Question about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
My pc displays messages of missing modules on turning on what is the problem?
  • 808 Answers
Itx the problem in ur registry so clean ur registry error using reginout
Posted on Jul 28, 2010
Mini cooper s obd codes 1627 whot to do?
Definition of check engine code P1627:
Citroen/Peugeot:
Module Supply Voltage Out Of Range
Ford:
GM:
A/D Performance
Isuzu:
PCM A/D Conversion Malfunction
Jaguar:
Module supply voltage out of range
Mazda:
Powertrain Control Module (ECM/TCS) Line Communication Error
Mercedes:
PCM (ECM/TCS) line communication error
Saturn:
PCM/EC A/D Fault
Toyota:
ESA3 Signal Circuit Malfunction
Volkswagen/Audi:
Data - Bus Powertrain missing message from fuel injection pump
Volvo:
Nov 22, 2017 | Mini Cars & Trucks
Tech sheet missing need help with codes
Your Error code is 94
81. - 95
. (0101xxxx) Phase 2 to 3 - Display/ Motor Control
Module. See Fault Code 106
106. (01101010) Phase 2 to 3 and 5 - Display to Motor
Control Module Communications Errors
(Phase 6 IW Also)
These faults are reported when the Display Module detects an error in
the communications between the Display Module and the Motor
Control Module.
Phase 2 to 3
Primary Source: Display Module.
Action: Replace Display Module.
Secondary Source: Motor Control Module.
Action: Replace Motor Control Module. If the new
Motor Control Module corrects the fault, refit the
original Display Module.
Phase 5
Primary Source: Pump
Action: Measure resistance of pump. If resistance is
less than 33 ohms, replace pump.
Secondary Source: Display Module.
Tertiary Source: Motor Control Module.
Feb 21, 2013 | Fisher and Paykel Washing Machines
Error message corrupt file or missing
hi, the best thing to do here is press f8 on start-up, you will then be greeted with a number of options select safe mode ,and then select System restore, hopeful it was turned on so you can step back before Angry birds was downloaded, you will need to press f8 a couple of times straight after the bios display on the screen...
Regards
Dec 21, 2012 | Sony VAIO Computers & Internet
When I turned on my printer today all the lights on the front started flashing and this error message showed: "C4EB8000. Turn power off then on again." I've tried googling it and nothing seems...
Follow these steps to resolve the error message. It might not be necessary to complete each step to fix the issue. Step one: Disconnect all data cables and devices from the HP product
  1. Disconnect any USB, Ethernet, or parallel cables from the back of the HP product.
    CAUTION: Do not disconnect the power cord during this step. Figure 1: USB connectionc01661620.gif Figure 2: Parallel connectionc01369986.jpg
  2. Remove any memory cards or USB drives from the HP product.
Step two: Turn the HP product off and then on
  1. Press the Power button (c01602202.gif ) to turn off the HP product.
  2. Wait 15 seconds.
  3. Press the Power button (c01602202.gif ) to turn on the HP product.
Step three: Reconnect the data cables and devices
  1. Press the Power button (c01602202.gif ) to turn off the product.
  2. Reconnect one USB, Ethernet, or parallel cable to the back of the product.
  3. Press the Power button (c01602202.gif ) to turn on the product.
  4. Check the display for the error message.
    • If the error message does not display , reconnect another cable, and then repeat steps 2 through 4.
    • If the error message displays , replace the cable you just reconnected with a new one. Go to the How to Buy HP page to buy the replacement power supply for your product.
Step four: Determine if the HP product uses a power cable or a power module as the power supply If the power supply is a cable with electrical connections at each end, the product uses a power cable . Figure 3: Power cablec01369983.jpg If the power supply is a cable connected to a module or box, the product uses a power module . The power module might have a permanently attached power cord, or the power cord might detach from the power module. The term power module refers to both the power module and the power cord. Figure 4: Power modulec01369984.gif c02020663.gifIMPORTANT If the product uses a power module, make sure that the power module part number is the same as the part number listed in the User Guide to ensure you have the correct power module. If the part numbers do not match, replace the power module. Go to the How to Buy HP page to purchase the replacement power module for your product. Step five: Check the electrical connections and outlet
  1. Disconnect the power cable or power module from the back of the product.
  2. Disconnect the power cable or power module from any power strips or surge protectors.
    NOTE: If the product uses a power module with a detachable power cord, unplug the cord from the power module, and then plug it into the power module again.
  3. Wait 30 seconds
  4. Plug the power cable or power module directly into a wall outlet.
  5. Reconnect the power cable or power module to the back of the product.
  6. Press the Power button (c01602202.gif ) to turn on the product.
  7. Monitor the product to see if it turns on then off again.
    • If the product remains on , you might have too many devices plugged into the power strip or surge protector. You might also need a new one.
    • If the product turns off , the source of the problem is the electrical outlet. Continue to the next step.
  • If these steps resolved the issue , there is no need to continue troubleshooting.
  • If the issue persists , see the next step.
Nov 11, 2010 | HP Photosmart C5280 Printer
C module causes error message: "Error spawning cl.exe".
I'm guessing C Linker is the executable we want to bring in to make FORTRAN and C be friends; maybe you're missing an include line or environment declaration on the C or FORTRAN side to get it done (or better error messages!)
Feb 09, 2010 | Compaq Digital Visual Fortran Professional...
Had Oil Changed...Now I Can't SEE my INFORMATION DISPLAY!
  • The message center display is blank
  • Instrument cluster.
  • INSTALL a new instrument cluster. REFER to Section 413-01 .
see owners manual for information
Principles of Operation
The message center is a vacuum fluorescent display, part of the instrument cluster. The message center electronic functions use both hardwired, standard corporate protocol (SCP), and UART based protocal (UBP) communication networks to transmit and receive information. As a technician it is very important to understand:
  • where the input (command) originates from.
  • all the information (messages) necessary in order for a feature to operate.
  • which module(s) receive(s) the input or command message.
  • does the module which receieved the input (message) control the input of the feature, or does it output a message over the SCP communication network to another module?
  • which module controls the output of the feature.
The message center provides the following features:
  • information displays
  • setup displays
  • warning messages
  • system check messages
The message center information can be selected through a set of three bottons:
  • INFO
  • SETUP
  • RESET
Jan 08, 2009 | 2002 Mercury Mountaineer
Dell laptop Latitude c 810 BIOS revision A12
Your laptop's memory is malfunctioning. To remove the memory, power down your laptop.
Turn it over and you should see a cover about the middle of the back. Open it and there you should see the memory. You may or may not have more than 1 memory Dimm. Also there are 2 slots. The bad memory is the one in the first slot. Take it out and put the other in it's place. the laptop should boot up ok, but slower because of the missing memory which you should replace.
If you get the same message, replace the memory with the one you took out, then reboot.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Oct 14, 2008 | Dell Latitude C810 Notebook
Camera module not working of model s3
camera module of china mobile model-ztc 220 is not working displaying the message,camera module not ready....
pls assist me as soon as possible
Jun 30, 2008 | Handmark Software MobileLists (950142) for...
Editing text
Windows
» HP Scanjet Scanners Supported and not Supported in Microsoft(R) Windows XP s.gif » Resolving 'Missing MSIEXEC.EXE File is Linked to Missing Export: MSI.DLL.222' Error Message During Installation of the HP Director Software s.gif » Resolving 'Scanner not supported' or 'Unsupported operating system' Error Messages s.gif » Resolving Image Zone Install Error 1402, 1406, 1714, 1904, 1935, 2203, or Unknown Error s.gif » Error 'The System Cannot Find the File Specified' While Attempting to Install the HP Photo & Imaging Software in Windows 98, 98se, or Me s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Error Install Failure' Message for the hpznfx01.exe Software Module Displays on the Computer When Installing HP Image Zone s.gif » The message 'Fatal error during installation' or 'Error Install Failure' Occurs When Installing HP Image Zone s.gif » A 'Fatal Error' or 'Error_Install_Failure' Error Message Displays on the Computer When Installing the Image Zone Software s.gif » The Error Message 'Error_Install_Failure' or 'Fatal Error' Occurs when Installing Image Zone Software s.gif s.gif
Macintosh
» Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Scanner could not be initialized' Message Displays in Mac OS X when the All-in-One Software is Installed s.gif » Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif s.gifs.gif
Jun 13, 2008 | HP 4570C Flatbed Scanner
Vista with bootmgr is missing message
put your recovery disk or vista OS disk and repair the boot...
Mar 25, 2008 | HP Compaq Presario C500t Notebook
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
16 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
