Question about Sharp AR-5316 Advanced Digital Imager Copier
I have Sharp AR 5316 L1 00 error in my copier pls give tips urgent
    President:
  • 2,072 Answers
L1 00 Content Scanner feed trouble.
Detail The scanner does not complete feeding in the
specified time.
Cause Mirror unit abnormality.
The scanner wire is disconnected.
The origin detection sensor abnormality.
Mirror motor harness abnormality.
Check
and
remedy
Use SIM 1-1 to check the mirror reciprocating
operations.
When the mirror does not feed.
Check for disconnection of the scanner wire.
Check the harness and the connector between
the mirror motor and the MCU PWB.
Replace the mirror unit.
Replace the MCU PWB.
When the mirror does feed.
Use SIM 1-2 to check the mirror home position
Posted on Jul 28, 2010
Pls help for sharp copier AR-5316 error code 2-H
H2 signal is thermistor open
check the harness and the connector between the thermistor and the PWB use TC 14 to clear the self diagnostic display.
Oct 04, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar 5516 printers error h5. h4
hi,I have error code L h on my coppier sharp 5516. your help please.
Aug 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
I Have Sharp Photo Copier AR 5316 when i given Print command the image was good but background double image was also come pls sir give some urgent tips sir
Needs a fuser hot roll. Once the get worn, they pick up some of the image and reprint it on the page.
They are available form several sources, Kaytin comes to mind. Precision roller. Google the printer model number . I would google is like this. Sharp AR 5316 hot roll.
That should give you several sources, Honestly I would replace the press roll also. Probably you should be able to find them both for less than 100 dollars, I sure wouldnt pay more. Look around. You can find them for a decent price. You may even want to look on E-bay. they often have them there.
Aug 02, 2010 | Sharp AR-5316 Advanced Digital Imager...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} E7-11 Shading troble(whife correction)
IMPRPER CONNECTION OF THE CCD UNIT CABLE DIRT ON THE MIRROR,THE LENS,AND THE REFERANCE WHIT PLATE
copy lamp lighting abnormality
ccd unit abnormality
MCU PWB abnormality
(when occurred in the scan position)improper installation of the mirror unit
Jul 31, 2010 | Sharp AR-5316 Advanced Digital Imager...
I Have Sharp AR 5316 when i power on copier L1 00 error pls help me
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} 00-The scanner does not complete feeding in the specified time
Jul 28, 2010 | Sharp AR-5316 Advanced Digital Imager...
MY SHARP PHOTO COPIER MODEL AR 5316 WAS PROBLEM WHEN I PRINT THE PAGE THE ERROR IS COME E7-11 NO BUTTON WAS WORK PLS GIVE TIPS ITS URGENT SIR
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 01.duplex model memory error
02.LSU trouble
03.shading trouble (black correction
04. shading trouble(white correction)
05. shading trouble
06.Abnormal laser output
Jun 21, 2010 | Sharp AR-5316 Advanced Digital Imager...
Error L4
This Code shows a mechanical problem. Main Motor doesn't run, or run slower. See gears.
Jan 15, 2009 | Sharp AR-5316 Advanced Digital Imager...
SHARP AR5320 error F5-02
SHARP AR 5020 error F5-02 pls canu give some tips very helpful its urgent sir
Dec 15, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR-5316 Advanced Digital Imager Copier Logo
396 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
