Question about Garden
Amflo #3125a I need the compresstion spring that is inside that is approx. 1 1/4 high by 3/4 dia.
  • 979 Answers
SOURCE: Dell OptiPlex?? GX520 GX620 Internal Speaker code.
My experience has been for this configuration, is that the red wire is your +5 volts, the green is right, the white is left, and the black is the ground for the supply and both speaker grounds. Hope this helps...accordianman
Posted on Feb 08, 2008
  • 990 Answers
SOURCE: need impeller for a flotec 5acmp drill pump
Try to match it to sta-rite PLBC
Posted on Aug 24, 2009
mowerman1857
  • 389 Answers
SOURCE: installing a bushing
If you bought the engine new from a dealer, ask about the availability of one with the correct shaft size or a crankshaft with a 1" PTO journal that you could install in the new engine.
The manufacturer designed the machine with the 1" PTO shaft for safety reasons. The load put on it during operation may be too much for the 3/4" shaft and cause it to break while running which could KILL some one!
You would have to replace the pulley, there is no SAFE way to use a 1 inch ID pulley on a 3/4 OD shaft, and if I am not mistaken, the keyway in the new engine is 3/16". and even if is 1/4, there isn't a "taller" 1/4" square key.
Just some things to think about! Chuck
Posted on Sep 22, 2009
Testimonial: "thanks for the input. I'll have to seek another solution, perhaps from a machine shop. thanks Mike"
  • 4088 Answers
SOURCE: Need connector wires inside wand. Electrolux
Go to a store like Lowe's and look in their electrical department. You need wire the same gauge size (stranded or solid) and comparable insulation. Hope this helps!
Posted on Jan 10, 2010
  • 5 Answers
SOURCE: need replacement high pressure hose.approx 7cm
Jura machine uses the same hose. Have just purchases one from Services Unlimited Inc. Jura Reinforced Silicon Hose 4.2x8.0x80mm item no. 0010681. email sales@partsguru.com
Regards,
Eric
Posted on May 30, 2015
I need to know which valves and springs fit into which places for a 1994 barina
big headed valves go in the inlet holes ( ones to the inlet manifold and little headed valves go in the exhaust ports
Measure the spring heights but they should be the same so they can go where ever
If you have large dia springs and small dia springs the little ones fit inside the larger ones to stop spring bounce at high rpms.
Mar 24, 2015 | Holden Barina Cars & Trucks
Why do no panel lights turn on when my Kenmore Model 587.1625 is latched and ready
The door latch in Kenmore and Kitchenaid isn't of the best design.The spring steel latching tab is needs to push down the black plastic slide mechanism when the door in closed. That slide pushes down on a micro switch which interrupts the cycle when you open the door when the dish washer is running. Take the latch assembly back out. You can insert two compression springs inside the slide on each side of the latch. They are approx 3/16 Dia x 3/4 to 1 inch long. In the hardware dept at Home Depot or Lowe's..The springs will push the slide down hard enough to activate the switch. Right now your dish washer thinks the door is open.
May 17, 2014 | Dishwashers
Connect Nikon D60 to Opticron Scope
You should be able to buy an SLR adaptor from most Telescope retailers Try asking "Telescope House" if you can't see what you need (link below).
https://www.telescopehouse.com/astro-imaging.html?cat=154&p=1
Nov 26, 2017 | Nikon D60 + AF-S DX VR NIKKOR 18-55 mm...
Where is the thermostat located between top
On 1998, 4.6 32 valve engines, the thermostat is located in the radiator to block hose. if you look directly under the power steering reservoir you should see it.
The thermostat has 3 hoses running from it. 2 are approx. 1.5" in dia. and one is approx .750" in dia. The .750" hose leads up to the coolant reservoir. and yes it is under the power steering reservoir. Access to the thermostat is from the bottom side. You will need an 8mm socket to remove the two bolts. Removal of the bottom radiator hose is mandatory.
Hope helps with this (remmeber rated this help).
Mar 08, 2010 | 1998 Lincoln Mark VIII
Dose Amflo spray gun meet OSHA 1910.242(b) Iam robert D. Sullivan Safety Specialest DART transit we use hundreds of the units All I neeed is a yes or no
Yes it should. According to AmFlo, their guns will not exceed 30psi at the tip when the inlet pressure is 150psi.
Sep 03, 2009 | Air Tools & Compressors
Where is the thermostat located on a 1997 lincoln mark 8?
The thermostat has 3 hoses running from it. 2 are approx. 1.5" in dia and 1 is approx .750" in dia. The .750" hose leads up to the coolant reservoir. and yes it is under the power steering reservoir
Mar 28, 2009 | 1997 Lincoln Mark VIII
Kenmore washer need to put rubber gasket retaining spring back on. Any tricks, seems impossible. Peter
I assume that you're talking about the inner spring. It's very tight, so you have to get the rubber gasket (bellows) fitted on the its frame, then push the bellows inside out in toward the tub. Start with placing the spring in its groove at 12 o'clock. Wedge something between the bellows and the white colored weight ring of the tub. You'll need something approx 3/4" in diameter to wedge the top of the spring in place. (I've used a 1/2"X90 degree copper elbow I had laying around that had an approx outside diameter of 3/4"). This will hold the spring in place as you work it around. It is still very difficult and you may have to stretch the spring ever so slightly to get it back into the groove. Once the spring is back on, remove the wedge, fold the bellows back out and attach the fill hose and attach bellows back to front panel.
Jan 02, 2009 | Kenmore 44072 Front Load Washer
Garden Logo
53 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
