (but do NOT change until EMPTY). You still can print.
the ink left in an empty cart keeps the system alive when some ink is neede for the automatic cleaning cycle.
If you print until this cart is really empty air will get into the tubes and ph. That leads to faulty printings.
brother had made sure that the amount of printable ink can be consumed. The rest is for service.
Jan 31, 2008 | Brother MFC 210C All-In-One InkJet Printer
Lexmark X2550 Cartridge Refilling
I just ordered a Lexmark X5495. The carts that come with it are throw aways (or return them to Lexmark to be remaned.) You can use cart. # 28a, 29a, 34 or 35 to refill, the latter two being the high yield carts. And yes the printer manufacturers are playing a cat and mouse game with us. I normally use Epson because it's easier to circumvent the tricks they employ. I understand Canon is an inexpensive printer to run also. HP and Lexmark are the costliest products to operate. There is a utility for Epson called SSC ver. 4.30 that gets around the safeguards by resetting the cart. chips and a whole lot more. Someone needs to write a utility for HP and Lexmark to replace the standard driver/ink monitors that are designed to siphon off our wallets quicker than they do ink. One more trick I've heard: when the printer is looking for a new cart have a spare cart handy and put it in in the printer. The printer will now think you have ink in the cart.(whether its empty or full) Now trying swapping it out for a refilled cart and see if that works. The point is this: the printer wants to see a new cart serial# ,not the same one that was just being used last.
Oct 29, 2007 | Lexmark X5495 Printer
HP DesignJet 500 InkJet Printer Logo
1,594 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
