Question about Cell Phones
Rings once and can not pick up any other calls
  • Cell Phones Master
  • 8,404 Answers
Contact your carrier to solve this ...
Posted on Jul 28, 2010
THE ANSWERING SERVICE CUTS IN BEFORE I AM ABLE TO GET TO THE PHONE
There should be a switch towards the bottom on the right hand side
Setting ring time switch The ring time/toll saver switch allows you to set the number of rings the caller hears before the answering system plays your outgoing message. You can set the switch to answer af ter two rings or af ter four rings. Once the greeting has star ted, you can stop it when you pick up the call at the handset or base. In the TS (Toll Saver) position, the answering system picks up af ter two rings if you have new messages, and af ter four rings if there is none. This way, if you call long distance to check your messages, you can hang up af ter the third ring to avoid billing charges.
Feb 28, 2011 | Uniden Cordless Phone
Fax not picking up Brother 4100
have you see the display if it was saying the word receiving...?
let me know..
Jun 26, 2008 | Brother IntelliFAX 4100 Laser Fax
My hp 1040 will not pick up fax after the fifth ring answering machine picks after forth ring can't tell the between phone call or a fax used to before changed date on answering machine fax quite working
Set rings to answer
You can select the number of rings that will occur before the fax answers an incoming call. If you are using your machine as both a telephone and a fax machine, we suggest you set the ring count to at least 4 to give you time to answer.
TIP: HP 1050 Fax: The Toll Saver function for the Digital Message Center interacts with Rings to Answer. See Toll Saver on page 40. If you have the HP 1050 Fax and have Toll Saver turned on, set the Rings to Answer to 2.
1. Press Menu repeatedly until BASIC FAX displays and press Start/Enter.
Rings to Answer will display.
2. Press Start/Enter.
3. Enter the number of rings you want (2-7) and press Start/Enter.
The HP Fax rings the set number of times and then answers. It then produces a different sounding ring to alert you to which type of call is incoming.
• The additional ring may occur once for a fax call
• The additional ring occurs 5 times for a voice call. After the 5 additional rings, the answering machine will answer.
Dec 08, 2010 | HP 1040 Plain Paper Inkjet Fax
Phone rings only once then is silent. How do we
This is a symptom of a feature that has been activated. It could be the call is forwarded, it could be the voice mail is programmed to pick up on the 1st ring. On some systems ext's can be programmed to ring elsewhere after a set number of rings. The do not disturbe feature could be activated. If it is an outside line, call it from your cell and see what you get (voice mail-continious ring-another ext etc.) Find out if it does it on an in houes intercom call. Look for a DND button the phone...is it lit up? Does the display show calls forwarded or DND? Hope this helps. Good luck.
Mar 24, 2010 | Lucent Merlin Legend MLX-20L Phone
Phone only rings once
ring tune setup ringing not beep or ring once
Jul 18, 2009 | Panasonic KX-TG5632M Twin Cordless Phone
How do you forward a phone call from this phone to a cell phone?
to forward calls...go to your phone service providers website and help section for complete instructions...
with most companies simply pick up the phone... wait for dial tone... press *72 wait for 2 beeps and enter the number (area code first) that you would like it to forward to...once you enter the number wait for the line to ring... once it rings and is answered you are all set!
if it doesnt ring or is in use.. try again within two minutes...you should hear two short rings if it is activated...
to deactivate call forwarding...
pick up the phone (in the office)
wait for dial tone and dial *73 or #73
you will hear two short beeps... it is then off..
Apr 10, 2009 | Panasonic KX-TS3282B Corded Phone
Number of rings
Sounds like you have either send all calls (SAC) enabled or your station is call forwarded to voicemail.
Disabling send all calls or call forward (as applicable) will solve the problem.
Feb 19, 2009 | Avaya Definity 6408D Corded Phone
Have nokia 3120 , incoming call does not rings
check if the format of ringtone set is compatible with your phone..
try to restore the refactory settings once.
thankyou.
Nov 19, 2008 | Nokia 3120 Cellular Phone
Phone keep ringing when incoming call is not picked up (and reach voice mail), and then hang
I need to know more details,
Can you tell me whether you have lotsa messages in your phone?
Jun 28, 2008 | Nokia 1600 Cellular Phone
Sharp UXB700 Fax
Below is for when you are using machine in fax mode, is that how you use it or are you also using the answering machine function? ie TAD mode
If desired, you can change the number of rings on which the fax machine
answers incoming calls in FAX mode. Any number from 2 to 5 can be
selected.
1 Press FUNCTION once and 3 times.
Display:
OPTION SETTING
To select FAX mode, press
(with no document
in the feeder) until the arrow in
the display points to FAX.
RESOLUTION/
RECEPTION MODE
RESOLUTION/
RECEPTION MODE
FAX
A.M.
TEL
Using TEL Mode
58
2 Press once and once.
3 Press once.
4 Enter the desired number of rings (any
number from 2 to 5).
Example: 3 rings
5 Press to return to the date and time display.
Note: If you are using Distinctive Ring, the fax machine will answer calls after
two rings regardless of the above setting.
Oct 16, 2007 | Office Equipment & Supplies
Cell Phones Logo
Top Cell Phones Experts
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
