Question about Aiwa HV-MX1 VHS VCR
When I push eject the vcr doesn't open the door and doesn't eject the tape
  • 12,061 Answers
This is a common problem, either the tape drive motor, or the driver for same has failed. Sometimes it is a thing called the Mode switch too.
http://www.retrevo.com/support/Aiwa-HV-MX1-VCRs-manual/id/1077dj194/t/2/
So, it is nearly always my professional opinion that one should always get a "Quote" from the manufacturers recommended service center, Aiwa, in your case, please contact a local or head office and ask for a referral to an Authorised service center. I cannot stress how important that last point is. It is even worth the cost of shipping. You see an authorised service agent, will have trained staff, trained on their brand, also they have first hand access to parts, original parts. This will actually save you money and ensure you can actually get it back fixed. Of course asking for a "Quote" also gives on the option of repair or replace. Often my clients,do not go through with repair, unless it is moderate, but in some of the more costly jobs they see it, as do i, that a replacement, with a warranty, is a better option. As an aside here, one could then tear the TV down, and sell the Known Good bits.
Posted on Jul 28, 2010
Vcr door won't open
It's probably just a little spring that has come. Or that a latch as come out of place. You can sometimes correct it by removing the front side part. You will have to take off the top cover and sometimes the base to get to the screws that hold the front on.
Dec 12, 2013 | Aiwa HV-MX100 VHS VCR
My VHS tape will not eject from the VCR. I have a message flashing stating ERR. What can I do to eject the tape?
Hello
The mechanism of your VCR has jammed with video casette tape. If tape ribbon has got twisted around the drum motor head, or the belt that connected to eject [capstan] motor has elongated, this type of fault will occur. Either it will play, rewind, fast forward of eject. Just replace the belts first. In most VCRs the user can replace the belt from underside. Let the tape is there, if it is in, replace all the belts. Belts can be bought from most of the electronic spare part shops at your town. It will come as kit type, each model has its own belt kit, and you have to give them the exact model number of your VCR. Just open the cover of the VCR, and look for tape ribbon twist if any. If it is there, remove it carefully without making damage to any other internal parts, especially to video head. If necessary, cut the tape film. If tape twist is only the problem, it will be rectifed as this twist has been removed. If this also doesn't help you, replace all the belts. OK.
Jul 11, 2011 | GoVideo Go Video DVD/VCR Combo
Vhc tape is stuck in my video cassette recorder, it is a much older vcs, is their any way I could possibly that I can get it out without breaking the vcs?
Take ur finger senses all around the VCR the open flap door for sensors also pushes the eject button too as the same time,when the right sensors it hit ur finger the VHS tape will come out.
Mar 16, 2011 | Zenith Televison & Video
VCR tape won't eject
The reason your tape wont eject is either because, it is stuck or the tape run loose inside of it.
To remove the tape, unplug the VCR, then unscrew it open, you will have direct access to the tape, so try to plug it back and press eject, when it gets stuck, apply a little force in pushing the tape up, to the height where it is to pass out, and it will eject your tape.
If you are not familiar with such activities, i will advice you get a repairman to get this done for you, in order for you not to damage any other part inside the VCR.
Take cacre and good luck
Oct 14, 2010 | Sylvania LV448HG VCR
DVD DOOR AND VCR DOOR WILL NOT OPEN, DOES NOT EJECT TAPES OR DISK
I have had some luck in unplugging the machine for five or ten and then trying again. I have spent five to ten minutes trying to get the darn thing to spit out the disk and it refuses. Unplugging either gives me time to cool off or it helps the machine :)
Apr 30, 2009 | Panasonic PV-D4745S DVD Player/VCR
My Sony SLV-N750 recorder works perfectly - except..
If the door is not connected to a "tape in" interlock
Jul 22, 2017 | Sony SLV-N750 VHS/S-VHS playback VCR
VCR Won't Eject VHS Tape
Do not panic yet! Before doing anything else just unplug the unit for a time. On two different occasions I unplugged my TV/VCR combo, it reset itself and I could eject the tape. I do not know how much time is really necessary as I let mine sit overnite in those two instances.
So after much frustration the first time a tape stuck which included carefully opening the chassis to look for a twisted tape, sticky labels or loose parts in and around the metal cassette holder plates, I put it back together. Now I just unplug to reset.
I am not saying this will work in every instance, but give it a try first.
Aug 20, 2008 | Zenith ZHX-313 System
you should take the bottom off and you will see a gear with a belt around it try to turn it the same direction as when it is turned off, do not force it but it may need a little force to move the wheel.
Mar 17, 2008 | Sony SLV-998HF VHS VCR
Cannot eject VHS tape from Sony SLV-X811
I had a similar problem with a Panasonic VCR. It would not eject the tape and gave an error code. I found that the door does not quite fully open, so that the top of the tape hits the door and cannot eject. If I turn off and then turn on the VCR the error code disappears. Then I press the eject button and simultaneously hold the door fully open with one finger until the tape starts to eject and clears the door.
Feb 29, 2008 | Televison & Video
Remote Buttons
Press the VCR button first then press open/close
Nov 22, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Aiwa HV-MX1 VHS VCR Logo
153 people viewed this question
Top Aiwa Televison & Video Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you an Aiwa Televison and Video Expert? Answer questions, earn points and help others
